Holley 870 Street Avenger - Chevelle Tech
Auto Insurance
Old Sep 20th, 05, 1:41 PM
SS427Rick SS427Rick is offline
Question Holley 870 Street Avenger
I'm thinking of trying different carb on my 69 SS396. I currently run a 750 d.p.but want to try a 870 vac. sec. Street Avenger. Engine is a 427 with about 11:1, .561/571 lift Comp. cam, 3000 stall, 410:1 gears. If anyone has any info. please reply. Have been told this carb would work well with this engine combo. Thanks.
Old Sep 20th, 05, 2:16 PM
69-CHVL 69-CHVL is online now
Vinny Vince
Default Re: Holley 870 Street Avenger
Its a nice carb, but like all 850's its jetted rich (78/82 w/front and rear power valves). I had one on a 454HO and it ran nice - no soggy bottom end, great response, etc.
Personally, if you need a 800+ cfm vac sec carb, I would go on ebay and get one of those ZZ502 850cfm take-off carbs. I've seen them new go for around $250, and its basically the same thing (less the quick change secondary can) and you save quite a bit of money over a new 870. The Avengers have that shiny finish that looks good coming out of the box, but turns crappy looking pretty quick.
*69 CHEVELLE SS EFI 502/T56/3.90
*06 C6 LS2/T56
*96 Stang LS/6.0 turbo - everyone should have one!
ak69 ak69 is offline
Score the 770 avenger. That's a better fit for sure. I did a little testing at the track. Car ran times in my sig with a Prosystems 1000hp, yanked that carb and put the 770 back on the car. I had the need to slow it down as I have no cage fro running under 11.5. Car ran a best of 11.58 with the avenger. Prior to the carb swap, change in rear gear, box stock avenger 770 jetted 74/84 on my car ran 12.1x. Electric choke worked great, plenty of vac ports, and SHINEY too!
Craig
69 Malibu BSE 454/TH400
Best pass 7/4/06
1.4882 60Ft
6.8929 1/8 ET
99.35 1/8 MPH
10.87 1/4 ET
121.69 1/4 MPH
Best 60' 1.46
Old Sep 20th, 05, 4:00 PM
GRN69CHV GRN69CHV is offline
Team Member
Joe
Had an 870 Avenger (out of the box) on my 408CI motor. The 870 was far too much carb for it. Not that it wouldn't get by, but the throttle response was real lazy. Probably good for a 4500 - 7000 RPM motor, but crappy below it. Now running a 670 on an Air Gap oval intake with the heavy (black) spring - throttle response is like fuel injection.
Status: Car-Less
http://www.chevelles.com/showroom/sh...2/limit/recent
Old Sep 20th, 05, 8:55 PM
mrchevelle mrchevelle is offline
Smile Re: Holley 870 Street Avenger
hi,
just rejoined this fine site, and reading your post, Ever think about a demon? I have a 66,ss L78, and I'm trying a Mighty Demon, had to do some jetting, but ! I like it ton's of throttle response, no bogging,and hold on to your pants .Jusr my 2 cent's worth.
good luck
the originial MRCHEVELLE
www.picturetrail.com/mrchevelle
  #6
Old Sep 20th, 05, 10:44 PM
Whittaker Whittaker is offline
Rob
Send a message via ICQ to Whittaker Send a message via AIM to Whittaker
I have the 870 on my 489. Runs great. I have played with the jets though. The 770 didn't have the top end this has.
BTW it is just like the 850 that comes on ZZ502 motors just shiney.
1966 Chevelle Malibu 489, 870 Holley, Edelbrock RPM Air Gap, 781 oval ports, TH 400 Gearvendors OD/UD, 12" disks up front and 9 inch with 3.50s.
1966 Chevelle wagon, 408 SB, 3.73 12 bolt, 700R4, 12" discs front 10" rear.
  #7
Old Sep 20th, 05, 11:27 PM
No difference in MPH with the 770 / 1000hp swap on my ride.
Craig
Best pass 7/4/06
1.4882 60Ft
6.8929 1/8 ET
99.35 1/8 MPH
10.87 1/4 ET
121.69 1/4 MPH
Best 60' 1.46
  #8
Old Sep 22nd, 05, 8:45 PM
I went with the 870 Street Avenger. Just came back from trying it out. Works great. Same bottom end as 750d.p. but far more high r.p.m. power. I think I made the right choice.
Chevelle Tech > General Tech Area > Performance      Current Topic: Holley 870 Street Avenger
Human Verification
Similar Threads
Street Avenger 670 or 770 for my combo? JimChevy Performance 5 Jan 25th, 05 10:19 PM
holley street avenger stringer69ss Performance 1 Oct 13th, 03 9:23 PM
Holley Street Avenger mapleaf Engine 4 Jan 6th, 03 4:55 PM
Good deal on Holly Street Avenger carbs Hotrod65SS 2001 3 Apr 27th, 01 2:28 PM
Holley street avenger carb Hot66ss 2001 5 Feb 18th, 01 7:54 PM
