Avenger MPFI installed!!! - Page 4 - Chevelle Tech
post #46 of 223 (permalink) Old Aug 1st, 10, 11:09 PM
Aaron
Re: Avenger MPFI installed!!!
that is awesome to hear and you never know its there!
1971 Chevelle. 355, megasquirt efi. On3 7875 turbo. 4l80e, py3600, 355 gears. C5 brakes, SC&C stg2+, hellwig bars, 04-06 gto seats. 546rwhp/450rwtq with 28% converter slip on 18psi!
Little walk around video
http://youtu.be/D_B0B1RNmcc
BowtieAaron is offline
post #47 of 223 (permalink) Old Aug 1st, 10, 11:14 PM
Mark
Mark
1970 SS396
Lewis Racing Engines (Wolfplace) 489:
634 HP @ 6000rpm
627 Lb-ft @ 4,000rpm
ProSystems SV1
Gear Vendors Overdrive
Moser 12 Bolt
Alumitech Radiator
Pypes Exhaust
Dyno
'70 Chevelle
'70 Chevelle 2
Xtreme70SS396 is offline
post #48 of 223 (permalink) Old Aug 2nd, 10, 1:13 AM
Mark
Are your brakes as good as before?
Do you suppose that the performance boost came from the larger 1000 cfm and/or taller intake?
Doug, does the intake make a big difference in performance on MPFI? I know you run a tunnel ram and Jim's 540 is running a Domintor MPFI intake, so I guess the answer is yes, but is there a significant difference?
'69 Chevelle SS (Almost on the road, and it runs again, but in the body shop for a while.)
ZZ502 Short block
Comp Custom Magnum HR 306/303 Adv dur 246/248@ .050 .680/.647-112LSA-108 ICL (Crap!...ate the cam's distributor gear!)
NEW CAM: Bullet HR ADV Dur 295/297 238/242 @ .050 .680/.650-110 LSA-108 ICL Morel lifters
Holley Avenger MPFI
612HP/594TQ (Dyno numbers with the Comp Magnum Cam)
T-56 Magnum trans with McLeod RST
MarkP is online now
post #49 of 223 (permalink) Old Aug 2nd, 10, 7:17 AM
That was my thoughts also. Would guess, Vince's motor is pushing 700 HP if dyno'd. Between the long runners and MPFI, the motor is now getting consistent fuel distribution along with all CFM that the motor needs. Now all he needs are some 10" rims and as much of a slick as he can get under the wheel wells.
GRN69CHV is offline
post #50 of 223 (permalink) Old Aug 2nd, 10, 7:18 AM Thread Starter
Vinny Vince
Thanks guys!
Mark, hard to say what makes it so much better. So far, the biggest thing I noticed was the better idle and WOT hits harder. I guess the MPFI is not waiting on air velocity like a carb does to get the metering going. The power is instantaneous...not waiting on a accelerator circuit of a carb to catch up. When you think about, when you wing open a carb, you get a gulp of air that goes down first, then the accelerator pump comes in right after. With EFI, the injector is below the plates, and the mixture hits right on time. I'm sure the 1000cfm throttle body and tall single plane are just what my 509 wants anyhow.
Keep in mind, I only drove for 10 miles. Need to get more time on in before I can come to complete conclusions. Speaking with Doug, WOT learning occurs very fast - and I beleive it b/c it felt SUPER strong right off the bat up top. Its the low rpm driving stuff that takes longer to learn. Just wanted to post my initial findings for now.
*11 C6, 6.2, 6spd
69-CHVL is online now
post #51 of 223 (permalink) Old Aug 2nd, 10, 12:21 PM
Originally Posted by GRN69CHV View Post
Intake can not be milled. Mounting flange is only about 1/4" thick. It's either a raised hood or a drop base air cleaner.
Not so. I milled mine 1/2". The steel plate under the TB will seal against a milled intake, even though the pad has been milled off. I used some RTV so the plate stays on the intake and then a gasket between plate and TB. I had what was left of the IAT hole TIG welded shut and put the IAT sensor in the air cleaner.
zwede is offline
post #52 of 223 (permalink) Old Aug 2nd, 10, 12:54 PM Thread Starter
Vinny Vince
Zwede,
What year is your car, and what's the airfilter system consist of? I contemplated milling the intake, but I think dropping the TB down lower closer to the rails would of made things worse for my particular situation. The drop base aircleaner just makes things tough. Did you clearance the throttle arm at all? The throttle arm hit my rails with just the metal spacer/gaskets not installed.
*11 C6, 6.2, 6spd
post #53 of 223 (permalink) Old Aug 2nd, 10, 12:57 PM
That's good to know. So the mounting bolt holes were drilled and tapped deep enough? 1/2" wouod have made a big difference with both the air cleaner and the throttle linkage.
GRN69CHV is offline
post #54 of 223 (permalink) Old Aug 2nd, 10, 2:41 PM
Stellar.
This is pushing me slowly but surely toward an EFI BB. Please keep the thread going, its invaluable to guys like me who wobble on the fence, HAVE to go with a BB and still havent built the motor yet so can go either way. I didnt want to putz with the laptop so what you are doing is PERFECTO for me to watch as well as others, I am sure.
VERY - VERY COOL
"I know a lot about cars, man. I can look at any cars headlights and tell you exactly which way its coming." - Mitch Hedberg
Beaux is offline
post #55 of 223 (permalink) Old Aug 2nd, 10, 3:20 PM
The car is a '71 Corvette, so not quite apples to apples. But we share a lack of hood clearance.
I'm using an L88 air cleaner setup where the filter is in the cold air chamber attached to the hood.
I have an earlier TB where the throttle linkage was billet aluminum rather than the steel linkage you have. Yes, I did cut mine to clear the fuel rail and also the top to clear the air cleaner. The linkage had two holes, I cut it right above the first hole.
If you need pictures from other angles, just let me know.
zwede is offline
post #56 of 223 (permalink) Old Aug 2nd, 10, 7:17 PM Thread Starter
Vinny Vince
Zwede, I figured you had the earlier TB with the different linkage. In all honesty though, I could of easily ground the bottom of this throttle arm off so the TB could sit lower. But in the end, just much easier to do what I did as far as modifying the air cleaner base and throttle bracket - its done.
Anyway, took her for another drive, she's running like a top. Power is just right "there" all the time. Spinning wheels at part throttle. Took the Mrs. along, and even she could tell the difference...especially at idle. It idles so smooth that if feels like its idling lower, even though the tach says 1000 rpms like it did with the carb. No hesitations, no hick-ups, nothing except razor-sharp power. I feel compelled to hit the track asap
Will do another update after a couple more drives, but cant imagine it running any better than it does already, but it will.
Good stuff people
*11 C6, 6.2, 6spd
post #57 of 223 (permalink) Old Aug 2nd, 10, 7:27 PM
Good stuff. You keep getting those bugs worked out.
GRN69CHV is offline
post #58 of 223 (permalink) Old Aug 2nd, 10, 11:20 PM
Vince, what did you end up with for a fuel system? I have a couple intakes with throttle bodies and injectors, just need to figure out a fuel system and get a harness and ECM........ Jim
72 Chevelle SS conv http://www.fquick.com/454ragtop
72ragtop is offline
post #59 of 223 (permalink) Old Aug 3rd, 10, 7:04 AM Thread Starter
Vinny Vince
I had run -8 Aeroquip socketless hose for the feed and a return for the prior setup. I have a bunch of reducers here and there to reduce the -8 to 3/8 barbed fittings throughout the system. The inline pump supplied by Holley, the filters, all use 3/8 barbed fittings...that's all you need for this system. Over the winter, I will get a tank sumped, and change everything to -6 socketless for a cleaner install. The -8 is just too big to route nicely through the car...it has a .75 OD IIRC, and you have two of them.
*11 C6, 6.2, 6spd
post #60 of 223 (permalink) Old Aug 3rd, 10, 8:38 AM
JIM
This all sounds familiar! When we converted mine it was on the dyno initially. We had been making dyno pulls with the carbed setup and Judson, the owner of the School of Automotive Machinists was listening through the walls up in his office as we made pulls. When we got the EFI fired up... he came back and wanted to know what we had done because he said it sounded like we had *taken 20 of cam out of it* from the way it was idling.
As soon as it cools off a little I'll be hitting the track also to get some runs in. I think it's going to be good!
Great to hear how it's working for you!
JIM
'67 Vette-555"/Gforce 5 Spd/Dana 60 IRS-3.07's
9.19@157.83 so far.....more to come soon...
200 MPH at TX Mile
http://s318.photobucket.com/albums/m...rrent=Jim3.mp4
"...when it's not pointing at a wall...grab a gear!"
*This Life Stuff ain't no dress rehearsal"
540Hotrod is offline
This Thread is more than 2005 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
