Fast EZ EFI - Chevelle Tech
post #1 of 6 (permalink) Old Jun 4th, 11, 10:26 PM Thread Starter
Fast EZ EFI
Hey everyone,broke open the piggy bank today and picked up a FAST EZ EFI . Looking forward to installing it SAP.
SUPERDAVE 67 SS-396,67 Elcamino,67 300 2dr Sedan,91 S-10,2012 Silverado
SSDAVE is offline
post #2 of 6 (permalink) Old Jun 4th, 11, 11:34 PM
Wade
Re: Fast EZ EFI
I've got mine up and running. Starts and runs good. Will be a couple of weeks untill I can drive it. Only problems I had with the install was I was 2 ft short on fuel line to finish the return. And getting the fittings on sucked! Ended up clamping a bulkhead fitting I had in the vise so I had something solid to push against. Just screws the hose end on it lube with a little grease. Then used a heat gun pointed right at the end of the hose, useing gloves get it nice and hot and push with everything you got. Boiling didn't much work for me. Could only get it on about 3/4 the way and had to boil again. Just took to long.
upman is offline
post #3 of 6 (permalink) Old Jun 6th, 11, 12:11 AM Thread Starter
Re: Fast EZ EFI
I was thinking of using up my left over steel braided stuff, and since I'am doing a frame replacement at the same time, I 'am going to use 3/8'' stainless hard line where I can. I have an AN flaring tool, so everything is going to be AN.
SSDAVE is offline
post #4 of 6 (permalink) Old Jun 7th, 11, 4:50 PM
Kevin
Re: Fast EZ EFI
I had major problems getting on the fittings so I switched to a combination of braided SS and aeroquip push lock hose. It's cheap, goes on easy, and doesn't leak. I did have to order some extra fittings from Summit as the supplied ones weren't enough for my installation. I also used some adapters to go from hard line to AN that use a compression sleeve. Real handy when you are under the car and don't want to remove your newly installed hard line to flare it.
"If your not living on the edge, you're taking up too much space" - Jim Whittaker
AFR Eliminator 195's
FAST EZ EFI
SC&C Stage II Plus suspension
Hotchkis/Hellwig sway bars
Tremec TKO 600
Chevy67 is offline
post #5 of 6 (permalink) Old Jun 7th, 11, 9:10 PM
Re: Fast EZ EFI
Boiling the hose for 15 min then, with the fitting in a vice and a squirt of spray lube, I got the hose on pretty good. By no means though, do you have to use the hose in the kit, whatever works is fine, so long as it doesn't leak.
fridgeguy is offline
post #6 of 6 (permalink) Old Jun 8th, 11, 12:50 AM
Kevin
Re: Fast EZ EFI
I tried everything to get the supplied Fragola hose on and succeeded with one fitting after boiling for 45 min coupled with a lot of force and swearing. The Aeroquip hose went on so easy I thought it would leak but no problems. We have a specialty fitting place in town and we measured the Fragola fittings and found them to be exactly the same size and design as the more expensive Areoquip push lock units. I still have about 20 ft of unused Fragola hose in my garage.
FAST EZ EFI
Tremec TKO 600
Chevy67 is offline
