| Chevelle Tech Current Topic: Burnout car | ||
| Performance Our High Performance area |
I want to put together a car for use at burnout parties and contests..
My dad has a 55 chevy donor car.. a 454 out of at truck with a new cam,, some head cleanup , new / intake carb.. large converter , and a 456 rear ... that should do the trick,, shouldnt it.. |
You could make a ton of smoke with a 200 shot of Nitrous
The only thing I would add to your list is Line Lock.
if all you want to do is burnouts, put 3.08's or 2.73's in it with a powerglide.
stock 454 with summit cam, and used intake and carb will get it done just well.. aaron
71 chevelle 355, voodoo roller 282/290, Brodix IK 180, 300-36, 3310, MSD, 355's, and an M20.. 314whp/349wtq, 12.911 @ 105.6, 1.95 60ft 94 Trans AM GT... Corsa Catback, Free Mods, Moroso CAI, Vortec elbow, A4, 3.42's..FOR SALE http://s28.photobucket.com/albums/c209/ssclonelq9/ http://www.sloppymechanics.com/ |
What a waste of a 55 Chevy.
1969 Chevelle Malibu 406 SBC http://oldfortyfives.com/CarsWeDrove.htm http://www.dragracingtv.com/scsn2006...eet-elims.html http://www.chevelles.com/forums/album.php?albumid=260 http://www.cardomain.com/ride/3245579 SBC/BBC/LS motors should have Separate Forums. |
I sure hope that with 4.56 gears you have a pretty big camshaft in the engine (with a long duration@.050). If it's a mild camshaft, or anything less than a very radical cam, those 4.56 gears will not be the best for massive burnouts. The car will still do them, yes but you'll get the rear wheel speed a lot faster with a more mild rear gear ratio like 3.08's or even 3.55's, and they would be much better for street driving too than 4.56's are.
The only time that 4.56's would be of help for burnouts is if you had a puney little small block engine like a 283 in a real heavy car. Because of the lack of low end torque of the engine, you might need extreme rear end gear ratios just to get the tires spinning real easy. But with a 454 engine, that would neither be needed, nor advantagous. If you want to really put on some seriously extreme smoke shows for people, you want to get the rear tires spinning above 100 MPH, and with 4.56 gears that won't be as easy to do than it would be with 3.55 gears. Particularly if you have a camshaft that isn't still making power increases up at 7,000 RPM. ![]() Below is a link to the video I made with my low 12 second car which happened to win a burnout video contest I entered (I won a leather jacket...big deal )...but the car has a puney little 281 engine that I installed a supercharger on, and I also installed 4.56 gears in it. But I can tell you that with the 3.55 gears that it originally had, it would've done even better burnouts. And BTW, it was a dialy driven street car that i used for the work commute, but it also had an overdrive transmission which made the 4.56 gears very tolerable on the highway.http://videos.streetfire.net/video/0...logy_46662.htm
70 Chevelle SS clone under construction w/new pump gas 632 C.I. engine full manual TH400 w/transbrake competition 10" torque converter Strange/Dana 60 rear Detroit Locker & 35 spline axles along w/3.73 gears daily driver: 2003 S/Ced Mercury Marauder 12.0 ET's @114 MPH on pump gas |
Sweet vid Billy.
1969 Chevelle protouring 496,AFR 305,Jesel shaft rockers,Morel lifters,UDHarold cam,Prosytems 950 carb,F1R Procharger. Run with UDHarold cam and F1R Procharger. http://s660.photobucket.com/albums/u...t=FirstRun.flv http://photobucket.com/ryfrat69 |
man that looks like a fun car billy,
1955 pro-street http://i117.photobucket.com/albums/o...o/DSCF0845.jpg [url]1966 elcamino 396ci 4 speed 1969 chevelle. 1.38 60ft @ 131 best et , best mph 133mp http://i117.photobucket.com/albums/o...ale4-11-09.jpg |
Yeah, with this guy out there I think its time to invest in rubber.
![]() [OO] Malibu [OO] 70 Chevelle - Malibu 71 GMC Sprint - RIP TC #4464 |
I always drove it and raced it with 18" drag radials on the back (they were P305/45/18 ) but for that video I bought some cheap $79 standard radials...here's what they looked like after the video was done. There's also a pic of the car sitting next to the $200K Ford GT that a guy I met through another car board gave me a ride in (that was real cool)....
http://i192.photobucket.com/albums/z...carszoo046.jpg 55 chevy
the 55 is a basket case and has NO title so it wont see road time.. I plan on not having rear brakes on it at all..cheap sheet metal after the front seats back. wrapin open headers out under the front wheel wells.. 1 guy around home here has a chevelle just for burnout purposes,, and his burnout party every year is OUT OF CONTROL sweetness.. my uncle owns a junkyard so burnoff tires r easy to store up all year.. |
My car does wicked burnouts. Its a 427BB turbo 400 3500 stall 3.73 gears. I just get it up on the line lock put the pedal to the floor and the stall allows it flash at around 4000 RPM so its instant smoke and instand 1-2shift at 7000 rpm then into third. I can cover the car with smoke in about 6 seconds. Also I installed my 3" exhaust to exit just over the axle with the ends pointing at the back of the rear tires to push the smoke out to the sides.
Here is a vid of one. Only problem is I let the car go forward almost right away. ![]() Here is a better one standing still.
Kevin, you car sounds excellent.
#13
that burnout car sounds sweet, if it cant be titled, race it or like you decided, burnout car, thats sweet! with that 454 you'll have no problem spinning tires
and Billy and Kevin, awesome burnouts! those cars are sweet!
18 years old ![]() 1970 El Camino-daily driver, resto-fied ![]() http://s282.photobucket.com/albums/k...kprimer001.jpg 73 Dodge Charger SE (hideaway headlights/ window louver delete car) 1970 440 big block http://i282.photobucket.com/albums/k...postcharge.jpg |
#15
Im a bit confused by a coment earlier.....
I had a 272 gear and a stock convertwer behind my current motor , and had to hold the HELL out of the brakes and let the RPM"S build up slowley ,, and tiers would eventually start to burn out.. I have a 373 and a 3500 converter now and its instant smoke blows 1st gear instant, with out very much pressure holding the brakes... somebody suggested i run a 272 gear for burnouts?? wouildnt that just take longer to get to peak torque RPM?? |
| Display Modes | |
