Please confirm this decode for me, 1969 Corvette L89? - Chevelle Tech
Auto Insurance
Chevelle Tech General Tech Area
Please try and post in specific forums
Old Nov 13th, 05, 7:51 PM
Stikman33 Stikman33 is offline
Daniel
Default Please confirm this decode for me, 1969 Corvette L89?
Hey guys, i am in the process of getting a corvette ready to go for a friend. I have posted info on here about it before but now i have some pictures. If you guys would look over this info for me i would really appreciate it. As by my current info it looks like it is a real 1969 Corvette L89 setup. The only thing that doesn't match to me so far is the heads, i dont know why they are 074 castings, i hear they should be something else, but by the block numbers it says that it is. Any help or opinions is appreciated.
Thanks for all the help once again guys.
Daniel
1970 Chevelle - Best time at the WCCG 12.749 @ 108.606, 2.011 60' on street tires!
427 BBC, 215 heads, 2.19/1.88 valves with some port work, 60212 Lunati Hyd Roller, 3310 Holley 750, Performer RPM intake, TH350 with shift kit, 3.55 gears 12 bolt posi, Pypes 3 inch kit, it's alive... again!!!
Old Nov 13th, 05, 8:18 PM
orange crush orange crush is offline
Default Re: Please confirm this decode for me, 1969 Corvette L89?
Daniel,
Looking at the corvette black book, your LP engine code is a 1969 Corvette 427/435 hp aluminum head engine. The 3946074 casting on the head is correct for that engine. The vin# makes it a earlier 69 model as the #' ran from 700000 thru 738762 the vin also shows it being a vette coupe.
Hope this helps,
Bill
Old Nov 13th, 05, 11:07 PM
Mike Feudo Mike Feudo is offline
The 074 is the L-88 ZL-1 head. With the closed chamber 11to1 pistons you definately won't have 435HP. I have never come across a real 69 L-89 head but it should be a closed chamber simular to the 392 head. I don't know if they used up all of the earlier heads they had or actually had a different casting but it's not an 074.
Old Nov 14th, 05, 1:15 AM
DaleM DaleM is offline
Gold Founding Member
Dale
Mortec.com shows the 074 casting for 69&71 rectangle port OPEN chamber (118cc) and idavett.net shows the L89 as an aluminum headed L71 (427/435) as well as the "LP" suffix code correct for a 427/435. Agree with Bill on this one.
NECOA #41 - 67 El Camino (sold) ~ TC Gold #92
* I only report what I read. If they're wrong, I'm wrong.
* ChevelleStuff - Decoding info for 64-72
* 1966/1967 Chevelle Reference CD
* L78~L79~LS3~LS5~LS6~YF3~SS396~SS~El Camino & Laguna S3 Registries
* ChevelleStuff Mailing List
Old Nov 14th, 05, 5:54 AM
von von is offline
Lifetime Founding Member
Von
Chevy By The Numbers shows #3919842 to be the correct alum head for a '69 427 L-71/L-89 Vette.
von '69 300 Dlx SS '69 Malibu TC #15 ACES #1575 HSCA #5
http://www.chevelles.com/showroom/da...m/DSCN1135.JPG
[img]
http://www.chevelles.com/showroom/da...m/DSCN1397.JPG
  #6
Old Nov 14th, 05, 6:59 AM
David Bates David Bates is offline
Dave
Agree!
Dave
My 65 Elky & 2002 Camaro SS
EC#1
05 Vette & 65 El Camino 1
NEW - Original 39000 mile 1965 Malibu SS Convertible
USAF Retired (1968-1988)
  #7
Old Nov 14th, 05, 8:02 AM
Dale
Mortec shows the 3919842 aluminum head for a CLOSED chamber w/107cc L88/L89. Could both heads be correct?
  #8
Old Nov 14th, 05, 10:08 AM
67-68 L-88 L-89 are closed chamber. 69 L-88 is open chamber. The 69 L-89 is closed chamber. The L-89 was just a std HP engine with alum. heads nothing else was different.
  #9
Old Nov 14th, 05, 10:16 AM
sob sob is offline
darryl
Hey Daniel,maybe this website can help further,post any questions on that motor in the c3 section,my L71 vette was modfied with 1971 openchamber heads with different pistons to help with todays gas,this was done in the mid 80s though I have all the ori. parts, what are the date codes on the heads?Darryl
http://forums.corvetteforum.com/index.php
1967 chevelle ss conv. 1966 chevelle ss coupe ,team chevelle member # 713
  #10
Old Nov 14th, 05, 12:32 PM
Daniel
Thanks sob, i will post over there as well. Where are the date codes on the aluminum heads? I didn't see anything readily recognizable on the top of the head, i had heard that for the aluminum heads sometimes the date codes were on the bottoms? Thanks for all the help/comments so far as well...
I had the same thoughts on the heads, i had heard they were supposed to be 842 heads. What is interesting to me though is the block is obviously the LP engine code, and it matches the VIN # of the car. Everything else it has matches as well including the rear end and tranny in the car. I searched the car high and low for a build sheet and have not been able to find anything, so i really dont hope to still find out. He is interested in selling the car eventually, but we are just trying to figure it all out now, and see whether or not its an L89, or an L72 i think it is that is the standard head 435 hp version.
Daniel
  #11
Old Nov 14th, 05, 12:48 PM
von von is offline
Von
The 435 hp 427 was option RPO L-71. If you wanted that with alum heads, you got RPO L-71 THEN added RPO L-89 which replaced the cast iron heads with aluminum versions. The L-88 was a whole different ball game. No heater or radio, different hood, very limited production car, very different 427 with huge solid lifter cam, 12.5-1 CR, open chamber alum heads, high rise 1x4 bbl intake with no center divider, 850 cfm Holley, etc.
[img]
  #12
Old Nov 14th, 05, 1:07 PM
Daniel
Yeah, i have seen the info on the L88 and i dont think this is one... What i am really trying to decipher is whether this was an L89, or its just another L71 that someone put a tri-power and 074 heads on.
Was this deck number exclusive to L89 motors with the LP code, or could the LP code also have been an L71?
Daniel
  #13
Old Nov 14th, 05, 3:20 PM
Daniel,
To the best of my knowledge and I don't claim to be perfect but the L89 is an L71 with alum. heads, the alum heads make it a L89. The L88 would have a LV engine # so it is an L89.
Bill
  #14
Old Nov 14th, 05, 3:54 PM
DougA DougA is offline
Doug
I have no idea what any of those codes mean,but I sure would like to go for a ride in it when its done.
70 SS 454 LS-5 M-22 Matching #'s
Jeff Dotterer Authenicated
LS-5 Registry
72 SS 454 El Camino W Code
Powered by 68 427 215 Iron Oval Heads Tex/G-Force 101A 4spd.
Best 60',1.49, 6.98@99.88, 10.92@123.13
My Showroom
In Car Camera Rowin' Gears http://www.youtube.com/watch?v=5vMnf...layer_embedded
Elky At the Track http://www.youtube.com/watch?v=YOVGi...layer_embedded
Wheels Up http://s1268.photobucket.com/albums/...urrent=009.mp4
  #15
Old Nov 14th, 05, 4:13 PM
sob sob is offline
darryl
the LP code confirms that the motor is a L71 with alum.heads=L89 with a 4 speed.and by the looks of the pad,it has never been messed with(original broch marks) some places to find the build sheet,on top of the gas tank,usally on drivers side.between the tack and speedo (you have to take the dash pad off )inside the dash,behind the kick panels,under the carpet in the back storage area, also in the seats.and people have found them shoved in diff. sections of the frame.you can pull down the rubber gas boot and take the gas bezel off and with a flashlight look on top of the gas tank to see if the buildsheet is still glued onto the tank,if it is DONT TRY TO REMOVE IT! drop the tank(only takes 30 mins,)try to dust the years of dust off with a paintbrush and take a pic. of it and reinstall the tank.what I did with mine is I took plastic with duct tape and put plastic over it then reinstalled the tank just to help preserve the build sheet,that looks to be a VERY rare car,Darryl
You may not post new threads
You may not post replies
Similar Threads
'06 Z06 Corvette - $65,800 Derek69SS Bench Racing 53 Nov 18th, 05 5:05 PM
Any problems putting a 1969 Rochester Corvette 350/350 HP on my 1969 L34 Chevelle? Steve Petzer Engine 1 Aug 22nd, 04 10:21 PM
Decode Corvette rally wheels? gigem Tag Team 3 Mar 6th, 04 2:29 PM
