| Chevelle Tech Current Topic: Another Timing Question! | ||
| Register | Photo Ads | Blogs | FAQ | User List | Social Groups | Calendar | Chat | Search | Today's Posts | Mark Forums Read |
| Engine General Engine Discussion |
My engine runs great, I'm just wondering if I should change anything. My total timing @3000 rpm is 36 deg but the initial comes in at 21 deg. Most of what I read states around 18 and 36. Should I do anything to bring the initial down or does this sound normal? I'm also running a 10 deg advance canister and the total with it hooked up is just under 50.
66 Chevelle awaiting the 454 build. 95 Z28 Convertible at a new home now, but still one of my children. |
| Sponsored Links | |
Advertisement | |
If that's the case, you're fine imo but I mainly run locked out timing so what do I know. Have you experimented with more and less total?
Tim
Have you experimented with more and less total?[/QUOTE]
Yes, and it's in the sweet spot.
I'd leave it, and let it be sweet.
Tim
If its running fine with no ping leave it alone.
But if you checked base timing with idle any higher then approx 600-650rpm then the mech adv is likely partially activated adding a fewdeg timing to the base making you think it 21 deg when it not. So if you didnt chk base timing with ildelowered to 600-650 rpm max with vac adv unhooked & plugged too then lower idle 7 recheck basetiming. But again,a fair amount of people run 20-21 deg base timing if thats where your motors truely at and 36-38 is generally where many total end up too. 3k rpm is the maxi would have total comming ,i generally like to see the total all in by 2600-2800rpm max,some people have it comming earlier at 2500rpms . Scott
SCOTT 1969 CHEVELLE SS396/4SPD/M20/12BOLT/3:31'S ORIGINAL #'S MATCH/OWNED SINCE 1978. 1977 KAWASAKI KZ1000 (ORIGINAL OWNER) 1976 KAWASAKI KZ900 2006 YAMAHA 1700 ROADSTAR SILVERADO |
I ran the idle screw down all the way until it was barely running and it stayed right at 21. No pinging. Very smooth idle quality.
I would be concerned about the total number. The total is what is what is goin got make it ping under hard acceleration. I would be more concerned if your initial was too low. Hell, in mine I don't even look at initial. I put springs in to make mine advance as quickly as possible, becasue I wanted to have as much as I could get at idle.
Ray http://www.dragtimes.com/1970-Chevro...ures-7479.html Best pass so far 9.089 at 146.78, 1.266 60'. http://s30.photobucket.com/albums/c3...rrent=Nova.jpg |
Leave it where it is. Per your own words, it's in the sweet spot. Sure, lots of guys run a little less, some run what you have, some guys run fully locked out timing.
Zeke 67 Chevelle 64 Chevelle 69 AMX TC# 3094 ACES# 7297 |
| Display Modes | |
