Looking for Sheet Metal Accessory that goes in front of Radiator - Chevelle Tech
Year One
post #1 of 3 (permalink) Old Apr 21st, 12, 7:12 PM Thread Starter
Rob
I saw a 1964 Chevelle, with a piece of sheet metal attached to the bracket that hold the two fenders together "upper grille tie bar". It was filler pieces bent 90 filling the open space between the grill & radiator created my this bar. One on each side. It had formal lettering "Chevelle & year" on the upper bent part which would be facing you as you looked toward the open hood..
This piece actually closes off the open space acting like an air dam directing all air to go straight into the radiator.
I was a OPG, they don't know anything about it.
Any help is appreciated
Thanks in advance
Brob is offline
post #2 of 3 (permalink) Old Apr 22nd, 12, 1:36 AM
Re: Looking for Sheet Metal Accessory that goes in front of Radiator
They are called radiator support show panels..Ground up has a whole bunch for a 64, from mild to wild. http://www.ss396.com/mm5/merchant.mv...ATORSHOWPANELS
"Don't You Know It's All Ball Bearings These Days"
1970 Chevelle SS 454
More Chevelle
Fear This...
chrispicide35 is offline
post #3 of 3 (permalink) Old Jul 23rd, 14, 7:45 PM
Undercover innovations and you can personalize them
crossfire8 is offline
This Thread is more than 1038 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
You may not post new threads
You may not post replies
