| Chevelle Tech Current Topic: Voltage Regulator Wiring | ||
| Register | Photo Ads | FAQ | User List | Social Groups | Calendar | Chat | Search | Today's Posts | Mark Forums Read | Insurance | Auto Loans | Auto Escrow |
| Electrical & Wiring Troubleshooting electrical problems. |
Hello Everyone,
I am building a cheap race car out of a 72 Chevelle. I plan on running with the original style external regulatated alternator for now. I have gutted the interior, and am installing a switch pannel with start button. I will not be using any of the original under dash wiring. My question is, is it OK not to hook up the Brown wire from the voltage regulator? My understanding is that it is only for the Alt warning lamp. Does it serve some other purpose? I am feeding my switch pannel from my trunk mounted cut-off switch, so the ignition circuit will no longer be fed by the fuse block. Will the Alternator/Regulator be damaged by having an open circuit on the Brown wire? How does the Brown wire trigger the Alt. Light? If the Alt is not butting out amperage, how does it send voltage through the brown wire to turn on the light? Any help would be appreciated. Thanks! Keith |
| Sponsored Links | ||
Advertisement | ||
Thanks!
So, if I understand correctly, if I do not use a warning light, I should connect the Brown wire (terminal 4) to 12V Ign? Keith
Keith '69 RS/SS Camaro 502/TH400/4.11 Best 12.10 @107mph '69 Z/28 Clone 383/TH400/3.73 Done! 996 Points out of 1000 at MCACN 2009 '72 Chevelle 540/TH400/4.11 Best 9.792@ 137mph - 11/07/10 |
Guys,
As I think about this more, how does the stock system keep from backfeeding 12V battery to the Ign circuit when the key is turned off? Do I need to wire in a diode on the wire feeding terminal 4? Thanks! Keith |
Guys, Quote:
The GEN bulb and bypass wire limit current, this prevents backfeeding anything. Generally, the only time you need a diode is if you are using a aftermarket ignition box, like a MSD 6AL as it takes very little power to turn it on. |
OK guys, now I am confused.
I do not plan on running a Gen light. I will not be running any of the stock underdash harness. That said, do I need to hook up the brown wire at all? Or do I run a 12V Ign wire to it, with a resistor installed. If so, any idea what size resistor? Then, I would go from the voltage reg. #4 pin, through a resister, then to a 12V Ign source? On a stock gauge car, with no Gen light, is the resistance wire linked directly to the ignition switch? The 72 Assembly Manual does not have a freaking schematic!! Thanks! Keith |
Thanks Everyone!
Hopefully, this helped some others too. Keith
| Sponsored Links | |
Advertisement | |
| Display Modes | |
