4l60e trans question - Chevelle Tech
Pro Touring Todays performance with classic style
post #1 of 8 (permalink) Old Apr 28th, 11, 4:35 AM Thread Starter
scott
My 2000 lq4 6.0 came with a 4X4 4l80e trans. Iím installing a 4l60e trans in the car. I hooked the two together and not all the bolts have holes, no big deal. Iím getting a 4l60e flex plate from auto zone and had the ECM and harness has been redone for the 4l60e.
1, I think the 4l80e flex plate has a spacer; I remove this to put on the 4l60e flex plate right?
2, on the 4l80e trans it had a two piece bell housing the 4l60e donít and now I have a open spot on the lower side. Is there a plate that goís in there like the old 350 trans?
3, will the stock 4l60e T/Q be ok for now? On modís on the 6.0 YET
4, what do you all do about a drive lines? I was thinking of junk yard van or truck one and having it cut to fit. If I do this it will fit the trans but what about the axel. Itís a 10 bolt in a 1968
455bird is offline
post #2 of 8 (permalink) Old Apr 28th, 11, 11:02 PM Thread Starter
scott
Re: 4l60e trans question
no input
455bird is offline
post #3 of 8 (permalink) Old Apr 28th, 11, 11:14 PM
the 4l80 takes a different flex plate and converter... drive shaft yoke also different....out put shaft different from 2 wheel to 4 by 4.....4 by is shorter...4l80 has a 6 bolt t/c 4l60 has 3...and it will bolt up to the block.....THX Tom
427yenko is offline
post #4 of 8 (permalink) Old Apr 28th, 11, 11:34 PM Thread Starter
scott
I know the flex plate and T/Q are different. I got the stock 4l60e T/Q and getting a new flex plate from auto zone. My 4l60e is a 2 wheel drive one, but when I pull the flex plate off the motor that had the 4l80e it has a spacer with it right?
Thatís good info on the drive shaft I did not know they were different
What about the bell housing space?
455bird is offline
post #5 of 8 (permalink) Old Apr 29th, 11, 11:08 AM
Neal
You shouldn't need a spacer for the 4l60e. I am not sure if the flexplates are different part numbers or not. You can do like I did and get an old 350 style inspection cover to cover up the hole on the bottom of the trans. I am sure there is a better solution but I had one laying around. Honestly, I wouldn't even think about messing with the 4l60e if I had a 4l80 in good shape in hand. Swap out that tailshaft on that 4l80 and put it there. You would never have to worry about tranny issues even with 500+ rwhp.
1967 Chevelle
LS1 swap is completed!
www.fquick.com/pist0lpete
12.70 at 108.95mph
pist0lpete is offline
post #6 of 8 (permalink) Old Apr 29th, 11, 10:28 PM Thread Starter
scott
no i did not get the 4l80 with the motor
455bird is offline
post #7 of 8 (permalink) Old Apr 30th, 11, 4:29 AM
Derrick
i don't know about the 4L80E, but on pretty much every other GM transmission the 4X4 version has a shorter output shaft to mate up with the transfer case and isn't machined for the reluctor wheel for the VSS, so it's not just a matter of bolting on a 2wd tailshaft and calling it good... but you can make a 2wd trans bolt up to a transfer case by cutting a few inches off the tailshaft.
regarding the driveshaft for a 4L60E- if you have a driveshaft for a TH350, then you will just need to shorten it a few inches and put it in. might as well put in new u joints while it's apart.
-Hank Hill
novaderrik is offline
post #8 of 8 (permalink) Old Apr 30th, 11, 6:33 PM
Resident A-hole
Your Lq4 may or may not have a spacer. Some of them had a longer crank flange ie 99-00 with 4l80..... I know for certain the longer crank flange motors cant be used with a manual trans, dunno how they swap between the 4l80s and 4l60s though.
1964 Malibu 5.3 LS twin turbo aka Maliboost coming soon BUT YOU WONT SEE IT HERE
Matty B is offline
