14" wheels w/ disc brake conversion - Chevelle Tech
Auto Insurance
Chevelle Tech General Tech Area
Please try and post in specific forums
Old Nov 16th, 05, 1:14 AM
Malibu Jimbu Malibu Jimbu is offline
Default 14" wheels w/ disc brake conversion
Thinking about going to front disc brakes with a conversion kit on my 67 Malibu. I currently have 14" x 6 (maybe x 7) Crager SS wheels. Will any of the aftermarket kits fit with these wheels? I've read where most people have to go up to 15" wheels after installing disc kits. I just put on a new set of Diamondback Redlines this summer, and don't want to have to buy new wheels & tires.
Old Nov 16th, 05, 5:56 AM
Dan Orgill Dan Orgill is offline
Team Member
Dan
Default Re: 14" wheels w/ disc brake conversion
If you want to go with disk, a stock disk setup from say, a '69 would likely work.
There are also conversion kits avl, try True Connections.
www.true-connections.com
Dan
Old Nov 16th, 05, 7:10 AM
DaleM DaleM is offline
Gold Founding Member
Dale
Be aware that discs ususally require a wheel with a greater positive offset, or more backspacing, due to the calipers. Most 'standard' custom wheels like Cragar, ARE, etc. designed for custom street use generally have just the opposite, less backspacing than stock for a 'deep dish' look.
You may have to forego the Cragars in favor of a set of GM rally-type wheels that were designed for disc brake applications or make the move to 15" or larger wheels. Another option would be wheel spacers but you may have to increase your wheel stud length to compensate for the spacer thickness.
TC Gold #92 ~ August 1998
* Ever stop to think, and forget to start again?
* ChevelleStuff - Decoding info for 64-72
* 1966/1967 Chevelle Reference CD/1970 Build Sheet Decoder CD
* Chevelle Registeries
* Build Sheet Data Collection
Old Nov 16th, 05, 9:51 PM
EddieC67ss EddieC67ss is offline
Didn't the 67ss that came with disc brakes have 14" ralleys?
MY 66 SS
Old Nov 16th, 05, 11:14 PM
Dale
Yep, mandatory due to the offset the rallys provided
  #6
Old Nov 17th, 05, 9:04 AM
Derek69SS Derek69SS is offline
"The Stig"
If you know anyone local to you with a 69-72 Chevelle, GTO, Monte Carlo, Cutlass, Skylark, etc with discs, just ask if you can test fit them.
Derek Kiefer, member of Minnesota's Northstar Chevelle Club
69 Malibu Pro-Touring stroker LS1-383/T56 - 69 Chevelle SS396 325/3spd
  #7
Old Nov 17th, 05, 2:26 PM
bhawk bhawk is offline
I converted my 69 cutlass to disc brakes, using stock A body components applicable to that year. Not the tall spindle swap, or the big 12 inch rotors, just stock 11 inch stuff. They caused no problems with my stock 14 inch Olds rally wheels. I suspect all rally wheels will be fine also, if you stay stock 11 inch A body rotor setup. Can't say how the Cragers will do, so hopefully someone will chime in with direct experience.
Marley; 65 malibu SS /70 vette /69 cutlass
  #8
Old Nov 17th, 05, 7:57 PM
zeke67 zeke67 is offline
My Keystones were fine -- I never even considered it when I did the my conversion with stock parts. There are factory 14 inch wheels for drum cars that won't clear discs though.
Zeke
67 Chevelle
64 Chevelle
90 Corvette ZR1
TC# 3094 ACES# 7297
Chevelle Tech > Information Exchange > Chevelle Tech      Current Topic: 14" wheels w/ disc brake conversion
Human Verification
