Cig Lighter removal & wires? - Chevelle Tech
  • 1 Post By Notes
post #1 of 6 (permalink) Old Jun 17th, 17, 7:42 PM Thread Starter
Bet it’s easy. Wiring is disconnected. How do you remove the assembly? And - is the black wire a factory ground that I could use for aftermarket head unit & amp? Thanks
Notes is offline
post #2 of 6 (permalink) Old Jun 17th, 17, 8:37 PM
Claude
Re: Cig Lighter removal & wires?
Once the wires are off, unscrew the sleeve (from behind the dash) which is screwed onto the lighter socket and it should come out.
Claude.
1971 Chevelle "SS 496"
toofastforyou is offline
post #3 of 6 (permalink) Old Jun 18th, 17, 8:38 AM Thread Starter
Finding out why you said “should” & included the winking emogee, Claude. Hope my lug nuts are screwed on as tight as the lighter is.
Notes is offline
post #4 of 6 (permalink) Old Jun 18th, 17, 9:11 AM
The orange is a constant hot, and the black is the ground.
RealRed70 is offline
post #5 of 6 (permalink) Old Jun 18th, 17, 9:47 AM
Claude
I used the word "should" because with these old cars, sometimes things which are normally simple don't always end up being as simple as we first thought they'd be… and the emogee was for…well…"good luck" in removing it.
Claude.
post #6 of 6 (permalink) Old Jun 18th, 17, 9:52 AM Thread Starter
Got it. I wasn’t holding my tongue right, I guess. It’s not quite round anymore, but I’m not going to use it anyway. Thanks!
wihaltom likes this.
Notes is offline
