Buffing and cleaning 14 yr old lacquer paint - Chevelle Tech
Auto Insurance
Body Shop Paint & Body Forum
Old Nov 8th, 05, 8:22 AM
richr richr is offline
Gold Founding Member
Rich
Send a message via MSN to richr
Default Buffing and cleaning 14 yr old lacquer paint
The other day I accidentally got super glue on my 14 yr old lacquer paint (another story), I tried everything to get it off carefully. Finally I had some 1500 grit paper so I carefully wet sanded it. Then of course I only had polishing compound to get those scratches off - this took a lot of rubbing but in the end the glue is of and that spot came very smooth and the depth of color looks great.
So I am now considering wet sanding the entire car, but not with 1500 as it was too aggressive and buffing it out. Just wondering what the best method and materials I should use to do this, 2000 - polishing compound? Brands etc? The paint still looks great but it can look better, it is a clear coat lacquer done apprx 14 yrs ago Mist Green.
Thks
Rich
70 Convertible 454
Member # 442
ACES # 3480
http://www.my70ss.com
http://www.chevelles.com/feature/august2001.html]
Old Nov 8th, 05, 8:47 AM
67shovel 67shovel is offline
Roger
Default Re: Buffing and cleaning 14 yr old lacquer paint
By all means buff it ouit again. Lacquer loves that. Stay off your edges or tape them with masking tape to keep from burning through. I'd hit it with 2000 grit and then buff it out. I use 3M stuff....a light grade rubbing compound since we have used the 2000 grit followed with a wash and then a glaze. Finally a hand wax
Old Nov 8th, 05, 11:21 AM
Rich
Ok thks 67 so here are the steps I should take - sorry to being extra thorough - just want to insure I do it right -
Wet sand with 2000
Buff with a light grade of 3m rubbing compound - any particular name?
Wash - just water rinse?
Glaze - 3M fill and glaze?
Thks
Rich
70 Convertible 454
Member # 442
ACES # 3480
Old Nov 8th, 05, 4:10 PM
Johnny B. Johnny B. is offline
RichR,
I'll second the using of 2000 for wet sanding. I use Mequires Diamond cut
compound. This stuff is great and can save you the polishing step. After
doing my 69 with this combo, I used Mothers carnuba and it looks real
wet. Although ANY 3M product has always worked well for me also.
Oh, use a nice wool pad at 1200-1800 rpm when using the Diamond cut.
Old Nov 8th, 05, 11:16 PM
sob sob is offline
darryl
Hey Richr,you might want to consider using system 1 for a compound,you can use it through all steps(wool,foamand finish pads)and when all steps are done right there are no swirl marks!the only downfall is it is alittle spendy.I have used a lot of different compounds but system 1 is my favorite,and no I dont have stock in it LOL.Darryl
1967 chevelle ss conv. 1966 chevelle ss coupe ,team chevelle member # 713
  #6
Old Nov 10th, 05, 9:08 AM
Roger
I'm using 3M Microfinishing compound. You sand it, then wash, then buff, then wash, then glaze (swirl mark remover), wash if necessary and then I hand wax. The washing is very important! First you wash and scrub the car before starting. Next you wet sand with the hose in one hand giving you a trickle of water to keep the fine paper from filling up. Don't sand where you can't buff like real close to emblems and trim. Rinse car to get get sanding residue off, let dry and start with your compound. When you have finished you will need to wash all the compound grit of the car or it will contaminant your next step with the glaze. You can't get the swirls out if your glaze is picking up the coarser girt of the compound. If you don't have experience with a buffer better to start on a beater car first, it can get away from you, grab loose clothing, and burn right through the paint and primer and leave you looking at bare metal. You will need to use clean buffing pads also. If you only have one pad you will need to wash the compound out of it before moving onto the glaze.
  #7
Old Nov 10th, 05, 12:16 PM
pist0lpete pist0lpete is offline
Neal
Why is everybody so gung ho about wet sanding the car? Unless he has alot of orange peel to take care of, he should be able to achieve a great shine and depth by merely buffing the car and by doing so he will remove much less material.
  #8
Old Nov 10th, 05, 12:48 PM
Bill Rose Bill Rose is offline
Team Member
Bill
Why buff the car then. The whole reason for buffing is to bring the shine back from wet sanding. Sanding/buffing is the final stage in a quality paint job. Sanding gets out any dust/dirt, as well as taking out any orange peel and makes the paint "flat".
For collision work on a Toyota, paint it and drive it, but for a top notch paint job, it HAS to be sanded.
I know/seen the Chevelle Rich wants to sand/buff, and trust me it is well worth spending a few weekends doing this correctly...
  #9
Old Nov 10th, 05, 3:18 PM
Roger
PistolPete has a good point. Not all cars need to be wet sanded and on some the paint is so thin you could go through.
  #10
Old Nov 10th, 05, 4:34 PM
Neal
Well cars can lose their shine over time from various elements in the environment. Buffing would bring that shine back out. Thats why people have their cars buffed its a common practice. The procedure for buffing a car after wet sanding is not the same as buffing a car at say your local detail shop. Buffing is definitely not a process to only be used after wet sanding. Like I said the process and compounds can differ somewhat but the end result is the same. However, you have seen the car and I have not, I was merely speculating on whether or not it has orange peel so if it does by all means wet sand it. See for all I knew the car was wet sanded 14 years ago when the paint was done. I was just going with the information provided.
Chevelle Tech > General Tech Area > Body Shop      Current Topic: Buffing and cleaning 14 yr old lacquer paint
Human Verification
