March Squishy Cam Madness
Tired of not driving the Machine in the garage because of the OEM flat tappet lifters, well here’s your answer for boosting confidence and HORSEPOWER!!
For the OEM headed 396, 402, or 427 let’s give the engine some reliability while boosting power
For $1095 you get
Straub Squishy Cam
Lift .600/.570
Adv. 288/300
.050 229/241
Lobe Sep 109
Matching Components
1.530OD Valve springs
7 Degree Chrome Moly Retainers for 3/8” Stem Valves
3/8” 7 Degree Locks
Double Roller timing Set
Timing Cover Gasket
Morel Street Series lifters
1 piece 3/8” Pushrods .083” Wall
Roller Cam button
Cam lock plate
Cam Bolts
This kit will give your 375HP mill another 100HP to play with on the streets. That’s 10.99 per HP!!
$1099* to your door.
• Note if rear cam journal needs to be grooved add $40 to cost.
For $1095 you get
Straub Squishy Cam
Lift .600/.570
Adv. 288/300
.050 229/241
Lobe Sep 109
Matching Components
3/8” 7 Degree Locks
Timing Cover Gasket
Roller Cam button
Cam lock plate
Cam Bolts
