Problem with CPP upper arms - Chevelle Tech
Classic Performance Products Classic Performance Products
Old Oct 16th, 11, 11:37 PM
nikwho nikwho is offline
Nik
Default Problem with CPP upper arms
Any one else experience this? The passenger side arm fits OK. Drivers side, not so much! First off, I would like to say that I love the arms! They are super beefy and look great! Price is great, too! On the passenger side, the step on the huge cross shaft hits the mounting surface on the frame at each side so it wont sit flush against the mounting surface. I'm sure it wont be a problem as it will probably be shimmed when it gets aligned. However, on the drivers side, at the rear of the cross shaft, the CPP arm conflicts with the frame surface and will not let the arm travel all the way down. Alignment shims will not fix this. Any thoughts? Any representative from Classic Performance Products on this board? I've got an email in to them and I trust that they will have a fix for me.
NIK
Click image for larger version
ID:	45971   Click image for larger version
Old Oct 16th, 11, 11:56 PM
Nik
Default Re: Problem with CPP upper arms
Whoops! I didn't realize that CPP had their own page. Thanks!
NIK
Old Oct 17th, 11, 1:44 PM
Mike Mike is offline
Not sure it'll help much moving it here as they don't seem to show up often.
Old Oct 18th, 11, 12:54 PM
Nik
Well, I spoke with a guy there in tech support. He told me that I need to grind my frame down until the arm fits. Now, with that said, my car is a Pontiac GTO, not a chevelle. However I thought that the frames were identical. apparently NOT! So, I guess that I can live with modifying the frame. Too bad I JUST painted it. I will have to grind it down to make everything fit, then take it back apart and repaint that part of the frame... So, I can live with that, but I noticed that the arm had a spot that didn't get powder coated. So, now I have to send the arm back to get a replacement! really? Its like these arms just don't want to be on my car!
Old Oct 18th, 11, 1:19 PM
CPPAaron CPPAaron is offline
Good Morning,
I'm Aaron @ CPP I have been emailing you back and forth.
That is correct on some 64-67 Non-chevelle A-bodies we see this slight interference from time to time. for the thousands of control arms we have sold I have only had this come up 3 times (including this time) and each time it has been on a 64-67 GTO. The upper a-arm mount must be just a tad wider. So yes, I did recommend trimming this down a bit.
As for the powdercoat we appologize and I emailed you directly for your info so we can send a pick up label to get this exchanged... Must have been the last of the silver in that powdercoating run... Sorry about that!
Old Oct 18th, 11, 1:34 PM
Nik
No problem! Thank you for promptly taking care of this. I was only frustrated about hearing of needed frame mods because I just painted the frame. My luck always seems to go this way. I really like the quality and look of the arm! And I understand fitment being off, being that my car isn't a chevelle! They look super tough and when a little more money frees up, I will look into buying the matching lower arms. Thanks Aaron!
Old Oct 18th, 11, 1:38 PM
Nik
I would like to thank Aaron and CPP for their wonderful customer service! We came to a quick solution and the product is awesome!
Nik
