LT1 swap in 66 el camino? - Chevelle Tech
Auto Insurance
Chevelle Tech General Tech Area
Please try and post in specific forums
Old Nov 22nd, 05, 8:33 PM
sweet64 sweet64 is offline
Default LT1 swap in 66 el camino?
Hi, my friend is swapping an LT1 from a 95 caprice into a 66 El Camino and have a couple questions.
What kind of radiators have guys used? Will the stock radiator work?
Are there issuses with the LT1 oil pan clearing the crossmember?
Is it necessary to modify or replace the gas tank for the fuel return line.
I really appreciate your help with this and any other info on the swap is welcomed.
Thanks...
Old Nov 22nd, 05, 8:35 PM
keithb keithb is offline
Keith
Send a message via AIM to keithb
Default Re: LT1 swap in 66 el camino?
1. I would go with a 4 core aluminum. but that is just me.
2. ?
3. yes I would
hope this helps btw I never did this swap
1966 Chevelle SS 396/360 M21 3:73 posi. silver/blue buckets
1994 Corvette coupe LT1 auto
Maryland Chevelle Club #682
Old Nov 23rd, 05, 11:24 AM
We'd like to use an original 3 row radiator so there's no problem bolting it to the core support.
Does anyone make upper and lower hoses that have different diameters at each end to accomodate the larger connections on the stock rad, versus the smaller hose connections on the LT1 motot?? thanks for the help.
Old Nov 23rd, 05, 11:52 AM
Derek69SS Derek69SS is offline
"The Stig"
What kind of radiators have guys used? Will the stock radiator work? I'm going to use the stock Chevelle radiator, and add an overflow tank.
Are there issuses with the LT1 oil pan clearing the crossmember? I'll let you know in a few weeks, my LT1 is still in the cop-car. I don't think it's a problem, though.
Is it necessary to modify or replace the gas tank for the fuel return line. You will need an electric fuel pump and return line. Internal pump is preferred. I still haven't decided what I'm doing on mine yet.
Other tips: headers may require a Corvette accessory drive bracket, or if no A/C, use a 1LE compressor-delete pulley.
Post pictures when you're done!
Derek Kiefer, member of Minnesota's Northstar Chevelle Club
69 Malibu Pro-Touring stroker LS1-383/T56 - 69 Chevelle SS396 325/3spd
Old Nov 23rd, 05, 2:06 PM
JWagner JWagner is online now
Gold Member
I dropped a 96 LT1 motor into my '72 chevelle a couple of weeks ago and there was no problem with the fit. I modified the crossmember under the trans to keep it way forward in order to keep the stock parking brake cable setup. The Caprice radiator looks like it will fit with a little fabrication. The Caprice steering gear looks like it will go in this week, so I will have an all -metric pump and plumbing. The Caprice hoses seem to fit well ,so far.
  #6
Old Nov 23rd, 05, 6:36 PM
Alwhite00 Alwhite00 is offline
Aren't the inlet & outlets reversed on a LT1? Upper right & lower left on the radiator I think.
LK
Chevelle Tech > Information Exchange > Chevelle Tech      Current Topic: LT1 swap in 66 el camino?
Location
*REQUIRED*
Insurance
First Name
Human Verification
