EFI tank that works - Chevelle Tech
 6Likes
post #1 of 67 (permalink) Old Jun 3rd, 16, 11:13 PM Thread Starter
Danny
Send a message via AIM to bluechevelless Send a message via Yahoo to bluechevelless
EFI tank that works
SO I have the aeromotive tank thats from tanks inc. I cant do anything with it under half a tank. So whats a tank that actually works with efi that will go around corners and be able to launch at the drag strip. I cant even accelerate hard on the street with street tires right now. Ive read alot about the ricks efi tank but I dont know which one or how much they are.
1970 Chevelle SS 396
Originally Mist Green
Dark green Interior
AC PW PL
www.cardomain.com/id/3115ultima
www.g3gm.com
bluechevelless is offline
post #2 of 67 (permalink) Old Jun 3rd, 16, 11:27 PM
Mark
Re: EFI tank that works
Mine works great at any level. Never a problem.
'69 Chevelle SS (Almost on the road, and it runs again, but in the body shop for a while.)
ZZ502 Short block
Comp Custom Magnum HR 306/303 Adv dur 246/248@ .050 .680/.647-112LSA-108 ICL (Crap!...ate the cam's distributor gear!)
NEW CAM: Bullet HR ADV Dur 295/297 238/242 @ .050 .680/.650-110 LSA-108 ICL Morel lifters
Holley Avenger MPFI
612HP/594TQ (Dyno numbers with the Comp Magnum Cam)
T-56 Magnum trans with McLeod RST
MarkP is offline
post #3 of 67 (permalink) Old Jun 3rd, 16, 11:32 PM Thread Starter
Danny
Mine sucks anything under half tank it cuts out. especially under hard accel.
Dark green Interior
AC PW PL
www.g3gm.com
post #4 of 67 (permalink) Old Jun 3rd, 16, 11:50 PM
Mark
I've never heard of anyone having problems with the Tanks Inc. setup. Almost sounds like the sump pan was missing, but I'm sure that you looked it over before you put it in. I'd call Aeromotive because something isn't right if it runs fine above 1/2 tank.
rel3rd likes this.
ZZ502 Short block
Holley Avenger MPFI
MarkP is offline
post #5 of 67 (permalink) Old Jun 3rd, 16, 11:56 PM
Troy
You probably have a leak somewhere between the 1/2 tank fuel level and the top of the tank.
66 CHEVELLE
senna is offline
post #6 of 67 (permalink) Old Jun 4th, 16, 12:01 AM Thread Starter
Danny
The aeromotive tank comes assembled and ready to install. Ive been tempted to drop it and remove the pump and check everything over. Im car will run just fine all the way down to almost completely empty if I drive like an old granny.
Dark green Interior
AC PW PL
www.g3gm.com
post #7 of 67 (permalink) Old Jun 4th, 16, 12:06 AM
Have two Tanks INC tanks with Aeromotive pump and hangers in two different cars and never ever had a problem with fuel. I auto cross the Chevelle with usually less than 5 gallons in the tank. Whats the rest of your fuel system?
TC Member #96
16 Year Team Chevelle Member
1967 Turbocharged 408ci LSx Chevelle - 1012 rwhp, 959 rwtq 67 Chevelle
2009 Supercharged Silverado - On the Dyno
1967 LSx El Camino build videos on YouTube - ***NEW VIDEO UP 12/28***
"Hey Butthead, does this Pantera guy ever relax?" - Beavis
Brian Hoss is offline
post #8 of 67 (permalink) Old Jun 4th, 16, 12:08 AM Thread Starter
Danny
Im running -6 PTFE lines with a Fuelab Fuel filter. straight shot to and from the throttle body.
Dark green Interior
AC PW PL
www.g3gm.com
post #9 of 67 (permalink) Old Jun 4th, 16, 1:21 AM
Mark
I wouldn't touch it until you contacted Aeromotive. The last thing that you need is them telling you that you voided your warranty by removing the pump.
oliver69 likes this.
ZZ502 Short block
Holley Avenger MPFI
MarkP is offline
post #10 of 67 (permalink) Old Jun 4th, 16, 1:21 AM
Rich
Check with rel3rd (Bob)...he has the same and runs the piss out of his car everytime it's out of the garage. If there were a problem with it we would hear about it for sure.
HandOverFist is offline
post #11 of 67 (permalink) Old Jun 4th, 16, 1:39 AM
Regulator? What are you running and where? What engine are you running? Some specs on it? Which Aeromotive tank did you go with?
TC Member #96
post #12 of 67 (permalink) Old Jun 5th, 16, 1:40 PM Thread Starter
Danny
The regulator is built into the throttle body. Ive had the tank since may 2014. Engine is 454 11:1 comp oval port heads and a healthy roller cam.
Dark green Interior
AC PW PL
www.g3gm.com
post #13 of 67 (permalink) Old Jun 5th, 16, 1:57 PM Thread Starter
Danny
I was carbureted I just got it going with the fuel injection.
Dark green Interior
AC PW PL
www.g3gm.com
post #14 of 67 (permalink) Old Jun 5th, 16, 2:14 PM
Jason
These setups usually require a corvette filter regulator. This is usually the weakest link. Maybe you have a bad one?
whatachevelle is offline
post #15 of 67 (permalink) Old Jun 5th, 16, 10:25 PM Thread Starter
Danny
Im using a fuelab fuel filter the return comes from the throttle body back to the tank
