Is this a good running gear setup? - Chevelle Tech
post #1 of 5 (permalink) Old Jun 12th, 05, 3:33 AM Thread Starter
Engine- 350ci 330hp
Trans- 700R4 2000 stall
Rear- 2.73 ratio
Should this setup work okay for street use? No racing in the plans. Should the ratio be in the 3's? What is the expected performance? Fast off the line, or high-end?
Thanks again!!
Malibu Marci's Showroom
If it's not a V8, it ain't worth driving!
Marci is offline
post #2 of 5 (permalink) Old Jun 12th, 05, 8:49 AM
Re: Is this a good running gear setup?
3:73 would be a whole lot better - The 2:73 would be fine with a non overdrive trans but I think that it will be a little tall for a 4 sp, auto. It would probabally work but you might not get it to lock up correctly in 4th. because of the gear.
LK
Alwhite00 is offline
post #3 of 5 (permalink) Old Jun 12th, 05, 10:07 AM
I have the 330 horse engine, 700R4 and a 3.33 in my wagon, which would be heavier than a coupe by a few hundred pounds. The gas mileage is close to 20mpg on the highway but the car is a little sluggish on hills in overdrive. I am thinking of switching out to a 3.55 or at least a 3.42 to pick up a little oomph off the line and better o/d performance. 3.73's would be great, but the gas mileage may suffer a bit.
65MALIBU 4 door wagon, Disc brakes, F41 suspension, GMPP 350/330hp crate engine 700R4trans, http://www.facebook.com/album.php?ai...4&l=3194cb2bc5http://chevelles.com/feature/september2004.html
JimN is offline
post #4 of 5 (permalink) Old Jun 12th, 05, 11:12 AM
3.42 would give you a better off the line ratio than a 4.11 and 3 speed auto, while giving you the benefit of a final drive ratio of 2.4. Go too steep with the rear gears, and the 700's 3.06 1st will be too steep, and much less than 3.08 and you have the wide ratio from 1st to 2nd dropping RPM too much and hurting performance a little. IMO 3.23-3.42 for a SB street combo would be ideal.
69 Malibu. It donated it's ZZ4 to my stepside, so a junkyard 454 is pending. Stay tuned....
ZZ69chevelle is offline
post #5 of 5 (permalink) Old Jun 12th, 05, 5:00 PM Thread Starter
When I decoded my ratio, and saw it wasn't 3-something, I knew I'd have to change it. It should be worth it when I'm done though. Thanks for the advice
Marci is offline
Confirmation of high volume pump causing loss of pressure @ 4750 rpm! Unclepennybags Engine 40 Aug 22nd, 08 11:38 AM
12 bolt setup Ron454 Transmission & Driveline 5 Jan 7th, 05 3:33 AM
Need internal speedo gear for Muncie M21! Please help? jgoggan Transmission & Driveline 18 May 5th, 04 1:09 PM
Speedo gear and drive gear question blumont Transmission & Driveline 2 Apr 21st, 04 2:43 PM
Why does my car run good again?? 73Malibu 1999 -- 6 Jul 16th, 99 10:05 PM
