Headlight upgrade moves? - Chevelle Tech
Chevelle Tech General Tech Area
Please try and post in specific forums
Old Apr 26th, 12, 9:51 PM
geo's 66 geo's 66 is offline
George
Default Headlight upgrade moves?
Guys, planning on more night driving in the 66.. The headlights work correctly but still are weak... What ideas have you guys used to get brighter/ safer lights???
Old Apr 26th, 12, 9:58 PM
bln bln is online now
Dave
Default Re: Headlight upgrade moves?
george here is some good info http://www.madelectrical.com/electri...adlights.shtml
My Chevelle convertible My65
67
Old Apr 26th, 12, 10:02 PM
SSR71 SSR71 is offline
Kevin
Originally Posted by bln View Post
1972 El Camino Custom
2005 SSR 6-speed
1999 Silverado
Old Apr 27th, 12, 5:36 AM
magicrat56 magicrat56 is offline
joe
Send a message via Yahoo to magicrat56
did the upgrade last year using Marks kit,excellent results and Mark is one hell of a nice guy to deal with.
Old Apr 27th, 12, 11:40 AM
wihaltom wihaltom is offline
Weldon
I do instrument wiring by trade so I built my own relay system, which is really not that much of an accomplishment. I was amazed at how much brighter the headlights were, especially on high beam. The relays unloaded the instrument wiring system dramatically.
Weldon
64 El Camino
http://i613.photobucket.com/albums/t...y030506a-1.jpg
67 Mercury Cougar
http://s613.photobucket.com/albums/t...om/Cougar1.jpg
Team Chevelle #5157
Old Apr 27th, 12, 12:30 PM
Schurkey Schurkey is offline
Gold Founding Member
Adding relays and plain ol' ordinary halogen sealed-beams beats hell out of installing some Chinese-junk "HID" system that is neither DOT-legal nor particularly effective except to blind oncoming traffic.
Did you SEARCH BEFORE POSTING a new thread?
Did you post in the correct forum?
Old Apr 27th, 12, 12:49 PM
novaderrik novaderrik is online now
Derrick
swap in a modern CS style altnernator and run a big wire directly from the back of the alternator to the battery... this should get you up to almost 14 volts at the lights if the rest of your wiring is in good shape.
"America can't collapse. We're as powerful as ancient Rome"
Homer Simpson
Old Apr 27th, 12, 1:00 PM
MM54 MM54 is offline
Matt
Also, some electrical contact cleaner on the terminals never hurts. Even with bulbs installed the contacts can still corrode and dim the lights.
Just because I'm new to this doesn't mean I can't do it. Most of my life has been learn-by-doing and my car is no exception. Not looking for restoration, just preservation.
'71 4-Door
Daily Driver
307, Powerglide
Factory A/C (Needs Fixed)
~100,000 Original Miles
Never Restored
Second Owner
Old Apr 27th, 12, 1:26 PM
Robinls5 Robinls5 is online now
Bob
I did the relay conversion on my 70 driver. ( P.S. NO Chevelle owner is dumber than me ) Dash lights are much brighter, Using Halogen headlight bulbs....
No night driving issues whatsoever! Just added the relays NOTHING ELSE, Using the Org. 70- 63 Amp. Alt.
Mounted the two relays behind the washer bottle on my 70 ( makes them hard to see). Best and very cheeeeeep upgrade for a Chevelle.
I am a guy that wants everything to look STOCK.
P.S. I hid the giant hot wire from the batt. to relays, Inside the core support with the Org. wiring. I also slid the hot wire inside a long piece of vacuum hose to protect it. Reason: A large hot wire that shorts out from the Batt. Would require at least TWO firetrucks to put the fire out.
Did this four years ago. I drive the Wagon a lot at night.
Bob
70 SS 454 El Camino 07 AACA Grand National Winner
70 SS 454 Station Wagon - Driver
Old Apr 27th, 12, 1:32 PM
While I don't use the CS-style alternator, I do wire the relay to the alternator output terminal via ~5 inches of fusible link (16 gauge) and the remaining wire 12 gauge until it splices into the (verified good) OEM headlight harness.
As long as the wire from alternator to relay to headlights has no corroded sections, it will provide alternator voltage or very close to alternator voltage to the headlights; whatever the alternator is regulated at is what the headlights should receive. This is typically 14+ volts.
Old Apr 28th, 12, 12:43 PM
Coppertop Coppertop is offline
Gold Member
Joe
http://prepostmodern.com/hd/
-If you don't stand for something, you'll fall for anything.
