anti-theft recommendations for our Chevelles? - Chevelle Tech
 21Likes
post #1 of 31 (permalink) Old Feb 14th, 17, 12:05 AM Thread Starter
Ken
I'm looking for a way to make sure my Chevelle is not "borrowed" while I'm gone. Does anyone have a favorite anti-theft system that they've had good luck with?
kls89027 is offline
post #2 of 31 (permalink) Old Feb 14th, 17, 2:11 AM
Hank
Re: anti-theft recommendations for our Chevelles?
This is the best thing going.
71 Malibu, 396BBC, 4 speed, 12 bolt.
HKalin is online now
post #3 of 31 (permalink) Old Feb 14th, 17, 4:01 AM
Marc
Red One Touch Engine Start Kit with RFID autoloc.com
Wire this into ignition and unless the fob is near the car it just won't start
1970 Chevelle SS 8.1 vortec TKO 600 12 bolt 3.08
1958 Apache 3800 1 ton dually 8.1 vortec 4L80E 14 bolt 5.14
2006 2500HD 8.1 vortec Allison 4.10 4X4
My personal website
http://www.marccuslidge.com/
The 8.1 performance parts store!!
http://www.raylarengineering.com/index.html
1970ss8.1L is offline
post #4 of 31 (permalink) Old Feb 14th, 17, 4:26 AM
Geoff
There are lots of choices, from cheap to expensive. In my car, I have HEI ign which uses a relay to supply power to the HEI. I have a small hidden switch that disables the relay.
wihaltom and lucifershammer like this.
Gtogeoff is offline
post #5 of 31 (permalink) Old Feb 14th, 17, 9:36 AM
An excellent insurance policy...
Kirk's67SS likes this.
hydro462 is offline
post #6 of 31 (permalink) Old Feb 14th, 17, 10:28 AM
I wired a push button switch in the cigarette lighter socket, connected the wires to the NSS circuit. So to prevent the casual drive off, push the lighter once to disable starting, push again to enable. Looks stock, but probably doesn't deter any determined thief.
Today 50% of all marriages end in divorce, but 100% of car part deliveries end in happiness.
72 Chevelle Malibu 327/350 Restomod
57 Chevy Bel Air 283/Powerglide
96 Ford Ranger (aka Truck Norris)
The problem with trying to make something completely foolproof, is you underestimate the ingenuity of complete fools. - Douglas Adams
72 Malibu 327/350 Restomod in progress
57 Bel Air 283/Powerglide
96 Ford Ranger aka Truck Norris (daily driver)
db11020 is offline
post #7 of 31 (permalink) Old Feb 14th, 17, 12:46 PM
How about a sign in your car window: " This car is protected by a man with a shotgun, THREE days each week. You guess WHAT three days. "
barnfind69 and Kirk's67SS like this.
Robinls5 is offline
post #8 of 31 (permalink) Old Feb 14th, 17, 2:05 PM
This is best, anyone who knows these cars realizes that a jumper wire and screwdriver will allow you to drive one away. So any alarm, goofy hidden switch, etc... will not save the car from being stolen. In addition, a to truck can just hook onto it or drag it on to a flat bed and drive off.
2006 Ford Mustang GT (momma's car)
2006 Ford Mustang Coupe (kids car)
http://s1141.photobucket.com/albums/n587/oldcutlass/
http://s1141.photobucket.com/albums/...lass/plymouth/
oldcutlass is online now
post #9 of 31 (permalink) Old Feb 14th, 17, 2:28 PM
Verle
It is more difficult to drive away if the ignition is grounded.
Verle
Tulsa, Ok
http://i877.photobucket.com/albums/a...e6June2010.jpg
Verle is offline
post #10 of 31 (permalink) Old Feb 14th, 17, 2:40 PM
This question has been asked many times on several forums---------------------------------------------------my position has NEVER changed!
Tom Parsons
TC# 474
#3 FOREVER!!!!!
DZAUTO is offline
post #11 of 31 (permalink) Old Feb 14th, 17, 2:55 PM
Just worked on something for my car.
Separate switches disable the ignition12 volt, mess with the MSD distrib ground and kill the juice to the starter. It is a tiny tiny bit involved to shut it down when it is parked in a spot outside my garage, kinda like shutting down an aircraft...a few switches here and there all gotta be right. In one circuit I have two hidden on / off toggles and a 5 way switch (all hidden) that have to ALL be set in the correct position for 12 volts to flow to the MSD 6al and the MSD distrib. You gotta find the switches, then set them right from the 20 possible combinations on that one circuit. IF ya get that right it still won't start because the distrib. ground is on another hidden swihch. IF they get BOTH of those disablers right there is still no juice to the starter because of what I did with the NSS.
The comment about the screwdriver is very true IF they get the ignition on BUT the way mine is rigged they have more than a smash and twist on the key in the column. The screwdriver will indeed turn it over but there is more to be done and I doubt the average thief is gonna find all the switches and methodically try all the combinations. Sure sure the warning about "If they want to______" applies as always but at some point you need to think about where you are leaving the car, time of day, neighborhood...... and all that.
Overkill....maybe then again finding an empty parking space after going into the Depot would really ruin my day.
deffmike likes this.
oman is offline
post #12 of 31 (permalink) Old Feb 14th, 17, 5:13 PM
Marc
My c10 had the nss wired through the floor mount headlight dimmer, a hold down button after that , a kill switch to the ecm and a case hardened eye bolt in the floor with a hole drilled through the e brake petal and a case hardened padlock through it after pressing down to the floor. I not only wanted it to not start buy not roll either. I also had a cool lock that hooked the brake petal and locked around the steering wheel so the wheel couldn't be turned. Two weeks ago someone rolled my buddy's nova on a trailer stealing it from a parking lot. I saw a guy once who put a boot on his mustang when it was parked.
My personal website
post #13 of 31 (permalink) Old Feb 14th, 17, 5:27 PM
Claude
This: Ravelco Anti Theft Device. It makes the car virtually impossible to start unless you have the special "plug". I have it on my pickup truck. It doesn't have any electronic or any moving parts that are subject to wear and also it cannot be "disarmed" by some crooks who have some kind of "disarming devices".
Claude.
1971 Chevelle "SS 496"
toofastforyou is offline
post #14 of 31 (permalink) Old Feb 14th, 17, 5:48 PM
A disarming or disabling device---------------------------no matter how sophisticated it is, will NOT stop a rollback-----------------------------but my .44mag will!!!
Tom Parsons
TC# 474
#3 FOREVER!!!!!
DZAUTO is offline
post #15 of 31 (permalink) Old Feb 14th, 17, 5:51 PM
Only if you are there waiting for the roll back to show up.
ashgoldchevelle likes this.
oman is offline
