Pro Touring Todays performance with classic style
Old Nov 2nd, 09, 10:50 PM
66promalibu 66promalibu is offline
Tyler
Default SPC/AFX Lower Ball Joint
Hey guys. What do you make of this? Lower ball joint on SPC arm with AFX spindle. Ball joint comes through the spindle about 3/8 of an inch. I've tightened it about as much as I can without hitting it with an impact. Is it possible I have the wrong ball joint?
http://i849.photobucket.com/albums/a...BallJoint3.jpg
Old Nov 3rd, 09, 5:00 AM
mcmlxix mcmlxix is offline
Default Re: SPC/AFX Lower Ball Joint
Wrong ball joint or wrong taper on the spindle... talk to your vendor.... DO NOT put an impact wrench on it!
Rich --- accepting PayPal donations to Chevelle_1967@hotmail.com
Las Vegas
1967 Chevelle * Pro-Touring *
http://i70.photobucket.com/albums/i9...g?t=1232947887
LS376/480hp * T56 * AFX Spindles * SC&C * Varishock QS1 * Currie * Moser
Old Nov 3rd, 09, 1:13 PM
BB_Mike BB_Mike is offline
Yeah, just make the phone call. I error'ed in asking my question prematurily, even though it was an open ended question that I thought would serve to help others. I got my problems solved quicky - and now I cannot edit the initial post.
Click here for pictures of my 72 convertible and 71 chevelle.
72' 3820# convertible
BB402, Merlin heads, TH350, 3.23 posi 1/8th mile: 8.6 @86mph
71' coupe project:
goal: 150+MPH, 9s driven to and from track, 10" tire, 1000+HP
Build: 540cid, twin turbo, 4L80e, .... more to come....
Heart of Dixie Chevelle Club
Old Nov 3rd, 09, 2:57 PM
MikeMalibu MikeMalibu is offline
Mike
What was the answer BB_Mike?
Mike
My car
Old Nov 3rd, 09, 4:44 PM
Mine was about the upper ball joint and a stock (but old) GM spindle. My spindle was on the edge of being too loose up to, which caused it to butt ("bottom out") against the stepped portion of the howe BJ. Only because my taper was still good and the fit was snug, I was able to chamfer the upper spindle opening to prefent contact with the stepped portion of the aftemarket ball joint. After doing that the ball joint did not sit any further into the spindle as I could still see a gap between the spindle and the stepped portion of the BJ. I am happy with the outcome.
71' coupe project:
Old Nov 4th, 09, 10:33 PM
Teetoe_Jones Teetoe_Jones is offline
You have a B body lower taper in your AFX spindle. Are you using factory A body ball joints? If so that's the issue.
Tyler
