| Chevelle Tech Current Topic: AWSOME conversion kit!!! | ||
| Brake Conversions Tech info on converting from drum to disc |
Last week I finally purchased a front disc conversion kit after much research. This kit was COMPLETE! I mean everything, never had to leave the house. $649.95 It even came with ALL the hard lines pre-bent and marked, Master to prop valve and lines to front hoses, I didn't even know it was comming with them. Proportioning valve mounts in same spot and REPLACES old junction block, no mounting to side of master cylinder. This kit even had everything already assembled! Not the lines obviously. I was truely amazed and impressed, 4 hour removal and installation for a novice, front clip and motor removed so it made it easier. I would recommend this kit to anyone! Found it on ebay at Matts Classic Bowties item#6872cbk-s-11-2. Their # is 1-866-628-8746. Want to say thanks to Olle for all his help with the research and pics. Hope this helps someone. As always thanks to all,
Brian Last edited by hischildbrian; Sep 4th, 05 at 10:23 PM. |
#2
2 thumbs up
Dan......66 ss396 chevelle with a brodix headed 496,2002 corvette with a afr headed 414 stroker |
Wow... that's cheap, considering that everything is included, and that it even fits. Glad it worked out for you!
Matt's classic bowties is one of the places I looked at before buying my kit, but they were more expensive back then. I just checked their web site and a complete kit is $729. Was this some kind of special? Would be interesting if you posted a review, I would really like to know more details.
1969 Malibu in progress |
Not sure if it was on special or not. I ordered the kit over the phone on 8/29 and recieved it 7 working days later just like thy said. I paid $649.95+$89.00s/h=$738.95 total. If the kit is now $729.00 I'd say it is well worth it, I still highly recomend it! Thanks for your help always guys!
Brian |
That's very cheap for a "kit" but you can piece together your own kit using junkyard spindles for a few hundred less... but it may be worth the ~$300 to not have to search for parts, or drive around to every parts-store in town looking for the right parts.
Derek Kiefer, member of Minnesota's Northstar Chevelle Club 69 Malibu Pro-Touring - 69 Chevelle SS396 - 66 Chevelle Wagon - 95 Caprice Wagon -23 Model T Ford |
#6
I might add that I have done several conversions using junk yard parts. My experience is that you won't save much money, unless you already have a parts car or a good source for very cheap parts. And I don't know how many times I have bought used parts out of a bargain bin at a swap meet, just to find out later that they won't fit. Maybe I'm just getting old and lazy, but I think kits are the way to go.
1969 Malibu in progress Last edited by Olle; Sep 6th, 05 at 3:48 PM. |
#7
Gas was $1.05/gallon then, so the 15 miles each way to the junk yard and parts stores didn't really add much ![]() You'd be amazed at the ammount of work I'll do to save a hundred bucks... much more work than you could actually pay me a hundred bucks to do
#8
But again, I'm getting old and I don't have as much time for this kind of projects as I used to have. Even if it can be fun to spend a day cleaning and inspecting grungy parts, and then decide what to reuse, it's not something I can do anymore When I started working on my latest project, I checked the prices with different parts stores, and I could probably have saved maybe $150 by doing what you did. However, I really wanted a new booster and prop valve, and the nice Delco-Moraine replica booster I got with my kit was what made the decide to go that route. Having all new parts, and knowing that I don't have to pull something off right after installing and trying it is worth a lot to me.But yes, you can save money, if you invest your own time instead. Might also add that you also need more experience to do it this way, especially if you can't find a complete kit. Puzzling parts together can be... well, puzzling
#9
Thanks. You Helped Me Decide On What Kit To Buy. I Was Looking At This Kit On E-bay. I Was Trying To Find Someone That Had Used This Kit To See If It Was A Good One.was The Power Booster Just Like The Original One? Thanks Again For Posting This Kit. I Will Buy One Real So And Install It.thanks Again John
#10
Are the calipers single pistons? I'd love to save money to, but, when it comes to the calipers, I can't help but think of forking out the extra cash for some dual piston calipers
I'm assuming the rotors are "normal," meaning, they're not slotted, etc. Just curious Thanks! |
#11
Yes, single piston and standard rotors. By the way, if you have 14in wheels you'll need to buy15's, I found out the hard way. I'm SLOW! But the good news is that I called the dealer and they are refunding half of my shipping because they felt sorry for me because I didn't know. Bad news is I need new wheels and don't have very much money left for my project!
#12
Yea i bought front dics brakes too from Matts Classic Bowties. Really cheap and they work really good. I they work 10 times better then the factory disc brakes there putting on cars now
#13
http://pg.photos.yahoo.com/ph/bbaker...bum?.dir=/6357 |
#14
Where on eBay?????
#15
Freddy, got to the e-Bay Auto parts section, do a search on "67 Chevelle".
If you sort on expensive to cheapest, you'll see "Whitemanfords" kits at the top of the list. I've talked with him and Olle actually used his kit. Best price around and everything was included. Look under the product evaluation section of this site to see Olle's report on the kit.
Herb Sr '67 Coupe (frame-off) 489BB/M20/3.73 Eaton posi http://www.chevelles.com/showroom/data/500/medium/Ext08.JPG .com |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| inexpensive conversion kit! | hischildbrian | Brake Conversions | 14 | Aug 30th, 05 8:59 PM |
| Cowl kit | Chevy 70 SS vert | Chevelle Tech | 0 | Aug 24th, 05 12:39 AM |
| HEI Conversion Kit | tmino | Engine | 0 | Aug 8th, 05 11:19 AM |
| 4 Door Power Window Kit on Ebay | Brad | Chevelle Tech | 3 | May 18th, 05 11:04 AM |
| Installing electronic ignitions conversion kit ?'s | james a larson | Electrical & Wiring | 0 | May 15th, 05 7:56 PM |
