Adapter for jack for use with rear sway bar - Chevelle Tech
 7Likes
  • 1 Post By oldcutlass
  • 1 Post By 1967 chevelle malibu
  • 1 Post By tireburner396
  • 2 Post By 1966_L78
  • 1 Post By Dave Birdwell
  • 1 Post By 1966_L78
post #1 of 14 (permalink) Old Apr 15th, 17, 8:10 AM Thread Starter
Since I have installed a rear sway bar it is a pain to jack the rear at the bottom carrier housing. I have been using a block I made to clear the sway bar and still catch the bottom of the housing. But I have to be careful it is placed just right.
Does anyone make an adapter for a floor jack that would help ? Or anyone have made something them selves? Thanks
james a larson is offline
post #2 of 14 (permalink) Old Apr 15th, 17, 8:25 AM
Re: Adapter for jack for use with rear sway bar
I've never had any issues, I just place the jack forward enough to clear the sway bar and yet center under the pumpkin.
Pats70ss likes this.
2006 Ford Mustang GT (momma's car)
http://s1141.photobucket.com/albums/n587/oldcutlass/
http://s1141.photobucket.com/albums/...lass/plymouth/
oldcutlass is offline
post #3 of 14 (permalink) Old Apr 15th, 17, 9:31 AM
Rob
I saw it here a while back......
I bought a small rubber wheel.....6" diameter.
And modified it to sit securely in my jack cup.
Then I installed the pro tour rear bar that mounts to the axle and moves bar enough that adapter not needed lol
robpp is offline
post #4 of 14 (permalink) Old Apr 15th, 17, 10:10 AM
gary
I put a short piece of wood between the top of the bar & bottom of the rear.
71350SS likes this.
post #5 of 14 (permalink) Old Apr 15th, 17, 10:36 AM
Hank
I have a Hein Warner jack that has about a 5" saddle on it. I just put a 2x4 on the jack saddle push the jack under the housing in front of the ridge of the housing where the bolts go and jack it up. The 2x4 gives it just enough clearance to clear the bar.
71 Malibu, 396BBC, 4 speed, 12 bolt.
HKalin is offline
post #6 of 14 (permalink) Old Apr 25th, 17, 9:04 PM
I do the same.Works fine,simple solution and no damage or slipping.
71 El Camino SS
406 SBC M21 3.31 12 bolt
71350SS is offline
post #7 of 14 (permalink) Old Apr 26th, 17, 4:41 PM
I just position the lip of the cup on my jack between the sway bar and the bottom of the differential.
1966_L78 likes this.
tireburner396 is offline
post #8 of 14 (permalink) Old Apr 26th, 17, 6:35 PM
IIRC, that's what I used to do... I'd place the jack under the rear, but just in front of the sway bar, and as the cradle cleared the sway bar, I'd pull the jack back. The cradle of the jack was oriented (by me), with one of the four "teeth" being behind the rearend cover, which helped (in my mind) keep the car from sliding "forward" off the jack...
Of course, the last time I used that "factory" sway bar was 1985... But I still have the same jack...
tireburner396 and OLDED like this.
TC #1366
'70 Chevelle 427 Stroker
'66 Convertible Sold
Dual Quad 396 & Conv Int
'66 SS L78
1966_L78 is offline
post #9 of 14 (permalink) Old Apr 26th, 17, 7:13 PM
Hank
The problem I see with this is your jacking the car with the edge of the saddle instead of spreading the weight over the center of the saddle which isn't a very good practice either. Have you ever seen a jack with an edge cracked off of the side of the saddle, I have.
HKalin is offline
post #10 of 14 (permalink) Old Apr 26th, 17, 8:09 PM
Lance
FWIW....I just bought a pair of "rubber" pads from Summit just for this purpose..to protect the chassis while jacking, about $7.00 each if I recall. Does just what is advertised.
vortec710 is offline
post #11 of 14 (permalink) Old Apr 27th, 17, 6:35 AM
Hans
When I had a 12-bolt my jack saddle just barely did fit in between the sway bar and the differential. Since converting to a 9" the sway bar sits maybe a 3/4" below the differential housing, no way to get the saddle in between there. I just put the jack under the sway bar and it gets pushed up a bit before the saddle corners catch......I see no harm in it.
1969 Chevelle SS, zz454HO, Sniper EFI, Bowtie 200r4, 4.11's (money pit)
2015 F-150 KR 5.0 4x4 Crew (DD and dog hauler)
2012 BMW 128i convertible (wife's)
71_340 is offline
post #12 of 14 (permalink) Old Apr 27th, 17, 11:23 AM
Ron
I have always just put the saddle under the sway bar in the middle and jacked it up that way, the sway bar goes up against the housing and doesn't hurt anything. Been doing it like this for decades.
70 Chevelle SS396 (496) Straub roller, M21
69 Malibu convertible
TC #54 Gold
69 - Top down
69 Top up
new wheels
70 side
On Gearz
ToocoolZ28 is offline
post #13 of 14 (permalink) Old Apr 27th, 17, 11:32 AM
Chevelle Doctor
Me too. 33 years of jacking cars and never had an issue.
Dan Orgill likes this.
Dave Birdwell is offline
post #14 of 14 (permalink) Old Apr 27th, 17, 1:35 PM
In reality, this isn't the case...
The rear of the saddle goes between the housing and the swaybar, and the saddle "teeth" kind of hook around the back/cover... But the front of the saddle also contacts the bottom of the rearend, so the weight was being supported on both sides of the saddle, and therefore the weight is distributed to the center of the saddle...
For mine, it was exactly the same as jacking without the swaybar, EXCEPT you had to push the saddle in front of the sway bar, raise the jack slightly, and pull the jack/saddle back over the swaybar (obviously just the edge of the saddle over the swaybar)...
If the saddle is only under the middle of the differential, the jack can slide, which is why I like to "hook" the saddle ahead and behind the cover flange.
I have never seen a saddle break.
tireburner396 likes this.
TC #1366
'66 SS L78
1966_L78 is offline
