gear oil for my Muncie - Chevelle Tech
Transmission & Driveline Transmissions and Differentials
Old May 10th, 12, 8:10 PM
forever young forever young is online now
Roland
Send a message via AIM to forever young
Default gear oil for my Muncie
I have a Muncie for about 3 years in my garage. I bought it and I was told it was completely rebuilt. What I need to know is if there is a way to remove the cover to check the oil level, where should the oil be if full, and what type of oil should be in there if I am low? Also what sealant should go on to reseal the sideplate? Is there a gasket instead of the permatex gasket material? I want to ensure that it is full before it gets installed.
Thanks, Roland
"some people spend their entire life trying to make a difference, US MARINES don't have that problem". Ronald Reagan Semper Fi
Old May 10th, 12, 9:19 PM
DMeeks DMeeks is offline
Dave
Default Re: gear oil for my Muncie
There is a plug in the side of the case, take out the plug and that is where the level of the fluid is supposed to be at the bottom of the hole, make sure the transmission is sitting level. If you need to add fluid it has to be GL-4 do not put GL-5 in it, it will ruin the syncros.
If you think you can, or if you think you can't, either way you are right!!
Old May 11th, 12, 7:42 AM
novadude novadude is offline
It's better to fill it once it is in the car, so you don't get lube running out of the tailshaft. Also, that lets you use the fill plug to make sure it is at the proper level when it is mounted in the correct position.
Old May 11th, 12, 9:17 AM
Auto Gear Auto Gear is offline
Nate
Go to Napa and get 1QT of Sta-Lube GL4 (P/N SL24229). Drain your gearbox, reload with the new stuff. Life is good
Old May 11th, 12, 11:49 AM
MEJ1990TM MEJ1990TM is offline
Michael
Send a message via AIM to MEJ1990TM
One quart won't fill it. It usually takes around 1.5 or so.
1966 Charger (383, 727 Torqueflight)
1970 SS 454 Chevelle (LS5+2, M22, 3.31 12 bolt)
1971 Malibu (350, M22, 3.31 12 Bolt)
I'm looking for a girl with a car, and a house..........with cable.
http://s160.photobucket.com/albums/t164/MEJ1990TM
Old May 11th, 12, 7:46 PM
XCELERATIONRULES XCELERATIONRULES is offline
Mike
Make sure you use GL-4....only.
Special order in most places.
Do not use gl5..it does not have the lubricating properties needed.
1971 Pontiac Lemans Olds 350
1973 Buick Centurion Ragtop 455
1974 Chevy El Camino Classic 350
1976 Pontiac Trans Am 455
1997 Honda Valkyrie 6 cylinders,6 carbs.
Old May 11th, 12, 9:06 PM
I was at Napa today, and they had several gallons of Sta-lube GL4 on the shelf for $31 ea.
Old May 12th, 12, 5:22 AM
Michael
Here we go again........
Are you freaking kidding me!?
Old May 13th, 12, 10:08 AM
Kidding you?
$31 / gallon makes it no more expensive than any quart of 80W-90 lube, so why not use it?
I think I paid $8 / quart through Amazon with free shipping (I added other stuff to the cart to get me above $25).
Old May 13th, 12, 3:56 PM
Michael
Kidding you?
Oops, my bad. I was thinking $31 a quart, not gallon. That's a good price for a gallon. Never mind me.
Old May 13th, 12, 9:36 PM
SWHEATON SWHEATON is offline
but closer
Agree'd on the Sta-Lube ,but the Muncie takes closer to 1.5qts gear oil to fill when completely empty.
Scott
SCOTT
1969 CHEVELLE SS396/4SPD/M20/12BOLT/3:31'S
ORIGINAL #'S MATCH/OWNED SINCE 1978.
1977 KAWASAKI KZ1000 (ORIGINAL OWNER)
1976 KAWASAKI KZ900
2006 YAMAHA 1700 ROADSTAR SILVERADO
