Heating & Cooling Heating, cooling and air conditioning
Old Nov 3rd, 09, 8:34 PM
Pro67Chevy Pro67Chevy is online now
Jim
Send a message via AIM to Pro67Chevy
Default need electric fan for 66-67 that fits in 3 1/2" gap
Looking for an OE type fan I can pull from a yard.
I was all set to go get a Taurus fan, but when I measured the distance from the radiator to the W/P pulley I only have about 3 ¾”!! I don’t know how everyone is getting these 5” fans in there. I even have the “short” water pump.
What are you 66-67 guys using for electric fans?
My core measures 20 x 18 x 3
Total radiator is 24 ½ x 18 x 3
Thanks,
Jim
Jim M.
467
th-400
12-bolt,4.10s
My 67 Chevelle Under Construction
"It's all in the smoke!"
Old Nov 3rd, 09, 8:46 PM
PCB67SS PCB67SS is online now
Bill
Default Re: need electric fan for 66-67 that fits in 3 1/2" gap
You could give Team Member Don a call for some advice and possible set up....I'm sure he has the cure.......
http://www.alumitechreproductions.com/58.html?sm=15943
Old Nov 3rd, 09, 9:10 PM
Jim
I will check him out.
I'm trying to stay with something I can pull from a yard. Hoping someone has a good fan for a tight fit.
Jim M.
467
th-400
12-bolt,4.10s
Old Nov 3rd, 09, 9:27 PM
Bill
Gotcha Jim.....I'm sorry I am not familiar with the whole electric fan thing so I cant offer any further suggestions.....But hopefully another member here can point you in the right direction......Good Luck
Old Nov 3rd, 09, 10:00 PM
eric13617 eric13617 is offline
Eric
I use a Perma-cool 16" and a homemade shroud. The fan is 3 3/4" deep and flows 2950cfm. @ 10.5 amps.
FWIW,I mounted the fan off center of the W/P. I could really care less how it looks. All I know is, it's functional.
Just a street car.
Old Nov 3rd, 09, 10:04 PM
Jebchevelle Jebchevelle is offline
Jeff
Thanks,
Jim
Jim
On my 66 I took out the grill and installed my fan on the outide I have a pusher A freind gave me. The fan came off a car he junked, I think it was a ford windstar van? its a single fan. The fan was to big to fit between the long water pump and becool radiator. So I mounted it on the outside and wired it up as a pusher on a temp switch. Might wanna see how much room you have between the hood latch and radiator.
66 chevelle 468 13:1comp. Wolfplace spec cam .274in/.282ex @ .050 .741/.717 109Lsa S/R. 780BG DB. sounds and runs great cant wait to get it to the track. Thanks Mike!
New mustang 09 45thAV v6auto red getting afew bolt on's.
http://www.chevelles.com/showroom/showgallery.php/ppuser/41692/cat/500
Old Nov 3rd, 09, 10:13 PM
Wes 66 Wes 66 is offline
Wes
A friend of mine and I are both using the twin Spal 12" electrics. We both have 66s with short water pumps. It is real close on the power steering belt but it works.
Old Nov 3rd, 09, 10:16 PM
shonuff shonuff is online now
John
Originally Posted by Jebchevelle View Post
Jim
Nope! a Ford Windstar fan is a dual fan assembly.........I know I have one.... from 94-2003
*69 Chevelle Malibu (Ice Blue Metallic)
*468 ci Mark Jones( Vortecpro)
*564 HP 598 TQ
*Edge 9.5" Torque Converter
*12 Bolt Posi 3.31
*850 DP
*2" Patriot Headers
*3" Exhaust Hooker Max flow Muff
http://video.cardomain.com/VideoPlayer.aspx?id=703388
Old Nov 3rd, 09, 11:29 PM
RB69SS396Conv RB69SS396Conv is offline
dual fan assembly
:yup:
That way, the fan motors are off to the sides instead of right in line with the WP.
Old Nov 4th, 09, 12:07 AM
JOHN WILSON JOHN WILSON is offline
Clueless T&T'r
Send a message via AIM to JOHN WILSON
As has been said. Consider a dual fan setup. This will get the fans off to the sides. This is what I did when I switched to a Meziere electric water pump. I was running the single Mark-8 fan and it was a no-go. So I switched to the dual SPAL setup. Works dandy.
67 Chevelle-427sbc
Best 60'-1.314
Best 1/8th-5.94@115.3
Best 1/4-9.39@141.3
Best mph-141.52
Click here to watch 10-19-07
http://www.dragtimes.com/Chevrolet-C...slip-5661.html
Old Nov 4th, 09, 1:11 AM
Jeff
I will ask him what its off next time I call him. I really dont rember what it is off of.
thanks
Jeff
Old Nov 4th, 09, 1:49 AM
twotone64 twotone64 is offline
Rod
There are a few different fans that the Taurus' used. There is a long motor and a short motor, and some motors had different fastening techniques to the blade. I pulled mine off of a 92 Taurus. I have mine because it is a two speed fan and thin. I tried a few but the Taurus fan was the thinnest for the size.
9 years and FINALLY she's drivable, just in time for my first born son.
My_two_tone_'64
Rod Hill
Industrial Tech. Instructor
Auto, Wood, Electronics, Drafting, and Architecture
Los Banos High
Los Banos California
  #13
Old Nov 4th, 09, 7:46 AM
bln bln is offline
Dave
I use these http://i33.tinypic.com/28lzzh3.jpg the spals, but you need a 22 inch rad core for them they work very well . you can get the dimentions here http://www.srbymichael.com/manufactu...ldualdimen.jpg good luck
  #14
Old Nov 4th, 09, 9:47 AM
Canucit@msn.com Canucit@msn.com is offline
Michael
I have a long pump in my 67 and I use dual fans but once I put them in I had to put in a bigger alt and then I smoked it and had to put in another with bigger wires
all said and done I think that I should of put a short water pump in and just moved my alt they have kits that can put the alt just about anywhere
on the highway my car runs warm but it cools down when driving in town
Michael
You might not be the best lookin girl here, but beauty's only a light switch away.
  #15
Old Nov 4th, 09, 4:51 PM
Jim
The Spals seem like they'd fit and are pretty popular but, man, they are a bit pricey.
Anyone know a comparable twin fan OE set up that flows enough air for me?
Rod & Wes, do you have pics of your fan set ups, what are the dimensions of your radiators?
Jim M.
467
th-400
12-bolt,4.10s
