67 chevelle bigblock frame mounts - Chevelle Tech
 5Likes
post #1 of 29 (permalink) Old Jan 11th, 17, 1:28 PM Thread Starter
robert milliman
Question 67 chevelle bigblock frame mounts
working on my sons car67 136 283 power glide car now 1977 454 turbo 400 12 bolt cant get past this wall. bought big block repo frame mounts differnt oil pan dont hit any more just stock exhaust or header wont fit her are some pic i hope thanks bob
ID:	413274   Click image for larger version
ID:	413282   Click image for larger version
bigblockbob is offline
post #2 of 29 (permalink) Old Jan 11th, 17, 3:51 PM
Terry
Re: 67 chevelle bigblock frame mounts
Which engine motor mounts are you using? Ones for a 67?
Terry who is offline
post #3 of 29 (permalink) Old Jan 11th, 17, 4:38 PM Thread Starter
robert milliman
it was in a kit frame and engine .i used the holes in the frame only had 3 holes .dont know frame mount hangs over the frame a lot thanks
post #4 of 29 (permalink) Old Jan 11th, 17, 5:28 PM
Greg.
Same thing I did to my 67
bought the Engine/Frame Mounts from GrdUp
No problems with installing 75 Truck 454
Having trouble with Photo Bucket of pics with them attached to Frame
67 Chevelle Malibu SS Cdn
Born 283 / PG / A51
Now 468/Th400 2,500 stall/ S60 3.70 Gs
Prev M&H MSS001 street Tires/dress 2015/9/20
60' = 1.756 1/8 = 7.815 et / 89 mph
1/4 = 12.253 et / 111 mph
NEW Best on M/T S/R #6641 street Tires/dress 2016/10/9
60' = 1.720 1/8 = 7.747 et / 89 mph
1/4 = 12.112 et / 112 mph
Kirk's67SS is offline
post #5 of 29 (permalink) Old Jan 11th, 17, 6:04 PM
I used the bb engine/frame mount kit from Groundup. Dropped right in to my Olds.
2006 Ford Mustang GT (momma's car)
http://s1141.photobucket.com/albums/n587/oldcutlass/
http://s1141.photobucket.com/albums/...lass/plymouth/
oldcutlass is offline
post #6 of 29 (permalink) Old Jan 11th, 17, 6:26 PM
T_R
I can't tell much from those pictures. What is the exact problem?
You need a chevelle oil pan. They are different than truck pans and what fits a camaro or vette won't fit an early chevelle. Even with the correct oil pan it is very close to the crossmember. Mine is about 1/4 away or less even after denting the pan for clearance.
Some of the reproduction frame mounts aren't quite right. Some of the aftermarket engine mounts aren't quite right either. Combine those and it can be off quite a bit. I had to flatten out the top of one of mine and also open up the hole in the engine mount to get the motor to drop down and get the bolts in.
The exhaust manifolds are very close to the steering shaft. I had to grind some off the manifold so the shaft didn't hit them.
T_R is online now
post #7 of 29 (permalink) Old Jan 11th, 17, 8:59 PM
I have also heard of people having fitment issues with reproduction BBC engine mounts. FYI when I swapped the 454 from my 71 Chevelle into my 66 Chevelle, I had to change the oil pan. The aftermarket oil pan that cleared in the 71 would not fit the 66. Good luck with your project.
dell72 is offline
post #8 of 29 (permalink) Old Jan 12th, 17, 2:00 AM
From your first picture, that does NOT look like a "Chevelle" exhaust manifold (drivers side)...
It is really difficult to see though, but the Chevelle (65-72) manifolds have clearance "dimples" for the steering shaft... Those dimples don't affect the clearance issues you have, but would help identify the manifolds. Generally, non-Chevelle manifolds (at least driver's side) will hit the frame at the manifold outlet, and therefore NOT sit flush on the head (as your pictures show with your manifolds)...
Do you know the casting numbers on the exhaust manifolds you have?
Ground Up and others offer repro manifolds that should fit.
1964-1972 Chevelle Big Block Exhaust Manifolds Without Smog
While these a technically for a 68+ Chevelle, the fit is the same. If you look at the picture, you can easily see the steering shaft clearance dimples on the #5 and #7 runners of the driver's side manifold (which are clearly missing on your manifold)
Next, the second picture appears to show the oil pan sitting on the cross member... at least it doesn't look like enough clearance to get the mounts bolted together even if everything else clears...
What pan do you have? Impala, truck and Corvette pans will NOT fit a Chevelle chassis.
I have used a Summit oil pan with great success (SUM-3510X). Under $40, fits great in my '66, and looks/feels like an OEM pan...
https://www.summitracing.com/parts/sum-g3510x
TC #1366
'70 Chevelle 427 Stroker
'66 Convertible Sold
Dual Quad 396 & Conv Int
'66 SS L78
1966_L78 is offline
post #9 of 29 (permalink) Old Jan 12th, 17, 9:22 AM
Lew
Look at the lemons headers website the big block frame mounts need to be like 1.25 or 1.5??? inches high from base to center of bolt hole. If you need to just buy some headers it may be a little louder but it will make a lot more power than the stock manifold. On a 454 LS6 motor cost if like 60+ hp. The 454 LS6 the 450 number was with headers and like 385 with the manifold on it.
Lew540 is offline
post #10 of 29 (permalink) Old Jan 12th, 17, 8:53 PM Thread Starter
robert milliman
some pictures or frame without motor and mounts .my problem the header and stock didnt fit or oil pan .got differnt pan and motor mount kit from ground up exhaust still dont fit oil pan fits now .the factory hole in frame should i have differnt locactions where shuould i go next any help thanks bob
ID:	413594   Click image for larger version
post #11 of 29 (permalink) Old Jan 13th, 17, 11:14 AM
My 67 Chevelle Malibu came with a 327 and powerglide... I had 2 sets of hole for my mounts to use. With the small block the motor mount brackets used the set of holes, to bolt to the frame, that were closer towards the center of frame.
When I dropped the big block in I went to the big block brackets and bolted them to the out side holes on the frame, farther away from frame center.
I only see one set of holes to bolt your mount brackets to frame. Maybe that's why they are not letting your engine set into your frame correctly?
I don't have a picture online, but I can upload one when I get back home.
HotWheelsFan is offline
post #12 of 29 (permalink) Old Jan 13th, 17, 2:31 PM
Not saying yours is incorrect, but I have had well over 15 1966 & 1967 Chevelles, and have not seen more than one set of holes for the frame mounts. The BB and SB SHOULD use the same holes.
Small block frame mounts will work when installing a BB, but you won't be able to use the BB block mounts, as those had the "T-bar" safety strap, which requires the "BB" frame structures... But either SB or BB frame mounts should place the engines in the exact same location. You can use the original SB frame mounts with Small Block rubber mounts on a big block, and the location will be the same as a factory BB (this is for 66/67 only)
To the OP, are you trying to fit headers (tubular aftermarket)? If so, are you sure they are for 66/67 Cheveles? Many header designs are listed as '68-72 Chevelle/A-body, and may have some clearance issues, especially in the earlier cars (often, the header tends to hit the rear-side of the main crossmember. Tubes can be dimpled for clearance... And once it fits, makes sure you have clearance at the brake lines across the crossmember...
Where are the headers hitting? It pretty common for some tubes to hit the rear side of the crossmember.
As mentioned previously, the stock exhaust in your pictures are NOT for a Chevelle chassis. Not sure where your interference issues are...
Your earlier pictures, were those with the old oil pan? Because it sure looked like the oil pan did NOT clear the crossmember.
At this point, I'd be looking at possibly different issues. #1 make sure the oil pan is a "Chevelle" specific pan. #2, try to install the engine without using the exhaust, and let us know if you can't get the mounts bolted together. If not, WHERE is the interference? #3 Once you get the motor mounting figured out, THEN try the exhaust with manifolds/headers specifically for a Chevelle chassis. Get some more pictures of where the engine is hitting...
Looking at this picture and the picture of the bare frame & mount, it looks like perhaps the engine needs to go rearward another 1/8 -1/4 Inch. It looks like the rear ear of the rubber mount is hitting the top of the frame mount... Is the transmission loose with driveshaft removed? Have you confirmed that the rubber mounts fit over the frame mounts (without the engine)? I have experienced some where the "ears" were bent and would not slide/fit over the frame mount...
What brand and part# on the headers? What casting numbers on the exhaust manifolds? What brand/part number on the oil pan?
Could be the reproduction frame mounts...
TC #1366
'66 SS L78
1966_L78 is offline
post #13 of 29 (permalink) Old Jan 13th, 17, 5:46 PM Thread Starter
robert milliman
iam sorry replaced oil pan works now . stock exhaust dont fit .is their only 3 holes in each side of frame this was a 136 car is that ok then ill try to find factory frame mounts thanks bob
post #14 of 29 (permalink) Old Jan 13th, 17, 6:14 PM
That manifold, #3884503, is for a 65/66 Fullsize car (Impala, Biscayne, etc). This will NOT fit a Chevelle!
I tried to use those same manifolds on a '66 Chevelle years ago, and had a similar problem...
You need "Chevelle" exhaust manifolds, at least for the driver's side...
So, the mounts still don't fit, but the oil pan does?
As for the mount issue, Do you have the original small block frame mounts and rubber block mounts? Maybe try those Small Block pieces temporarily. The SB stuff will fit the BB, and then you can see IF the repro BB frame mounts are the problem or not... Small Block and Big Block mounts ( for 66/67) will put the engine in the exact same position.
TC #1366
'66 SS L78
1966_L78 is offline
post #15 of 29 (permalink) Old Jan 13th, 17, 6:19 PM
Greg.
Bob it appears that the Frame mounts/Holes are not towards the firewall enough
based on the pics that I sent you of my Front Cross member
I would install the Engine mounts to the engine then install the Frame mounts to them
to see if they fit together easily/correctly
Then lower the Engine down to Front Cross Member
and see if the Frame Mount Holes lineup with the Cross member holes
The Engine with the Distibutor on it should have a distance of/about 2 to 3" from the Firewall
71350SS likes this.
Born 283 / PG / A51
