Performance Our High Performance area
Old Nov 5th, 09, 12:27 AM
smallblock413 smallblock413 is offline
reggie
Default drag radial
anyone here have succes in getting the hoosier drag radials to hook..275/60x15??
if it rolls im rocking itif it has a button im spraying itif it hooks im outta here
Old Nov 5th, 09, 1:57 AM
BillyGman BillyGman is offline
Default Re: drag radial
I'm pretty sure that Bob West has, with multiple 1.3 second 60 foot times. If he doesn't chime in soon, you might want to send him a PM to inquire. But I'm sure that Bob isn't the only one who has.
70 Chevelle SS clone
under construction w/new pump gas 632 C.I. engine
full manual TH400 w/transbrake
competition 10" torque converter
Strange/Dana 60 rear
Detroit Locker &
35 spline axles along w/3.73 gears
daily driver:
2003 S/Ced Mercury Marauder
12.0 ET's @114 MPH on pump gas
Old Nov 5th, 09, 3:22 AM
FourEightyNine FourEightyNine is offline
Brian
Send a message via AIM to FourEightyNine
Yeah pretty sure Bob had good success with them but I think he said they didnt last too long compared to others he has tried.
9.79@135mph, 1.341 60ft in 3000ft of air.
http://s67.photobucket.com/albums/h2...nsept11025.flv
Old Nov 5th, 09, 4:56 AM
jaywill jaywill is offline
Petie
check this out!!!
http://www.chevelles.com/forums/show...ot+drag+radial
496 , GM"215" 101cc.. COMP 5-angle VALVE JOB,...GASKET MATCHED...,2.19/1.88 vavles
COMP X286R SR 693/661 LIFT, 1.8 & 1.7 ALUM.ROCKERS...VICTOR W/ 1050 DOM
350/3800 STALL /4.10 GEARS
275 M/T DR'S 3700lbs "pump gas"
TO-DATE.. N/A
BEST ET...7.14 60FT 1.58 .330 4.55...NO HIGH GEAR
BEST MPH....99.6 60FT 1.77 .330 4.78
Old Nov 5th, 09, 5:00 AM
Petie
TO-DATE.. N/A
Old Nov 5th, 09, 7:29 AM
Bob West Bob West is offline
Green Weenie
Send a message via AIM to Bob West
I like the Hoosier drag radials, they weigh the same as my slicks, they hook as good as my radial slicks, but they just dont last like I think they should The MT's on the car now are HEAVY, costing me a tenth in e.t. in the 1/8th mile.
*** 72 Malibu ***
http://smg.photobucket.com/albums/v2...t=5c4f344c.flv
Nov.'08-9.988@131.62 , best 60ft to date - 1.319-
http://www.dragtimes.com/1972-Chevro...ures-5251.html
Old Nov 5th, 09, 10:31 AM
reggie
tires are almost new how long of a burnout is needed...i know every setup not the same...just your experience...tire pressure?? thanks
Old Nov 5th, 09, 1:58 PM
Rowdy Rowdy is offline
Vegas TC Ambassador
I found most every drag radial to work best between 15-16.5 psi. As far as hooking with any consistency, it depends on the track, especially what tires other racers are using, as much as anything. If everybody is running street tires and not laying down decent rubber, then forget about it. That's my experience, and I run soft 60's, I have to imagine that Bob is even more susceptible to spinning on a crappy track. The MT's are quite a bit heavier than the Hoosier's.
Rowdy
'66 Malibu
540cid 753.8hp 673.4tq
COAN Extreme Street Th400/10"
3.55 12 bolt Auburn posi
DAILY DRIVER
BEST: 60' 1.59 / 1/4 10.591 / MPH 129.70
3770 lbs, 91 Octane, M/T ET Street Radials
http://www.youtube.com/watch?v=88c6MLbQvEI
http://www.youtube.com/watch?v=rTd2O5fZ2lU&NR=1
Old Nov 5th, 09, 2:58 PM
Perhaps you should explain a little bit more about your vehicle combo, what 60' times you're obtaining, and what other tires you have tried (if any). Because maybe your traction problems aren't really due to your tire choice at all. What about the rest of your vehicle? ET's? Front and rear suspension? vehicle weight?
Detroit Locker &
daily driver:
Old Nov 5th, 09, 9:20 PM
Green Weenie
I set the tire pressure at 18psi Friday when I got to Tulsa last weekend, ran Fri,Sat and Sunday and 60fts were 1.360-1.371 in 12 of 13 passes. One pass I backed off the burnout and it spun hard (posted every pass in my CDRA post). I go from 2nd to 3rd til I see smoke in the rearview then let off the brake and power up to the line.
*** 72 Malibu ***
Old Nov 5th, 09, 9:37 PM
40Coupe 40Coupe is online now
Mine on 275's
'67 Camaro
9" tires
3525 lbs
1.311
6.13 @ 110.93
9.68 @ 137.82
Videos
http://www.youtube.com/watch?v=7KLaWp0RZoM
http://www.youtube.com/watch?v=TrLxwZbd8A8
Old Nov 5th, 09, 9:55 PM
o6r1man o6r1man is offline
Chris
No matter how many times I see this pic I still dont get tired of it.
I like anything fast enough to do something stupid with.
1972 El Camino
496 Dart Pro 1 325
Prosystems 1000 hp
ATI 8" treemaster MRT
3" Jegs X-pipe 18" long Dynomax ultra flows
http://s278.photobucket.com/albums/k...urrent=005.flv
11.22 @119 spinning or as Bob would say "going shopping for christmas trees!"
  #13
Old Nov 5th, 09, 9:58 PM
Green Weenie
Notice that there is no starter in the picture? He ran off to the side of the track just to take that picture
*** 72 Malibu ***
  #14
Old Nov 5th, 09, 10:17 PM
Chris
I was there that day watching in ahhhhhhhhhhhhhh!
I had to pick my buddys Jaw off the ground when he seen the two "street cars with exhaust hooked up and skinny slicks leave like that.
1972 El Camino
496 Dart Pro 1 325
Prosystems 1000 hp
  #15
Old Nov 5th, 09, 10:18 PM
Petie
x 2
TO-DATE.. N/A
