| Chevelle Tech Current Topic: Back seat measurement for 66 | ||
| Interiors Upholstery and soft trim |
I'm having one heck of a time getting my upper back (back rest) seat cover to fit over the upper back seat frame in the 66 SS 2 -door coupe. The covers fit the lower back seat (seat portion) fine and the buckets as well. Seat covers are PUI - color is two-tone fawn.
I tried to put the cover on it multiple times, even drawing down the frame springs to allow for easier application. I tried the top as the top, then the top as the bottom (in case I had it backwards) -- still no fit... I figure it's one of the 2 following things: 1). Cover is wrong (though the PUI plastic bag that the cover came in identified it for the correct car and car type) 2. Upper frame (back rest) is wrong (would not be the first thing that was wrong with the car as it was a mess when I received it) Measurement for the back seat upper (back rest) is as follows: across the top = 55 inches across the bottom = 57 inches The seat frame does fit in the back seat with no issues If someone can confirm these measurements, I have a wrong seat cover and will get look at purchasing a new cover. If these measurements are wrong, then I'll be looking for a new back seat upper (back rest) frame. Thanks, |
Got 28 views and no replies???
Just looking for 2 measurements of the rear seat upper (back rest), across the top and across the bottom from a 66 owner.... Thanks, |
John,
Sorry I haven't done this yet - but I will get you the measurements tomorrow or Sunday; I have to dig the seat out of my shed.
Dave 1966 11A Fremont-built SS396/325 Chevelle Aztec Bronze/Black Bucket Interior "Meet my wife, Chevelle - she drinks like a fish and spends all my money." ![]() http://www.cardomain.com/ride/3072903 |
Sorry it took so long, John
-These measurements are at the seat frame: Top - 55 1/2 inches Bottom - 57 5/8 inches Hope this helps you out.
Thanks a million....
Looks like I have the correct size frame, so it must be the seat cover that is off.... |
John if the problem is with width is it possible you have a convertible rear seat cover as they are a bit narrower I believe?
[http://www.chevelles.com/showroom/sh.../ppuser/26429] |
Thanks, though I believe the bag it came in said "Coupe". Of course a "Convertible" cover could have slipped into the "Coupe" bag... just my luck... The back seat cover (bottom) fit fine, so I'll assume that the bottom frames are the same on a 66 Coupe and Convertible. |
My PUI top cover didn't fit the best either. When installed the bottom of the back didn't show, so the guy that put on the covers put it in that way.
PUI's rear door panels also were a problem. And they sent me the wrong front door windowfelts, (two different ones available depending upon placement of clips). If I had to do it again, I would put on the Legendary covers for a 66, that are available now.
interior rims, dogs, & repo redlines http://www.chevelles.com/showroom/da...m/103_0307.JPG |
Thanks all fro the responses.
I haven't got to the door panels yet..... but I'll be looking for that now. I'll probably order a back seat set real soon from PUI since I have the fronts already completed... not sure of the match if I get Legendary rear set and the PUI fronts......... Thanks, |
Both the upper and lower convertible seats are shorter than the coupe... I no longer have my convert, but I'd estimate the convertible seats are 6 inches shorter than a coupe seat...
Once you go RAT, you never go back... TC #1366 '70 Chevelle new paint 427 Stroker '66 Convertible Sold Dual Quad 396 & Conv Int '66 SS L78 |
Can you guys tell me if a 4dr rear seat is the same as a 2dr coupe? I need a rear seat for my 66 SS and might know of a 4dr sedan.
Thanks again for all the replies... |
#13
No, they are not the same. Good seat frames are getting hard to find, but I believe any A-body of the same years will fit.
66 SS Black/Black 4spd 66 SS clone Gold/Black SB2, PG, 5.535 1/8 66 SS project Slate/Black&White 03 FXSTI 67 Vette Black/Black 427/4spd 72 Cheyenne C-30 carhauler 454/5spd 72 Suburban 402/400 72 Custom Deluxe lwb (shop truck) |
| Display Modes | |
