89 camaro sub frame work for a 66 chevelle - Chevelle Tech
Pro Touring Todays performance with classic style
post #1 of 13 (permalink) Old Nov 19th, 11, 10:39 PM Thread Starter
Ten
Tennessee
i bought an 89 camaro rs for pretty cheap guy sold it because he drove it when it was really low on oil so it messed up the engine anyways im wanting to take the sub frame off this camaro along with the clutch assembly and put it under my chevelle i will also put the 5 speed manual from the camaro in the chevelle the chevelle is a malibu two dr original 4 speed car i wanna know if it would work in my chevelle
Ten is offline
post #2 of 13 (permalink) Old Nov 19th, 11, 10:48 PM
& Administrator
Re: 89 camaro sub frame work for a 66 chevelle
Chevelle has a full frame ,are you going to cut off the front of the frame to replace it with the Camaro subframe?
And if so - Why?
uıɐbɐ ʎɐqǝ ɯoɹɟ pɹɐoqʎǝʞ ɐ buıʎnq ɹǝʌǝu ɯ,ı
Mike is offline
post #3 of 13 (permalink) Old Nov 19th, 11, 10:50 PM
Ethan
And if so - Why?
What Mike said.
Ethan
1972 Chevelle
(oo________oo)
Ethan1 is offline
post #4 of 13 (permalink) Old Nov 19th, 11, 11:00 PM Thread Starter
Ten
Tennessee
so i can use the rack and pinion steering and disc brakes
Ten is offline
post #5 of 13 (permalink) Old Nov 19th, 11, 11:01 PM Thread Starter
Ten
Tennessee
and i would cut the original frame to fit in the camaro frame
Ten is offline
post #6 of 13 (permalink) Old Nov 19th, 11, 11:11 PM
& Administrator
You might want to recheck the dimensions of both as I doubt the front clip (fenders,core support,grill,etc) will come close to fitting.
Don't think the frames will match up enough to graft together either.
Dale has some frame dimensions listed so have a look.
Mike is offline
post #7 of 13 (permalink) Old Nov 19th, 11, 11:23 PM Thread Starter
Ten
Tennessee
thanks for the help
Ten is offline
post #8 of 13 (permalink) Old Nov 19th, 11, 11:49 PM
That's actually not a subframe, more like just a bolt in crossmember. It's a strut like front suspension, you need strut towers too. Really don't think it's feasable.
72 Chevelle SS conv http://www.fquick.com/454ragtop
72ragtop is offline
post #9 of 13 (permalink) Old Nov 20th, 11, 12:18 AM
Resident A-hole
Without being a total jerk, this is one idiotic idea. I will tell you why
1) Gen3 Camaros arent exactly known for their superior handling. Even in their time they werent corner carvers, so spending the amount of time and money on just getting that suspension on the car is like running the Boston Marathon backwards, admirable to some but bewildering to most.
2) There is much more aftermarket support for an A body as far as handling equiptment and it works a lot better than whats available for a 3rd Gen.
3) If all you are doing this for is R&P steering, there are companies that make ready to go kits that get you that without any cutting. Unisteer is the one that best fits that application and the one Id use.
Beyond that, I seriosly hope you are joking cause this is probably one of the worsy conceive ideas Ive ever heard of. Now it you said I have a DSE subframe for a 1st gen then Id be giving a few thumbs up but since you arent I think you need to shelve this horribly assembled idea.
1964 Malibu 5.3 LS twin turbo aka Maliboost coming soon BUT YOU WONT SEE IT HERE
Matty B is offline
post #10 of 13 (permalink) Old Nov 20th, 11, 8:49 AM
Thomas
Put a disc brake kit on it for a 66 chevelle, change the steering box to a 93-97 jeep grand Cherokee steering box. Do it all in a day and call it done.
http://www.carolinachevelle.com
Carolina Chevelle Association
TC # 688
ACES 2759
PeachState Chevelles
http://www.chevelles.com/forums/albu...pictureid=6381
66 malibu wagon, 327, AC, pw.
67 chevelle 300 deluxe post, LT1-4L60E, 3:36-10 bolt posi,AC,tilt,pw,pl, Autometer gauges,custom dash
"I think we have more machinery of government than is necessary,
too many parasites living on the labor of the industrious."
--Thomas Jefferson, letter to William Ludlow, 1824
elcamino66 is offline
post #11 of 13 (permalink) Old Nov 20th, 11, 4:50 PM
Derrick
no, no you cannot use the subframe from a 3rd gen Camaro in a Chevelle... and, no, the Camaro doesn't have rack and pinion steering..
stick with the basics and learn what you are doing.. disc brakes from a 69-72 Chevelle or any other A body are easy to bolt on. stock replacement Moog rebuild parts for the suspension are available at any parts store. a tighter steering box can be found in the junkyard. stiffer springs and better are readily available.
but the most important thing it to learn the basics before you start spending thousands and thousands of dollars on aftermarket parts that look cool but might not make the car any better for what YOU want out of it.
-Hank Hill
novaderrik is offline
post #12 of 13 (permalink) Old Nov 20th, 11, 4:57 PM
Paul
You should sell your chevelle to someone on this forum and build up the Camaro.
454/T400/9" in a 67 Beaumont
Paul-ish is offline
post #13 of 13 (permalink) Old Nov 20th, 11, 5:19 PM
Send a message via AIM to Hot66ss
Please tell me this is a joke.
21st Century Performance
(310) 425-8700
67 Velle- AFR headed 509/4L80 Pro-Touring.
70 Chevelle- Latest project
03 Mustang Cobra Terminator 512RWHP/498RWTQ
68 Vette, Documented 427/435hp Tri Power, 4 speed- Sold
70 SS LS6/M22 Documented, black/white stripes- Sold
Hot66ss is offline
