Magnaflow 15893 kit not fitting - Chevelle Tech
Magnaflow Magnaflow
post #1 of 10 (permalink) Old Jan 29th, 11, 5:30 PM Thread Starter
Anybody have any issues with the magnaflow 2 1/2 kit for 64-67? I got the header back with x pipe all installed. Everything is centered level and straight. Mufflers sit lever and tucked up nice. But tail pipes wont go. The passenger side fits perfect. The drivers side hangs down 3 inches. looking from the rear axle both mufflers look perfect.
The exhaust that came off which I installed in 1976 had offset to offset mufflers. The magnaflow has offset to center. If both were offset I would have plenty of room to adjust. I can see that the left tailpipe is bent a little different then the right as far as bends go.
64 Chevelle 496
StevenS is offline
post #2 of 10 (permalink) Old Jan 30th, 11, 4:27 PM Thread Starter
Re: Magnaflow 15893 kit not fitting
Well I guess I will see how good magnaflow customer service is. I cannot see anyway to fit the left side pipe other then cut and re-weld. I tryed every adjustment possible. Even if I measure it up to trim both pipes it wont work. Has to be the over the rear pipe. You can see left to right pipe are bent differently and the left is longer.
I bought this kit because it was supposed to fit not the case.
64 Chevelle 496
StevenS is offline
post #3 of 10 (permalink) Old Jan 31st, 11, 11:59 AM
Jordan
Hi Steve,
It sounds like you need to spin and rotate the side you are having problems with.
Please feel free to call, email or PM me.
Regards,
Don
JDP Motorsports
888-308-6007
Sales@JDP is offline
post #4 of 10 (permalink) Old Jan 31st, 11, 6:38 PM Thread Starter
I did try to spin and rotate that side. Tryed every adjustment possible. You can only spin the pipe so far since its so close to the upper control arms. If they use offset offset mufflers things would fit so much better. Like I said you can see the over the rear pipes are different side to side. Thank you for the help tho.
64 Chevelle 496
StevenS is offline
post #5 of 10 (permalink) Old Jan 31st, 11, 7:18 PM
Jordan
Hello,
Give Jim Cates a call at Magnaflow he is the Head Tech person 800-990-0905. He has always been able to solve any problems I have had with Magnaflow products.
Regards,
Don
JDP Motorsports
888-308-6007
post #6 of 10 (permalink) Old Jan 31st, 11, 7:34 PM Thread Starter
Thanks Don. I already have a contact into magnaflow. I sent them photos and they have reviewed them. But no solution as of yet.
64 Chevelle 496
StevenS is offline
post #7 of 10 (permalink) Old Feb 26th, 12, 9:02 PM
Cory
Steve,
Any solution yet?
'66 SS 396 #'s match/ POP - Aztec Bronze / Bronze Interior
'66 Malibu 454 Cortez Silver / Maroon Interior
'37 Chevy Coupe 235 Straight 6 - Cabana Cream`
'55 Chevy Gasser - 427, 4 speed
'72 Cutlass Supreme - Gold/White
dream66 is online now
post #8 of 10 (permalink) Old Aug 14th, 12, 7:04 AM
Steve,
Any solution yet?
I've got the same problem on my 64 coupe with that kit
Thanx
David
Davidmalibu is offline
post #9 of 10 (permalink) Old Aug 14th, 12, 6:30 PM Thread Starter
Hi David. They sent me another tailpipe and I installed tubular upper controls for more clearance. Fits better but not tucked up like I would like it to.
I am not liking the Magnaflow sound. So I am going to put flowmasters on. But I will buy offset offset mufflers. The offset mufflers will without a doubt tuck the tailpipes up were they should be.
64 Chevelle 496
StevenS is offline
post #10 of 10 (permalink) Old Aug 15th, 12, 4:39 PM
Andre
I had problems with the kit for 68-72, as the left u shaped pipe that goes over the axle did not match the right. The difference could only be seen when laying the 2 pipes on the garage floor in different positions. The result was a pass side pipe that was titlited upwards towards the bumper. Struggled for days until I realized it was the pipe and when I called them they told me to return it, and they would warranty the system but since the front was all finsihed and cut to size, I just had the muffler shop splice the rear section and weld it on at the correct angle - took an extra 45 mins of labor but I was there to have the joints welded up anyway. Magnaflow claimed it was virtually impossible for this to happen since the pieces are all robotically bent and cut but......
Having said that I got the kit for a great price and I do like the sound.
1969 SS396, Lemans blue, M21, 4.10 12 bolt, Matching #'s
BigBlockBeaumont is offline
This Thread is more than 1774 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
You may not post new threads
You may not post replies
