HEI Spark plug wire?? - Chevelle Tech
Auto Insurance
Electrical & Wiring Troubleshooting electrical problems.
Old Sep 13th, 05, 8:30 PM
nolimitpkr nolimitpkr is offline
Brian
Question HEI Spark plug wire??
Can anyone post a diagram of the firing order for a small block with a HEI distributor. I know the correct firing or, just not where to hook the wires back onto the cap. I up graded my 350 with a new cap and the coil is on top of the cap, but the only diagram I have to hook back up the spark plug wires, is for a points distributor. Will this diagram work??? Thanks for the help.. B.
Old Sep 13th, 05, 8:41 PM
BillsCamino BillsCamino is offline
Gold Founding Member
"Wild Bill"
Send a message via AIM to BillsCamino
Default Re: HEI Spark plug wire??
The firing order is the same...
18436572 clockwise
Where #1 wire terminal is on the cap depends upon where the rotor was pointing and the position of #1 cylinder when the distributor was installed.
1972 GMC Sprint
Team Chevelle #613
ACES #3920
CAMI (Ireland) #14
CanAm Chevelles #136
Carolina Chevelles #185
Heart Of Dixie #231
Long Island Chevelles #113
Old Sep 13th, 05, 9:26 PM
Finally Finally is offline
Hank
What Bill said, firing order doesn't change. Usually #1 is around the 4-5 o'clock position looking down on the distributor from the front. From there, like Bill said, clockwise around -8436572. #2 would end up being around the 1-2 o'clock position. No guarantee, that's just normal position.
Hank
70 Chevelle SS396(454), M20, 3.73
My Chevelle
Old Sep 13th, 05, 9:46 PM
Dean Dean is offline
Moderator
Gold Founding Member #3
My 69 SS
My 70 Convertible
Mid America Chevelle Club #01
Old Sep 13th, 05, 10:49 PM
rianbechtold rianbechtold is offline
Ryan
Hey Dean, that isn't for ALL HEI's is it? I have a GM hei on mine and i hooked the wires up like that when i first got it (about 6 months ago) and i couldn't start the car. I moved the wires one spot to the left (looking down on the cap, clockwise) and it fired up and runs perfect.
No SS here! Proud owner of a 1971 Malibu 454.
Updated Pic 1
Update Pic 2
Updated Pic 3
  #6
Old Sep 13th, 05, 10:54 PM
LeoP LeoP is offline
leo
Your dist is off probably a couple of teeth, since it runs and you can set the timing, leave it alone.
Leo Paugh
Maryland Chevelle Club #017
A.C.E.S.#3731
progress has little to do with speed, but lots to do with direction
www.mdchevelleclub.com
  #7
Old Sep 14th, 05, 1:18 AM
Brian
Took the advice, and I got the damm thing to fire... HURRAY, but it is still running a little ****ty. My question now is, do I just have to tweak the timing, and adjust the distributor a little here and there? Would the car run at all if I was not at or near top dead center?
  #8
Old Sep 14th, 05, 7:21 AM
Hank
I replied to you post in chevelle tech 2005. Yes it will run if close enough. Set the timing with a light and you should be all right.
Hank
My Chevelle
  #9
Old Sep 14th, 05, 8:57 AM
Moderator
It doesn't really matter which position #1 is in as long as the distributor can be rotated enough without interference and the wires will still reach.
You could start with #1 anywhere on the cap but the vacuum advance might hit on the firewall or the wires might be behind the dist. but you could still get the timing correct.
My 69 SS
My 70 Convertible
  #10
Old Sep 14th, 05, 12:29 PM
Brian
Thanks for all the info DEAN, really helped me out, the vacum advance is sitting around the 7 o'clock position right now, so hopefully it will be alright. Thanks for the reply's.
Chevelle Tech > Mechanical > Electrical & Wiring      Current Topic: HEI Spark plug wire??
Human Verification
Similar Threads
ALT harness question for alt upgrade...again BlackNBlue65 Electrical & Wiring 8 Sep 12th, 05 5:08 PM
Spark Plug Selectoin dave_silva Performance 0 Mar 16th, 05 7:43 PM
Spark plug wire routing??? gatkins 2004 2 Jun 23rd, 04 3:23 PM
how close for spark plug wire to headers?? storm Electrical & Wiring 2 May 31st, 04 8:18 AM
72 SS GAUGE BULKHEAD CONNECTOR PINOUT MATHER34 Electrical & Wiring 8 Mar 19th, 04 12:03 AM
