AC Blower not moving much air ? - Chevelle Tech
Heating & Cooling Heating, cooling and air conditioning
Old Nov 12th, 08, 10:02 PM
ihav1 ihav1 is offline
Default AC Blower not moving much air ?
Hello and thanks for any help... I have a 1970 Chevelle with factory AC . I replaced the blower motor but other than HI it just doesnt seem to move much air.
Has anyone used a late model Fan Blower motor that moves alot of air ? If so , what was the blower unit from ?
Or any other mod's to make the system work better ?
Old Nov 13th, 08, 10:22 AM
442 Harv 442 Harv is offline
Default Re: AC Blower not moving much air ?
I replace the motor on a Chevy PU years ago, and got it from the junk yard, and was not from the same type vehicle. So I put the motor in with the fan. It ran good but little air came out. Took it back out, and checked it with the old one.The fan blades were in opposite direction, just changed the fan,and worked like it should.Maybe that's your problem?
Old Nov 13th, 08, 4:53 PM
lsrx101 lsrx101 is offline
Tom
Although those systems were kind of wimpy when new, the problem isn't likely the fan motor. The most likely cause is the outside of the evaporator caked with 38 years of dust, dirt, and debris from the unfiltered air. Pull the blower motor and have a look.
Old Nov 13th, 08, 5:38 PM
I have had the entire unit out and restored. New Evap., POA , restored box , wiring , Fan motor , relays , etc...
Seems to work - Ok on HI , but the other speeds move little air.
Has anyone done anything to update the motor or squirrel cage for more Air ?
Someone told me to take one from a late model car , like a Monte Carlo, but the blower motor is shaped different. Just looking for some good idea's from someone who has already been down this road....
Old Nov 13th, 08, 6:22 PM
LeoP LeoP is offline
leo
Make sure the blower motor is spinning the correct way, also, the A/C blower motor is different than the non A/C motor, make sure that is correct also.
Leo Paugh
Maryland Chevelle Club #017
A.C.E.S.#3731
progress has little to do with speed, but lots to do with direction
www.mdchevelleclub.com
Old Nov 13th, 08, 7:08 PM
I am pretty sure its the AC Blower as it has a ground and power terminals. Like i said, it works ok on HI , just the other three speeds dont move enough air or very little.
Is there a better cage , faster blower motor , better relay ?
Does anyone know what other blower might fit the case ?
Old Nov 14th, 08, 12:07 AM
BlueSS454 BlueSS454 is offline
Tom
Send a message via AIM to BlueSS454
IF it's workig on high, and barely on any of the other speed selects, it's a current problem. Check the blower motor resistor that is screwed into the heater box on the engine side. It's the one with the 3 spring looking coils.
Tom Rightler, MCC VP & Newsletter Editor
1970 SS Best ET: 12.31@108 MPH
1969 Malibu
1969 Dodge Charger
1970 Chevelle Convertible
Old Nov 14th, 08, 11:11 AM
Second_chance_SS Second_chance_SS is offline
Mitch
Many of the doors to direct the air are vacuum operated. The engine needs to be running for the controls to work properly and get the air into the cab. If you have tried it with the engine running, are the controls working ??
70 Chevelle SS 396, Canadian documented Z25 project.
66 Chevelle SS 396, Atlanta built 138 driver/project.
66 Chevelle Malibu Fremont built Marina Blue on Blue
67 Camaro, ss/rs 350 LA built driver/project.
66 Corvair Corsa convert...140hp 4 speed
38 Chev coupe...355, 200r4, 8.5" 3.08 posi
52 Chev 2 ton flat bed
59 Friendship camping trailer
Old Nov 14th, 08, 11:33 AM
Chevelle_Nut Chevelle_Nut is offline
Jonathan
Cheap after market blower motors are not wound as tight as OEM units. I was able to reuse my 69's original unit and it blows musch stronger than my 72's with an aftermarket motor.
https://www.coolharts.com
http://www.carolinachevelle.com/
72 Chevelle Malibu
72 Chevelle Malibu Father/Son Project-- In Pieces
NCOA #6446
ACES #8153
Carolina Chevelle Association #147
Maryland Chevelle Club #834
Old Nov 14th, 08, 11:39 AM
ccpd166 ccpd166 is offline
Steve
I have the same issue. However, I first had a problem with no high on the fan. I was then advised (on here) that there is seperate fuses for the other speeds, and one high speed fuse that I located under the hood. Is it possible that that High speed fuse is good and the other bad?
Steve CCPD166 Broward County Florida
1970 Chevelle SS
396/350
Old Jun 30th, 09, 4:39 AM
69307/350Chevelle 69307/350Chevelle is offline
James
Same kind of question here. I've taken everything out and cleaned up the whole A/C system, new blower motor, etc. I know the car has a 40 year old design, but is there a more powerful blower motor that might make it match today's late model standards. My friends new Civic A/C feels so nice, are new cars systems just better at sealing in cool air?
"Wake me when you need me."
-117-
Old Jun 30th, 09, 6:13 AM
Tom
Newer cars are just better designed for better airflow and volume.
Back in circa 1970, most GM cars were known to be rather wimpy as far as airflow out of the ducts, except on High Blower (Thus the High Blower Relay to put as much power as possible to the motor). Then they were only "kinda" wimpy. Chrysler products were even worse at that time. Ford was the only one back then that could boast that the output from the dash vents could "blow your hair back". Even they weren't up to todays expectations.
The High line GM cars (big Buicks, Olds, Etc) were better than the Low or Intermediate Line cars for airflow, but even they were not what you would expect today from even a "cheap" car.
Cars of the 40's and 50's had very poorly designed airflow (heater) systems that were just barely better than nothing. The systems of the 60's and 70s were comparatively far superior performers as the years progressed, but surely not even good compared to today. Fast forward to the 80's and they were better yet, but still not up to todays standards. Only in the late 80s and into the 90s did GM produce MVAC systems that compare to today's systems. That same progression held true with the other manufacturers, but GM historically has always had the "wimpyist" airflow systems as compared to the "other guys". Actually, that still seems to hold true even today IMHO. The difference just isn't as noticeable.
There might be ways to improve the airflow of those older cars, but I've never delved into it.
Today, the best you can do is meticulously seal leaks in the ductwork, make sure everything is nice and clean, and make sure the blower motor and it's wiring is up to par on these older cars. They were great performers compared to their predecessors, but you will never get 2009 performance out of them.
"I didn't defend myself. I killed the crap out of him!" Norma Bates
Chevelle Tech > Mechanical > Heating & Cooling      Current Topic: AC Blower not moving much air ?
Human Verification
