| Chevelle Tech Current Topic: Morel Lifter Lash | ||
| Performance Our High Performance area |
What's the concensus for setting the lash on AFR BBC heads?
I saw a posting awhile back from Cstraub saying @ 1 turn for lash. I set mine at 1/2 turn and after reading other people having noisy valvetrain so I'm gonna go back and set to 1 turn.
69 SS396 Camino (540 FAST EFI BBC) http://profile.imageshack.us/user/peetsjunkie/images Check out the latest stuff here! FS: Hotchkis A-arms New- $400 http://img440.imageshack.us/i/dsc0014g.jpg/ Edelbrock 60459 BBC Heads $1400 http://img42.imageshack.us/i/dsc0021do.jpg/ |
The stud is 20 threads per inch so 1 turn is only .050" and half is only .025" which could end up being noisey. I would go back and redo them at 1 turn or .050" preload.
70 Malibu (unnaturally aspirated) LS7 454 T400TB |
Jason,
go 3/4" to 1 full turn on BBC aluminum headed stuff. |
You answer the forum faster than your email....
thanks... Looking to light this beast soon..... stay tuned.
Well I had read your e-mail then got called away so when I saw the post I just fired off a response.
69 Chevelle SS "Walk Softly, But Carry A big Stick" My Cars Liberals--an example of what happens when the weak are allowed to survive. |
Morel or Crane hyd roller lifters, minimum 1 full turn preload. With alum heads ( and enough spring) you can run 1-1/4 turns.
'69 SS396 2006-2007 version :ZZ460"/T400/3.73/10" 3000 converter.......11.67 @ 117.34 2008 version : 469"/T400/3.73/10" 2200 converter..................not fast enough 2009 version : Cruising with the A/C running .........................11.47 @ 116.41 |
Depends on the head used and the quality of aluminum. Some grow more then others.
My AFR's grow .007. Heck, that's slightly more than an 1/8 of a turn lost just to expansion.
VINCE G. 69 CHEVELLE SS 509/AFR305/XR286/5SPD/3.90 |
How you like the 509/AFR combo? wicked?
My morels on BBC Brodix are 1 full turn and still noisy
Done a lot of research on hydraulic lifters (beyond basic BBC hot rodding). Info indicates hydraulic lifters are designed to be ran in the middle 1/3 of plunger travel. The Crane lifters we checked had .140" travel. Bottun line is mid point is .070 preload (hot). Mid 1/3 is .046" to .092" (cold). Adding in .006" expansion (alum heads) nets a setting from .052" - .098". Basically 1 full turn to 2 full turns on a 7/16"-20 stud. This debate will go one "forever". Bottum line, mine are set at one full turn right now. This is beating a dead horse - I am running Beehive springs and "absolutely" have not experienced valve float with either the .650 lift Comp cam that was in there prior or the .610 lift Crane in there now - and trust me, we have deliberately tried to find the limit. So, when I get a chance, these preload is going to get an added 1/2 turn to set it right in the middle of the plunger design (cold) which will net .064" preload hot on my motor. Can tell you I went from 1/2 turn (cold) to 1 full turn (cold) lifters got progressively quieter.
You need to do what you are comfortable with!
#13
When you guys are saying they are noisy, how noisey are they? Is it just on cold start up?
Jerry 65 Beaumont, 2 dr. coupe,406sb Afr's,Reed solid f.t., M22W, 3.73's Best time to date 12.37 @ 108mph 496 BB by spring!! http://www.chevelles.com/showroom/da...e_Rims_014.jpg |
#14
Not a BB, But my old combo I ran Morel's 1 1/4 turns on 3/8 studs. It was still noisy kind of like a solid cam sound.
My 67 Camaro 400 Dart Little "M" AFR210 Eliminators, Jesel shaft rockers, Comp Solid Roller/Isky Red Zones,Super Vic,Prosystems 847cfm-TKO600 5spd-Eaton 4:10 posi w/Strange Pro Race Axels Best E.T. June 6, 09 (11.96 @ 118.06) N/A New 400 SB Pic |
#15
Also I would like to add, which Morels. Street version or Pro Version. I am referring to the Pro version, the over $500 sets.
| Display Modes | |
