400 sbc - Chevelle Tech
post #1 of 7 (permalink) Old Dec 28th, 12, 10:06 AM Thread Starter
Shane
400 sbc
I have a 400 SBC in my 69...
The starter bolt holes are egged pretty badly.
Is it repairable? Costly?
I would like to take it out and get ready for the BBC I have on the stand.
fishhead is offline
post #2 of 7 (permalink) Old Dec 28th, 12, 10:35 AM
jackie
Re: 400 sbc
By egged, do you mean that the threads are stripped, or that the first 1/2 inch that is "fitted" is wallowed?
As a machinist, I could fix it by reaming the fitted part of the hole round and machining a bushing, but there is not a lot of room to play with there.
If the threads are stripped, you can heli-coil them and hope for the best. Since the Helicoil drill is larger than the fitted part of the hole, that will present a problem.
I guess your problem is the result of someone not using "starter bolts", or failing to tighten them correctly.
'67 Chevelle Malibu, Catalina Blue, 540 inch Rat, Air Flow Reasearch 290 CNC Heads heads, Custom Hyd Roller, .675 lift, 234, 244 at .050, Lemons Headers, TCI 6X 6Speed Automatic, 12 bolt Posi, 3:31 Richmond Gears, front and rear power disc brakes, Global West Suspension, etc.
http://www.chevelles.com/showroom/sh.../22377/cat/604
jackie schmidt is offline
post #3 of 7 (permalink) Old Dec 28th, 12, 10:50 AM Thread Starter
Shane
Re: 400 sbc
When I bought the car, ($1000) the previous owner did get it running but when I got it back to the shop, after taking it off the flatbed, the starter was hanging. I tried tightening the bolts, but they dont really tighten.
Threads were stripped, I have a helicoil in it now, and the bolts tighten up to a point, but I never took the motor out of the car to work on it properly.
The engine has been in my car since I bought it in 99. I havent put any miles on it yet, just quarters, paint, and an interior. I am doing a BBC now which will go in with the M22 I also have.
It is an early 400, if I remember 73 or 74. I also for some reason think its out of a Monza...dunno.
fishhead is offline
post #4 of 7 (permalink) Old Dec 28th, 12, 11:14 AM
Durand
Re: 400 sbc
Shane:
Monza's did not come with 400 engines (to the best of my knowledge), seems as if they came with either a 267 or 305 as largest V-8. Maybe the 400 is from a Monte Carlo or Caprice. Anyway, I wouldn't do anything with it other than tell any prospective buyer about the problem. Make sure you have the proper knurled starter bolts for your big block so you don't have a redo of this problem.
Durand
DFER is offline
post #5 of 7 (permalink) Old Dec 28th, 12, 11:19 AM Thread Starter
Shane
Re: 400 sbc
Originally Posted by DFER View Post
Shane:
Durand
Your right...
Its from a Truck. The flywheel I believe is out of a Monza.
fishhead is offline
post #6 of 7 (permalink) Old Dec 28th, 12, 11:38 AM
& Administrator
Re: 400 sbc
You better hope not.
The 305 the Monza had was internally balanced and the 400 is external.
uıɐbɐ ʎɐqǝ ɯoɹɟ pɹɐoqʎǝʞ ɐ buıʎnq ɹǝʌǝu ɯ,ı
Mike is offline
post #7 of 7 (permalink) Old Dec 28th, 12, 12:55 PM Thread Starter
Shane
Re: 400 sbc
LOL
I guess I really dont know.
I remember the flywheel didnt have its normal amount of teeth.
I'll get the numbers etc, and put them up here.
I know the starter took me quite a time to match.
fishhead is offline
