Brake Conversions Tech info on converting from drum to disc
Old Aug 30th, 05, 9:23 PM
540cutlaSS 540cutlaSS is offline
Default C5 Rear Brake Mod
Some have expressed an interest in the C5 rear brakes. This is what I did.
I traced the outline of the backing plate, so if anyone needs a copy let me know. (You pay for the stamp)
This set up does not allow for a parking brake, so if you need one I would use the Camaro/Trans am brakes.
You will need to fab up the hard lines so they will attach to the calliper. I looped my line to take up some slack. I used Aeroquip ends. You will need 2 Aeroquip adapters that will go between the hard line and the flex line and 2 Aeroquip 10mm Banjo X whatever size flex line you are using. #3 or#4??
Sorry I dont have the #3 part #'s (thats what I used). The #4 adapters are
FCM2937 this is the 3/8-24 to inverted flare. It would go between the hard line and flex line.
FCM2948 is the 10mm banjo X #4. It will bolt to the calliper and the other end of the flex line will attach to it.
I know Im missing alot of info, so ask away. I can also take more detailed pictures as these were taken before the job was complete.
NCOA Member # 14002
Life is hard, it's harder if you are stupid. (John Wayne)
OO SS OO
  #2
Old Aug 30th, 05, 10:25 PM
sinned sinned is offline
Dennis
Default Re: C5 Rear Brake Mod
The really easy way to do the rear swap is to just buy everything from the backing plate out from an LSX series Camaro/Firebird and bolt it all on. No fab work, no fuss. I've seen the whole packages go on ebay for about 200-300.
On the fronts, calipers are only 150/ea brand new so paying over 200/pair on ebay is just silly. Rotors are 30/ea brand new at any Napa store, I wouldn't even think about buying them ebay....shipping would cost more than new rotors. I don't remember exactly how much I have wrapped in mine but the Wilwood setup is going to be cheaper than used C5 parts were.
Dennis
Looking for a replacement-
Old Aug 31st, 05, 12:05 AM
I can't argue with that. This is just one more option that some may like to do. There really is'int any mods using C5's it was a direct bolt on also. I did loop the original brake line though as it was to long.
I Have about $1200 in the brakes front and rear. It is all brand new GM not import stuff like Napa's rotors MIGHT be? not sure about that.
NCOA Member # 14002
OO SS OO
Old Sep 1st, 05, 6:11 PM
webfoot webfoot is offline
Team Member
Jeremy
The NAPA durastops (?) I got for my 02 monte carlo had a big fat "made in china" sticker on the bag.
Running in place gets you nowhere fast.
- JL Clark
70 Chevelle
383, AFR heads, voodoo hyd roller.
68 GTO 'vert factory M-21, 1 of 3,974
71 K-20 3/4 ton 4x4, 4 speed.
Old Sep 1st, 05, 10:27 PM
Dennis
The NAPA rotors I buy (about a dozen set a week) all say Canada on them. BTW, might want to check that GM=made in U.S.A. theory, most of it is made in Mexico.
Dennis
  #6
Old Sep 6th, 05, 9:28 PM
rbeckman rbeckman is offline
Team Member
Ric
Send a message via MSN to rbeckman
Red face Re: C5 Rear Brake Mod
I work for TRW after market and all of our rotors are made in Ohio and Candada. We sell them to DANA and Federal Mogul who market them with there brands. I know for a fact that they sell to Autozone and NAPA.
Ric Beckman
69 Chevelle SS 396 4 speed.
True SS, Canadian built
Team Chevelle Member #2998
MY CAR
http://www.cardomain.com/ride/2094332
You may not post new threads
You may not post replies
Similar Threads
Disc Brake Upgrades--Jury Pool Statements 2 Ike Brakes, Suspension & Steering 3 Dec 26th, 07 1:15 PM
Mounting rear brake calipers Rich-L79 Brakes, Suspension & Steering 3 Jul 5th, 04 10:41 PM
Rear Disc Brake QUestion jerry396ss Brakes, Suspension & Steering 2 Dec 1st, 03 1:06 PM
Rear brake adjustment MonteMan454 Brakes, Suspension & Steering 3 Nov 26th, 03 4:01 PM
GM replacement rear parking brake cables michael j Brakes, Suspension & Steering 4 Jul 30th, 03 9:56 PM
