Bremerton Tech ? - Chevelle Tech
NW Northwest Region
post #1 of 12 (permalink) Old Feb 22nd, 08, 10:15 PM Thread Starter
Bremerton Tech ?
I was just the lucky recipient of a pair of decent used slicks and rims from a friend of mine. They are M/T ET Drag 28.0 x 10.5 x 15. They came with a set of 10" rims, but I need to change the backspacing or get different rims.
After listening to many of you talk about wheel studs with slicks, could someone tell me what the Track requirements are in general, as it pertains to running slicks with my setup. It is a stock open 10 bolt, but my friend said to use the slicks anyways. Also, he said I could run them tubeless or with tubes...any suggestions ?
It would be a drag to come all that way to get turned away at the gate, so here is a basic list of safety gear on my car,(or will be on it by the time I get there,). Please let me know if I'm lacking something for safety, for what I hope will be a 12 second or so car. Thanks.
10 pt cage, 5pt harnesses, Snell approved helmet and collar, no rubber fuel line, roll-over valve for fuel cell, oil pressure cutout switch for fuel pump, sealed battery box in trunk with external shut-off, drive shaft safety loop mounted w/i 6" of trans tail shaft, sealed firewall between trunk and pass. compartment, nitrous lines routed under car from trunk, expansion tank for rad, functioning neutral safety switch. I can't think of anything else.
Do I need a special licence to run there ? I am a total newb to sanctioned drag racing. Any input would be appreciated.
OutCast is offline
post #2 of 12 (permalink) Old Feb 22nd, 08, 10:24 PM
P evaD
Re: Bremerton Tech ?
No special License till You go under 10.0, I think.
I'd suggest open end lugnuts, with Your slick's.
With Those slick's, if You hook, You can kiss that 10 bolt GOODBYE.
Dave P.
1971 Chevelle
11.44 @ 118.43
Leading by example.
Curing cancer, one body panel at a time.
My Chevelle
now
Before
Motorvation
Resurection home page
Dave is offline
post #3 of 12 (permalink) Old Feb 22nd, 08, 10:53 PM
Frank
Those are the same tires I'm running and yes they hook, just ask my axel...
Frank
69SS 468/475hp M20 3.31 mutt
1/4 mile- 12.19@114mph mph
TC #3444
http://i52.photobucket.com/albums/g3...5/DSCN0173.jpg
flink69SS is offline
post #4 of 12 (permalink) Old Feb 22nd, 08, 11:20 PM
Doc. Smokum
If they are a straight up backspacing, they will fit with those rims (8 inch rim, 4 inch BS). If a 8 inch rim, a 4.5 BS is even better
1968 Chevelle Sb
1969 Chevelle 496
1973 SS 454 Chevelle
1974 S-3 454 Chevelle
1955 Delray LS1
1967 Nova 496
1969 nova 427
1969 Camaro 350
1968 Camaro Convertable 350
1968 Camaro Coupe 427
http://tcnwracing.com/
FRYNTYR is offline
post #5 of 12 (permalink) Old Feb 22nd, 08, 11:21 PM
Doc. Smokum
If running slicks you need a driveline loop for sure but you got that covered already.
1968 Chevelle Sb
1969 Chevelle 496
1955 Delray LS1
1967 Nova 496
1969 nova 427
1969 Camaro 350
FRYNTYR is offline
post #6 of 12 (permalink) Old Feb 22nd, 08, 11:23 PM
George
But 10s he probably will need a 5.5" BS, right?
What is the BS John?
Dave....are you watching this...15 x 10" ?
George Kettler
http://public.fotki.com/kettbo/gearhead/
o 68 Camaro Vert 327 project, painted, assembly stage http://www.camaros.net/forums/showth...183654&page=55
kettbo is online now
post #7 of 12 (permalink) Old Feb 22nd, 08, 11:26 PM
Doc. Smokum
Yes, a 5.5 b/s would be best with a 10 inch rim as the section width gets a bit wide and may touch the outside lip.
1968 Chevelle Sb
1969 Chevelle 496
1955 Delray LS1
1967 Nova 496
1969 nova 427
1969 Camaro 350
FRYNTYR is offline
post #8 of 12 (permalink) Old Feb 22nd, 08, 11:26 PM
P evaD
15 x 10, it's gotta be a 5.5 BS, or it aint gonna fit.
I bet it's 4" BS, and He need's to get to 5.5"BS. 10.5" tire, it's gonna have to have a 9-10" rim.
Dave P.
1971 Chevelle
11.44 @ 118.43
Leading by example.
My Chevelle
now
Before
Motorvation
Dave is offline
post #9 of 12 (permalink) Old Feb 22nd, 08, 11:44 PM
Frank
I ran mine on a 8" rim.
Frank
TC #3444
post #10 of 12 (permalink) Old Feb 22nd, 08, 11:49 PM Thread Starter
They were modded to fit his 65 Nova before he tubbed it. Had the centers brought way out. From the back of the bolt circle to the edge of the rim is 8". Not to mention they are dang ugly. What about the tube/no tube idea ?
BTW, do you see anything missing from my original list that will get me disq'd from the track ?
How his Nova looks these days. Ran a best of 10.21 at Mission last summer. 327 car with a little blue bottle.
OutCast is offline
post #11 of 12 (permalink) Old Feb 23rd, 08, 2:25 AM
Greg
That's a sweet looking car John. I didn't notice any primer, but maybe that's on the other side...
"the Special" SBC 355/TH350/12 bolt 3.90 posi
Best motor pass - 12.58 @ 107mph
Best nitrous pass (125shot) - 11.72 @ 115mph
http://www.cardomain.com/ride/2345518/1
66 Buick Special is offline
post #12 of 12 (permalink) Old Feb 23rd, 08, 2:30 AM
Check out the tech section here
http://www.bremertonraceway.com/
1966 SS Chevelle LQ4-4L80E
1965 SS Malibu Race car
1970 C-10 SWB Tow pig
www.u11racing.com
66SSFan is offline
