Brake Conversions Tech info on converting from drum to disc
Old Sep 18th, 05, 3:18 PM
PaulR PaulR is offline
Default 1971 Combination vlv on 1970 frame
Hello, I am installing 1971 brake lines on my 1970 Chevelle convertible, to include the combination valve for a 71. I am wondering if someone out there could provide a picture of this valve installed in its proper location on the frame so I can determine what bracket I might be missing or what minor mods I might need to make to my lines in order to get the hydraulics installed as correctly as I possibly can. Thanks for any help you can provide.
Paul
1970 convertible
454 EFI 700R4 3.55 posi
  #2
Old Sep 22nd, 05, 6:17 PM
Gambi69 Gambi69 is offline
Default Re: 1971 Combination vlv on 1970 frame
Paul,
I am doing the same as you, (except my 71-72 valve is going on a 69 frame)
I haven't installed yet, but I purchased this bracket from inline tube. It is supposed to put the valve in the correct location, so you don't have to bend up your lines more than necessary. You CAN just bolt the valve directly to the frame, as many do, but that involves more line tweaking.
To me, it's worth the 22 bucks!
www.inlinetube.com
Part Number - BRK-04* 1971-72 GM A-body Valve Bracket *** $22.00*
1971-72 GM A- Body
Chevelle / Lemans / Cutlass / Skylark / El Camino / Grand Prix / Monte Carlo
Factory Disc Brakes
1964-72 GM A- Body
Disc Brake Conversion
1971-72 A-body Disc Brake Bracket
Details:
This item is an exact reproduction of the 71-72 A-body disc brake bracket. All factory disc brake cars had this bracket to hold the prop. valve to the frame. Drum brake cars did not have this bracket only the front disc cars. If the car is being converted to disc brakes this item is a must to place the valve in the right location so the factory lines will bolt into the correct location. All the disc brake companies use the wrong bracket that mounts up by the master cylinder. All 68-72 A-body cars mount the valve at the frame. The valve will only mount correctly with the use of this bracket. This bracket will fit
This bracket may also be used if converting a 64-70 A-body to disc brakes using the GM 5 port valve. Although not correct, since 64-66 cars were not available with disc brakes and 67-70 used a two part valve one piece mounting on the frame and a second part at the master cylinder, this bracket does mount the valve in the proper location on the frame instead of up by the master cylinder.
-gambi69
Old Oct 10th, 05, 5:34 PM
scubaman scubaman is offline
there was also a rear valve on the 70 disc drum version
S
You may not post new threads
You may not post replies
Similar Threads
Frame Question BIGJACK Body Shop 5 Jan 8th, 03 10:41 AM
frame; repair or replace? 72sselcamino Body Shop 3 Apr 8th, 01 3:15 AM
Swap frame or have current frame fixed up? Gandalf80 Body Shop 6 Jan 12th, 01 6:02 PM
frame off resto.....what now? nebula72 1999 -- 12 Nov 19th, 99 1:15 PM
pulling body off frame BigT 1999 -- 4 Nov 29th, 98 10:29 PM
