Hi Guys
Anyone here use the ARP ultra torque fastener assembly lubricant? I have the directions and it says to use blue 242 loctite on the flywheel threads and then apply the ARP lube on the underside of bolt head. After that torque to 85lbs. Last time I did that i noticed that the lube spun onto the flywheel and onto clutch disc after the car ran. I assume that can be good for the disc. When this happened the car sat for a few months before I started it. It seems the ARP lube doesnt cure and it will spin onto flywheel again. Maybe I will put a thin coat on to eliminate this. Has anyone had this happen to them? When I apply it I use a q-tip and brush on underside of bolt head.
