Quadrajet Electric Choke - Chevelle Tech
Auto Insurance
Old Sep 5th, 05, 9:09 PM
malibu man malibu man is offline
Default Quadrajet Electric Choke
Anyone know how to preliminary install, set, and then adjust one of these? Just rebuilt an '79 vintage M4MC for the '72 and everything is done besides the choke. I put it together and set it, and I think it works. But I never made a mark for reference when I initially took it apart. So I took the choke back out of the housing just to see how it works, and now I can't get it to work again. It warms up and everything. I'm energizing it with a battery charger, and I get spark at the charger clamp when I complete the connection, so I believe it should work. I just can't get it to work the choke.
Any advice, or support?
Old Sep 5th, 05, 11:34 PM
77 cruiser 77 cruiser is offline
Jim
Default Re: Quadrajet Electric Choke
I usually set it so the choke plate just barely closes @ 70 or so deg. Does that help?
Jim
77 Monte
385- AFR 190's Clay Smith solid--200-4r w/ 3.73's
67 Imp.SS for the wife 275 hp 327-TH350
http://myweb.midco.net/77cruiser/
Old Sep 6th, 05, 12:23 AM
I wish I could say "yes".
70 deg angle?
Old Sep 6th, 05, 12:33 AM
Tom Mobley Tom Mobley is online now
Boldly procrastrinating
TerribleTom II
sounds like you missed the link to the choke with the bi-metal coil inside the cap. pop it out, look again. the end of the coil has sort of a C-shaped tail, the link to the choke mechanism go in that C. Did you install the little link that goes inside the carb body, the shaft coming out of the choke housing goes into it after passing through the outside wall of the main body.
I think he meant 70 degrees Farenheit, something I won't be seeing any time soon here in Phx.
Tom
Old Sep 6th, 05, 12:54 AM
Hi Tom,
That was my first guess on the 70 degrees Farenheit. I knew he meant either that or a 70 deg angle. Take your pick kind of thing.
The choke links are installed and hooked up in the body, and i've had the choke on and off several times, always making sure that the choke goes around the link inside the housing. I can rotate the choke (like the way it would be adjusted) and can get the choke to go on and off, but don't know what orientation to set it to for a baseline adjustment, just to make sure it works.
I might just set the choke so it stays open for now and try the carb out sometime during the day tomorrow. I hope it works. I mistakingly tampered with the primary metering adjustment screw for the primary piston, and set it to 3.5 turns out for an initial adjustment. Think that will work? Will the air horn gasket be reusable if I have to go in and readjust?
  #6
Old Sep 6th, 05, 5:14 AM
Unclepennybags Unclepennybags is offline
Mike
The airhorn gasket will be okay if you have to open things back up once or twice.
For a baseline, I rotate the black cap until the choke closes, then rotate it the other way until it just opens. I lock it down there. This is assuming 70 degrees or so.
3.5 turns will probably get you close on the APT.
  #7
Old Sep 6th, 05, 9:51 AM
Jim
Yea 70 deg. F. that's a warm day up here.
Jim
77 Monte
  #8
Old Sep 6th, 05, 9:59 AM
Yeah, been getting pretty unseasonably warm in southern MN lately. Lower 90's...... Maybe warm again this weekend. BTW, it's about 70 degrees here right now.
Thanks for the tips on the rest of the carb.
I found a decent link about modifying Q-Jet's to work on engines with larger cams. http://www.corvettefaq.com/c3/myqjet.htm I wonder now if this carb will even work decent on my engine. It currently has a 244 @ .050" cam, which according to that link will make the carb run bad.
  #9
Old Sep 6th, 05, 10:10 AM
Jim
It adjusts your part throttle (cruise) A/F ratio. The 3.5 turns that Mike said will get you started.
Jim
77 Monte
  #10
Old Sep 6th, 05, 12:46 PM
I set the choke like you told me and I hooked it up to the battery charger. It does work!
  #11
Old Sep 6th, 05, 7:40 PM
HemiTCoupe HemiTCoupe is offline
Q-Jet info----> http://www.florida4x4.com/tech/quadrajet/
Pat
HemiTCoupe
Pro Street Full Fendered '27 Ford T Coupe -392 Hemi with Hilborn injection
'27 Ford T Tudor Sedan -V-6
'68 El Camino 406
'87 Mustang GT convert -302
Trike Shop -VW Trike -1835
'93 S-10 4X4 Blazer (Hey! it snows here) Oops! it's a parts car now
  #12
Old Sep 6th, 05, 8:44 PM
Thanks for that link!
Put the carb on the grain truck today. Figured since it has a Performer intake, I might as well test it out on that. It's a very mild 355. I am very impressed with the Q-Jet. The last one that I ran was a 4MV with no choke linkage or linkage from the vacuum canister to the secondary air valve. Never could get it working. It came from a local dirt track racer, don't know if it was ever used in that application. I should see what it has for tuning parts in it. Probably stock, not too many Q-Jet tuners around here that I know of. Anyways, I thought this carb worked good today, right from bolting it on. APT screw was adjusted out 3.5 and idle mixture screws were adjusted out 3.5. I'm anxious to see how it works on the 383. I have to get a manifold for it yet, though. Unless, is their a way to bolt it up to a Stealth intake?
I took the truck out to the corner and back tonight. I thought it was underpowered, but then remembered that I forgot about something. The electric choke wasn't wired up, so the secondary lock was on and I didn't have the secondaries. As I was driving it I thought that I would come on here and tell the symptoms (the secondaries don't feel like they're coming on), but then I forgot about that secondary lock. That carb has fairly small primaries on it too (also the fact that it's a spreadbore), so it wasn't too powerful with the front two. I managed to rig a throttle system up with a spring, temporarily, so there is a little play in the pedal. I just wanted to see if the carb worked, and wanted to be able to move the truck around.
  #13
Old Sep 6th, 05, 9:07 PM
Just thought i'd add. I had to pull the carb off right away because I wasn't getting any fuel out of the carb. Found that for some reason the float rod was sitting on top of the float linkage instead of through it. Got that fixed, got it assembled, and saw that I forgot the float bowl filler piece, so had to take the top back off again. Then I put it back on the truck. It was the first time that I had fuel to the carb. After I got it running I noticed that the air horn gasket surface in front was wet, where it protrudes out of the carb. I took the 1/4" nut driver with torx bit and snugged the front screw up a bit more. Not sure if i'm getting any more moisture out from the gasket area at all. I'll check tomorrow.
Another thing I found was a vacuum leak. There is a hole in the front above the filter boss that comes from the right, and goes up and towards the center at a slight angle. At first I heard the noise and I found that the PCV hose wasn't hooked up. After I hooked that up, I still heard the noise. Then while hooking the valve up into the valve cover, I saw the hole. And after restarting the engine, I felt a good amount of vacuum from that hole. I managed to use a vacuum plug (that would be used on a vacuum fitting) and pushed it in the hole with the closed end in so it stuck in there, and it sealed it up good.
Chevelle Tech > Mechanical > Engine      Current Topic: Quadrajet Electric Choke
Human Verification
Similar Threads
electric choke/ manual choke? hischildbrian Engine 12 Sep 21st, 05 8:36 PM
Problems with Holley Electric Choke minnocen 2004 17 Oct 29th, 04 3:13 AM
Electric Choke Why th 12 Volts Brob Electrical & Wiring 9 Jun 11th, 04 7:29 AM
Q-jet electric choke conversion Monte-73 Performance 4 May 4th, 04 6:58 PM
What's the best Quadrajet choke, electric or mechanical? chevyjim Engine 8 Apr 22nd, 04 7:29 PM
