Fuel tank question on a 64 - Chevelle Tech
post #1 of 6 (permalink) Old Mar 20th, 17, 4:06 PM Thread Starter
Hey guys just a quickie here. I have a new tank and noticed there are two openings on it. One on the upper passenger corner, and one in or out line on the float/sending unit. Which one does what?
alwaysavocado is online now
post #2 of 6 (permalink) Old Mar 20th, 17, 4:19 PM
Rame
Re: Fuel tank question on a 64
I think the one you pinky finger is pointing at is for the vent line that goes to the canister under the hood, just a guess I could be wrong.
sampoerna415 is offline
post #3 of 6 (permalink) Old Mar 20th, 17, 5:20 PM
Keith
no charcoal canister under the hood on a 64. the small one in the upper corner is a vent line that connects via hose to a other vent line that runs up into the trunk and back out
1994 Corvette coupe LT1 auto
Maryland Chevelle Club #682
keithb is offline
post #4 of 6 (permalink) Old Mar 20th, 17, 5:33 PM Thread Starter
Thanks. That makes sense I see the steal looped line in the trunk on the right. I would have guessed it was the other way around. So the one in the center is the main feed line that goes to the engine/carb/fuel pump .
Do you guys know if there is a padding or material that goes in between the fuel tank and the metal straps that hold the tank up?
post #5 of 6 (permalink) Old Mar 20th, 17, 6:17 PM
Yes, there is an anti squeak material available. Some folks use strap material, heck, i saw one fella use several layers of duct tape. The original appeared to be sort of a felt like material.
The Deejay is offline
post #6 of 6 (permalink) Old Mar 20th, 17, 8:13 PM
Keith
use roofing felt
keithb is offline
