are these heads any good? 336781 oval port - Chevelle Tech
Auto Insurance
Old Aug 17th, 05, 2:28 PM
john6066 john6066 is offline
Team Member
Question are these heads any good? 336781 oval port
i have a chance to buy a set of these cast iron heads. # 336781 made between 1973 and 85. there suppose to be 113.0 cc. these are bare heads that were supposedly magnafluxed and found to be in good shape. anyone know valve sizes, and weather they'ed be good street performance heads when equiped with 2.25 intakes and 1.88 exhuast (if they would fit) valves. are these open ports?
i can get them pretty cheap, but i've learned cheap isn't always a good thing.
thanks john
Bad Papa's '69 Chevelle
Old Aug 17th, 05, 2:59 PM
mr 4 speed mr 4 speed is offline
Default Re: are these heads any good? 336781 oval port
John,781's are some od the best open chamber BBC heads out there.
They will measure bigger than 113 cc (more like 118-120) unless they have been previously milled.
2.06/1.72 is the stock size
Old Aug 17th, 05, 4:18 PM
Team Member
thanks chris. i think there may be too many variables. i'll probably buy some new heads. if i ad the shipping and replacement valves with machining i'm within a couple hundred.
thanks john
ps if interested they're in ebay for cheaps.
Old Aug 17th, 05, 9:15 PM
pdq67 pdq67 is offline
Guest
Paul
Smile Re: are these heads any good? 336781 oval port
John,
I have NO idea what you want to build or to what power level, but it has been proven that just a GOOD bowl-blend and "dingle-berry" casting flash port clean up on a set of 2.06"/1.72" valve BB large oval port heads really wakes them up!!
AND only after adding big valves AND then doing the same port and bowl work to them will bigger valves help make more power!!
I mention this b/c this is my "poor-man's shade-tree" way of doing things!!
pdq67
Old Aug 17th, 05, 11:09 PM
Team Member
Talking Re: are these heads any good? 336781 oval port
thanks i'll look up pricing on new valves and machine work. not sure there would be much difference. i like the way you put that though.
  #6
Old Aug 17th, 05, 11:57 PM
ChevelleRob ChevelleRob is offline
Send a message via AIM to ChevelleRob
The 781 or 049 are the best ovals you can get. if you are sure about the condition and they don't need any seats replaced thay are great.
"..a true hotrodder wouldn't be content untill he had created a car so violent, so totally sick that the act of dropping the hammer would result in instant death. Anything less results in the need to go faster." Tony DeFeo
NPB 9.55 at 138
  #7
Old Aug 18th, 05, 10:20 AM
justkyle justkyle is offline
Kyle
Send a message via Yahoo to justkyle
I am in the process of having my 781's worked over as we speak. After cutting in the hardened seats with 2.19/1.88 stainless steel valves and some minor port work. I will be into the heads approximately $750. That is a LOT less expensive than buying a new set of aluminum heads.
Kyle
69SS (probable) project. 496, TH400
70 malibu race car
How to build a proper TFH
  #8
Old Aug 18th, 05, 12:49 PM
Team Member
i was planning on buying "iron eagle" cast iron heads. they can be had for $1460 per pair. 2.30 intake and 1.88 exh. max .690 lift. thats with 345cc intake ports and 119cc combustion chambers.
john
  #9
Old Aug 18th, 05, 1:11 PM
Mike Feudo Mike Feudo is offline
You don't need 345cc intake runners unless you have a 632 or something close.
  #10
Old Aug 18th, 05, 10:25 PM
Team Member
Question Re: are these heads any good? 336781 oval port
they also have 308 intake runners? what application would work best.
  #11
Old Aug 18th, 05, 10:59 PM
ddeennis ddeennis is offline
Dennis
for a complete rebuild of my 049 heads it cost me 315 bucks total. that was decked. valves reground 2.06 and 1.72 with a few new replacement thrown in the mix. seats done with 3 angle valve job and new guide liners installed with a set of "h.o." 427 springs and new retainers and keepers and umbrella seals.
this was from long's machine shop here in kansas.
mike stark from cfm said the 049 heads with bigger valves and pocket porting and casting clean up will flow about 300 cfm and support 550 hp easy.im using these heads on my 454 build up im doing now. port them and put bigger valves in them. so i guess i will spend alittle more money at longs shop to put the bigger valves in which is 100 bucks to cut them open for them. new valves can be had from competition products for under 100 bucks new.
http://s50.photobucket.com/albums/f320/ddeennis/
pics of projects and whatever.
  #12
Old Aug 18th, 05, 11:13 PM
ak69 ak69 is offline
I am liking my 049's! "There so fine my OH Four Nines my OOOH FUR NINES!!!!!" Them there heads is so good the damn Beach Boys wrote a song about them!!!!
Craig
69 Malibu BSE 454/TH400
Best pass 7/4/06
1.4882 60Ft
6.8929 1/8 ET
99.35 1/8 MPH
10.87 1/4 ET
121.69 1/4 MPH
Best 60' 1.46
  #13
Old Feb 18th, 12, 1:33 PM
gsx1 gsx1 is offline
Dave
Why is it i find sites that id the 336781 heads at 133 cc chambers?
  #14
Old Feb 18th, 12, 3:33 PM
Mike Mike is offline
Dave ,did you notice the date of this thread?
Where are you seeing 133?
I see 113 to 118.
You may not post new threads
You may not post replies
Similar Threads
Which Oval Port BBC heads to use for 489 Build Up TW Performance 8 Apr 22nd, 05 7:27 AM
Edelbrock Perf. Rpm Oval Port Heads LAUGHING RAT Performance 9 Apr 1st, 05 2:09 AM
Big Block Oval Port Heads Questions shrado Top Tech 11 May 8th, 00 9:14 PM
Q&D cost analysis of converting to Vortec heads Pat Kelley 1999 -- 6 Apr 17th, 99 7:55 PM
