'06 LS2 Drive by wire and gas pedal - Chevelle Tech
Pro Touring Todays performance with classic style
Old Aug 16th, 08, 11:31 AM
Kingstir Kingstir is offline
Blanchard
Default '06 LS2 Drive by wire and gas pedal
I purchased an LS2/4L60E pull-out from a 2006 GTO. I was promised everything that I needed would be there. So far, it appears I don't have a gas pedal or any of the wiring from that end of the harness. Am I screwed, or is there a way to incorpoate another pedal and wiring that will get me up and running? I hate to spend 2 Large on a whole new harness if there is a way to use what I have. Thanks for any input.
Blanchard
1970 El Camino
Old Aug 17th, 08, 7:21 PM
andrewb70 andrewb70 is offline
Andrew
Default Re: '06 LS2 Drive by wire and gas pedal
Search LS1tech.com
You should be able to find the pin-outs for your computer and figure out what wires to run for the pedal. 2007 Monte Carlo SS uses a nice pedal that fits well in a-bodies. You can look in my build thread for details. Link in sig. It's less than $50.
Andrew
1970 GTO Version 2.0 in progress
V8TV Feature video
Popular Hotrodding feature
Car Craft feature
1967 Cougar LSx build
"You were the gun, your voice was the trigger, your bravery was the barrel, your eyes were the bullets."
Old Aug 17th, 08, 7:59 PM
Alwhite00 Alwhite00 is offline
You might be able to swat the throttle body out for a cable drive unit. That's what my budy did with his 5.3 he is putting in a 37 ford street rod. Guy swapped him even-up. Of course he is using an aftermarket harness. (Howell)
LK
The only difference between No.One & No one. is where you put the period.
67
http://i925.photobucket.com/albums/a...7/DSCF9178.jpg
70 (SOLD)
http://i925.photobucket.com/albums/a...e/DSCF9111.jpg
Sea Ray
http://i925.photobucket.com/albums/a...0/DSCF6826.jpg
Old Aug 17th, 08, 11:15 PM
novaderrik novaderrik is offline
Derrick
i think swapping the throttle body requires an intake swap due to a different mounting bolt pattern.
as for the pedal- i think everything GM sells is fly-by-wire these days, and i know that GMPP sells a complete wiring kit for LS2/LS3/LS7 swaps that comes with a pedal.
i'd be calling every junkyard around and telling them that if they get a wrecked truck that you need the pedal and some of the wiring for it.
"Detroit hasn't felt any real pride since George Bush went to Japan and vomited on their auto executives, I tell you whut"
-Hank Hill
Old Aug 18th, 08, 10:54 AM
Blanchard
I spoke with John Spears at Speartech this morning. He is going to be able to fix me up with a reworked harness (using what I have) and add in a pedal and everything else I need. Looks like I am going to escape for a little over 6 bones and some change. I figured I was going to be paying close to that if I had all the pieces I needed. Glad to have a solution to this problem. Thanks for all of the input.
Blanchard
1970 El Camino
Chevelle Tech > Specialty > Pro Touring      Current Topic: '06 LS2 Drive by wire and gas pedal
Human Verification
