Performance Our High Performance area
Old Jun 18th, 09, 12:55 PM
staygreek staygreek is offline
bobbyh
Default this cam ok?
first off im building more of a pro touring driver than a strip car...
specs
496ci
10.25:1
PRO-COMP ALUMINUM CNC PORTED RECTANGLE PORT MANLEY VALVES (2.25 X 1.88) i think good up to 650 lift
1.7 RATIO FULL ROLLER ROCKER
bg mighty demon 750.... think i need 850
air gap intake
cam
@50 238 248 cut on 109 lift 540 540
rest of car
th350 3000 stall
3.91 gear
motor is new not in car yet would like to make changes while its on the stand
Old Jun 18th, 09, 1:16 PM
cstraub cstraub is offline
Default Re: this cam ok?
What is your max rpm you wish to turn the engine?
Is the cam a flat or roller lifter lobe?
Chris Straub
Mfg Performance Parts
www.straubtechnologies.com
Old Jun 18th, 09, 1:42 PM
bobbyh
6500 maybe 7 at most
flat
Old Jun 18th, 09, 1:47 PM
kettbo kettbo is offline
George
Bobby,
238/248* and .540" lift is more appropriate to a moderate street 454 and 6000 rpm than a 496 with rectangle port heads you wish to rev to 6500 or 7000 rpm.
Just when your heads get going, the cam will lay down. Simply not big enough to feed the beast or get the job done. The 496 will make that into an RV cam.
George Kettler
o 70 El Camino mild 454/TH350/3000 stall/3.42;
http://s266.photobucket.com/player.s...fs=1&os=1&ap=1
bests: 1.70 12.787 104.89 1/4 mi 8.03 1/8 mi
o 68 Vette 427/M-20/3.36
http://public.fotki.com/kettbo/gearhead/
Old Jun 18th, 09, 2:09 PM
71454Chevelle 71454Chevelle is online now
Darren
Send a message via ICQ to 71454Chevelle
flat
That cam wont come close to doing that.
Darren
1971 Chevelle
496
Brodix 294cc Rect Port Race Rites 10.5 scr
Ultradyne Solid Roller 256/264 .660/.660 108 lsa
Dr. J's Ported RPM AirGap Pro Systems 1000HP
S-K Speed Iron cased Super T-10
12 Bolt, 4.30 gear, Mosier axles
M/T 295/65R15 Drag Radial
N2O
http://www.chevelles.com/showroom/data/508/IMG_0023.JPG
Old Jun 18th, 09, 2:11 PM
Darren
Darren
1971 Chevelle
496
N2O
Wont even get close to that kind of rpm, what you have will be done by 5200 to 5500 rpm in 496 cid. If this is a pro touring car I would recommend hyd roller. You can get more power out of a "smaller camshaft" and still maintain some type of street manners. The investment is more but the results will more then please you.
I would shoot for a max HP rpm of say 6200. She will still pull beyond this but the HP will fall off after this point. This kind of max HP rpm still give you street manners for the pro touring aspect of the engine but still make a legit 600HP.
If budget constraints warrant a flat tappet then thats what you will need to run but that cam will not come close to getting you to 6500 rpm.
If I can be of help pm me or call and I can design you something to get you where you want to be within reason.
Chris Straub
Old Jun 18th, 09, 2:36 PM
bobbyh
soooooooooo somthing like this?
lUN-30210
Cam Style Hydraulic flat tappet
Basic Operating RPM Range 3,500-7,000
Intake Duration at 050 inch Lift 245
Exhaust Duration at 050 inch Lift 255
Duration at 050 inch Lift 245 int./255 exh.
Advertised Intake Duration 295
Advertised Exhaust Duration 305
Advertised Duration 295 int./305 exh.
Intake Valve Lift with Factory Rocker Arm Ratio 0.605 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio 0.612 in.
Valve Lift with Factory Rocker Arm Ratio 0.605 int./0.612 exh. lift
Lobe Separation (degrees) 110
Old Jun 18th, 09, 2:40 PM
bobbyh
or is this still too small
Old Jun 18th, 09, 3:03 PM
George
while I won't say your choice in the post above is ideal, you have caught on to the theme I was working toward...big engines require big cams!
George Kettler
Old Jun 18th, 09, 3:12 PM
Jason Snyder Jason Snyder is offline
lUN-30210
that cams rpm range looks like it is rated for a 396 , not a 496 , add 20 degrees more duration for the 496 .
Old Jun 18th, 09, 3:35 PM
Jason and Ketbo are correct, you have added cubes over the common BBC of the past. You also have piston speed. That extra stroke increases the piston speed in the engine. Piston speed will "swallow" head volume and cam duration as compared to the same engine with equal cubes but less stroke.
Also with those heads you have I believe they need a little tighter duration split
Chris Straub
  #13
Old Jun 18th, 09, 3:48 PM
the heckler the heckler is online now
kevin
fwiw...I run this flat tappet solid lifter cam in my "street" 496. 10.5:1 with edelbrock oval ports and 850 dp. makes 600 hp on pump gas....
The cam is a comp cam part # 11-679-5.....xs290s....
Duration at .050 252/260
lift .598/.598
lobe sep. 110
lash .016/.016
works great but requires a vac reservor for the brakes...
  #14
Old Jun 18th, 09, 4:21 PM
Chris Stanwyck Chris Stanwyck is offline
chris
lift .598/.598
lobe sep. 110
lash .016/.016
like that choice...very streetable in a 496...like it even more so cut it on a 112 or a 114 & won't hit so hard on your turbo 350....plus a bit more vacuum that should not require the resevoir.
600lift, duration in the late 250's @ .50, with solid lifters in a 496...nice street piece with a ton of power.
The cam you have will hit too hard early and die off fast fo sho....and you will leave too much horsepower on the table.
You can always contact one of the cam guru vendors on this site as well...worth the few extra bucks IMO.
stayingmacedonian
  #15
Old Jun 18th, 09, 5:25 PM
wildman926 wildman926 is offline
Walter
I would go with this one for a solid ft. It has PROVEN performance -
Lunati 402A7 -
Solid, rough idle. Good cam for bracket racing in 396-454 cubic inch motors. Needs 3500 RPM stall converter, headers, 10.5:1 compression ratio and 4.10 gearing.
Advertised Duration (Int/Exh): 288/296
Duration @ .050 (Int/Exh): 255/263
Gross Valve Lift (Int/Exh): .612/.630
LSA/ICL: 110/104
Valve Lash (Int/Exh): .024/.026
RPM Range: 3000-7000
Here is a video of a 496 with one in it. I run the solid roller version of it in my Chevelle. This is NOT my car -
Short+video+of+my+El+Camino+idling.
69 Chevelle SS
10.5-1 496/AFR 305's/Voodoo 60234 Solid Roller/TH400 3400 Stall/4.11 12 Bolt
Liberals--an example of what happens when the weak are allowed to survive.
