Engine General Engine Discussion
Old Jan 15th, 10, 1:02 PM
keithss keithss is offline
keith
Default Engine breather
I may have made a big mistake. I have a 70 "396" that I put the correct chrome valve covers on. I blocked the "breather" line going to the air cleaner since it did not have a connector. After running for awhile, I began smoking from both banks and also see some oil blowing out the rear bottom of motor. Am I screwed ?
Old Jan 15th, 10, 2:04 PM
steve70malibu steve70malibu is offline
Steve G.
Default Re: Engine breather
It probably blew oil into the pcv valve which will go through the carb and make it smoke, the oil leak sounds like the pressure pushed oil out some gaskets. Just clean out the pcv line and valve then clean the engine. Unplug the breather then try running it again and see if it clears up.
Steve
1970 Malibu 331 A/T 3.42 posi
1972 Buick GSX 455
