Starting an engine that hasn't been started for a while - Chevelle Tech
Auto Insurance
Chevelle Tech General Tech Area
Please try and post in specific forums
Old Aug 17th, 05, 5:17 PM
OUChevelleSS OUChevelleSS is offline
Send a message via AIM to OUChevelleSS
Default Starting an engine that hasn't been started for a while
My engine hasn't been started in five weeks, but it ran fine when I parked it. I just never had to take it anywhere.
I'm trying to get it ready to move up to school on Friday (well, that was my goal), and I found I had to replace basically my whole charging system.
I know its hard to start engines that have sat a while, but this one just isn't doing too well. I've tried giving it a few pumps of gas and starting, tried just cranking it regularly, tried starting it like it was flooded, holding it open a little bit, etc.
Any tips on how I should do this? I don't think anything is wrong with it, just not firing up. Maybe I should spray some starter fluid down there or something? Thanks..
Taylor
'71 SS 350, Black w/ white stripes, now a '71 SS 454! Brodix Race Rite heads w/CNC, SRP pistons, ~10.2:1CR, 402A3LUN Solid cam, Edelbrock Performer RPM intake, Holley 850cfm double pumper, Tremec TKO-600 and a 4.11 posi 12-bolt rear.
Old Aug 17th, 05, 5:44 PM
Buzzbomb Buzzbomb is offline
Roland
Default Re: Starting an engine that hasn't been started for a while
Start it like you normally do! Five weeks is not long at all. Maybe your gas is bad, but after 5 weeks, I just can't see it. Gas can't be that much CRAP nowadays.
The only hard thing about starting an engine that has sat is cranking it long enough for oil pressure and to fill the float bowls. That is probably your problem. Crank it for 20-30 seconds or so, then start as normal.
"The man who lets a leader prescribe his course is a wreck being towed to the scrap heap."
-Ayn Rand
Old Aug 17th, 05, 11:11 PM
136679ss 136679ss is offline
Jason
Send a message via Yahoo to 136679ss
uh, start and go, five weeks is just like you drove it yesterday. In the winter I only start the cars in the garage once a month let run five minutes. The 327 engine I pulled from my project was seized, had not run in 8+ years had ****e loads of stuff inside.....1. changed oil, 2. poured mystery oil in each cylinder 3. turned by hand after working the crank for 2 days and retapping snapped off harmonic bolt. 4. reprimed oil pump with ground down distributor 5. hooked up parts and 12 vdc. 6. ignition after fresh gas. barely even a puff of smoke, then I tore it completely apart and gave it away. seriously just start and go. JN
TC#2693
Aces# 7467
Heart of Dixie CC
Old Aug 18th, 05, 1:33 AM
Chris R Chris R is offline
Just get in and start it normally, it probably wont start normallly because it has sat that long but you wont hurt anything. Thats what I do when it sits all winter. It will take some extra cranking.
Chris.
When the Boogeyman goes to bed, he checks the closet for Chuck Norris.
If it aint broke, just give me a minute.
Old Aug 18th, 05, 3:04 AM
undee70ss undee70ss is offline
Greg
Send a message via AIM to undee70ss
As I said in the electrical forum, if you want it to start right away after the car has sat for a while, fill the bowls first with a squirt bottle. If you are having trouble starting it the plugs may be fouled.
Greg U
MY 70SS
Chevelle Tech > Information Exchange > Chevelle Tech      Current Topic: Starting an engine that hasn't been started for a while
Location
*REQUIRED*
Insurance
First Name
Human Verification
Similar Threads
Starting Engine before putting Body on ??? 71307chevelle 2000 14 Aug 21st, 05 1:12 PM
Re-assembled engine Started today-Update Flye Engine 6 Dec 24th, 04 6:47 AM
trouble starting my engine steve61877 Engine 2 Oct 19th, 04 5:50 AM
Engine starting, idleing, troubleshooting PT. 2 feedphillipnow Performance 36 Nov 24th, 03 3:43 PM
Slow starting when engine is HOT. Bud70 Engine 5 Feb 19th, 03 2:00 PM
