1970 Muncie 4-speed TRANSMISSION?? or - Chevelle Tech
Auto Insurance
Transmission & Driveline Transmissions and Differentials
Old Sep 18th, 05, 3:50 AM
ahaban1931 ahaban1931 is offline
Question 1970 Muncie 4-speed TRANSMISSION?? or
Hey gang. Whats up? Im new to this fourm and would love some intput on this subject matter if anyone is kind enough to do so. I have a 1970 Chevy Nova SS and I require a transmission. What would you guys recommend?
Old Sep 18th, 05, 4:21 AM
Adman Adman is offline
Default Re: 1970 Muncie 4-speed TRANSMISSION?? or
engine specs? Rear gear? What you already have? your goals for the car? Usually the base th350 is perfect.
1965 Chevelle Malibu SS.
www.livermoremuscle.com :: For my car
Years away from being my 8-71 blown 540, TKO 600, 4.11 and 4 wheel disc brake monster.
Old Sep 18th, 05, 12:35 PM
Dustinyork Dustinyork is offline
Talking Re: 1970 Muncie 4-speed TRANSMISSION?? or
if your asking about trannys i think for a mild small block th350 for an auto is fine , though behind the stroker i cracked two cases and eventually went to a turbo 400 wich i think if your going to go street strip its the way to go . 4 speeds are great but there are some weak ones out there . a muncie will put up with abuse but it seemed when i started to hook is when it broke (m20) .m22 rockcrushers seem to be tough but expensive and hard to find parts for. . i went to a super t10 out of an older trans am (26 spline input shaft) and it seems to work well . i had a cast iron three speed that i couldnt kill , since it had no fourth in it i suppose it left room for larger stronger gears from the factory ? but i still prefer a 4 speed with reverse in the tail . no saginaw four speeds they make hemselves into soup the first good launch
Old Sep 18th, 05, 1:53 PM
Wally Wally is offline
Moderator/Gold 67
If racing and sticky tires are in your future, then consider a automatic. They are far easier on parts than a stick car and are more tolerant of a bad setup. A stick car needs a good suspension, no wheel hop and bullit proof parts.
But if the street is your thing with a blast at the track every now and then you can't beat a stick for fun factor. Parts for any muncie are available new, not hard to find at all. There are also new gear sets for muncies now, M22 wide ratio and a M21 wide, not just another M20.
Every part of a Muncie had been reproduced and most of the new parts are much stronger than the originals.
Gold 67
M.C.C. 559
1967 Malibu
Nothing Shifts Like a Muncie!
Chevelle Tech > Mechanical > Transmission & Driveline      Current Topic: 1970 Muncie 4-speed TRANSMISSION?? or
First Name
Human Verification
Similar Threads
Wally - Muncie 5 Speed Update? LS_5 Transmission & Driveline 71 Nov 10th, 10 3:21 PM
TH400 to a Muncie 4 SPEED PE TCHR Transmission & Driveline 7 Dec 18th, 03 8:38 AM
Muncie help 69velle Transmission & Driveline 3 Dec 22nd, 02 10:28 PM
Muncie 4 Speed Linkage JMiddione 1999 -- 1 Aug 19th, 99 8:46 PM
Need help identifying a Muncie 4 Speed Donny Moore 1999 -- 4 Jan 1st, 99 6:32 PM
