steering column bearing? - Chevelle Tech
post #1 of 46 (permalink) Old Apr 13th, 05, 7:13 PM Thread Starter
Can anyone identify this bearing, it surrounds the steering shaft right in the center of the turn signal device. The car is a 65 chevelle. I need to get a new one, this one has a ton of play in it. Can anyone tell me where to get one?
1965 Chevelle SS
fusion_ta66 is offline
post #2 of 46 (permalink) Old Apr 13th, 05, 7:57 PM
Todd
Re: steering column bearing?
Did you remove the screws that hold the bearing in place?
If they are missing that would be the source of alot of slop.
I couldn't tell you where to get a new one.
Your best bet would probably be a junkyard.
BAD415 is offline
post #3 of 46 (permalink) Old Apr 13th, 05, 8:31 PM
hrd
jayt
if all the balls are there and round...just grease and tighten like any bearing set, i just went through the same deal
hrd is offline
post #4 of 46 (permalink) Old Apr 13th, 05, 11:31 PM
You can still get that bearing from the dealer.
NCOA Member # 14002
Life is hard, it's harder if you are stupid. (John Wayne)
OO SS OO
540cutlaSS is offline
post #5 of 46 (permalink) Old Apr 13th, 05, 11:31 PM Thread Starter
Yes I do have the screws, I just had taken them out for this pic. When you say 'tighten' the bearing set, do you mean tighten the nut that goes on the end of the steering shaft?
540, do you happen to know the part number? Is it for the bearing or the whole turn signal piece?
1965 Chevelle SS
post #6 of 46 (permalink) Old Apr 13th, 05, 11:57 PM
I don't know if the bearings are in a cage but if they are loose yu can buy individual balls at ace hardware,. Jim
Jim Mac is online now
post #7 of 46 (permalink) Old Apr 14th, 05, 12:00 AM
The bearing only, from old post is 5679205. Same as Corvette and Impala.
New Steering Column Bearing for 64 & 65
shooter is offline
post #8 of 46 (permalink) Old Apr 14th, 05, 12:05 AM
I do not have part #, but I think that size bearing is very common on most columns. A dealer would be able to help. I made my own column from stainless steel and all new GM guts. I was supprised what was still available.
NCOA Member # 14002
OO SS OO
post #9 of 46 (permalink) Old Apr 14th, 05, 7:44 AM
Do you still need the pn# for this bearing? If so I can send it to you, also the lower bearing was not available from the dealer in 2000 when I did my frame off on my 66, if you need that pn# and where to purchase it let me know also. Hope this helps.
Jesse Robertson
Jesse Robertson
T/C Gold 243
Jesse66Original is offline
post #10 of 46 (permalink) Old Apr 14th, 05, 8:55 AM
I have rebuilt a number of 64.66 columns.. and it's my understanding the bearing your referring to is part of and molded into the turn signal switch have that be a Guide or BPC switch.. you pre load it with the spring and top nut .
If the top is loose/bad how is your bottom bushings condition ?
True Connection in CA has all the stuff you need to rebuild a early column.
Wayne
TC # 186
ACES#1556
WayneK is offline
post #11 of 46 (permalink) Old Apr 14th, 05, 9:11 AM Thread Starter
Wayne,
So the bearing is not available separately? What spring are you referring to?
Jesse,
Yes please post the part number you used.
1965 Chevelle SS
post #12 of 46 (permalink) Old Apr 14th, 05, 12:20 PM
Very interesting... I just posted (like 4-5 minutes ago) in the "Electrical" forum about this very same thing (but for a 66, inquiring if it was part of the signal switch, etc...)
Jesse, I am going to email or PM you...
TC #1366
'70 Chevelle 427 Stroker
'66 Convertible Sold
Dual Quad 396 & Conv Int
'66 SS L78
1966_L78 is offline
post #13 of 46 (permalink) Old Apr 14th, 05, 7:22 PM
Rob
These bearing part numbers are 63-65 Corvet.
Steering Column Bearings for 64 & 65 Chevelle available from your Chevrolet dealer
Upper bearing #5679205 cost $12.61
Lower Bearing #7802845 cost $19.12
Thes cost are a couple years old.
This was for my 64 non-tilt. I replaced my old one just for GP. Nothing was wrong, I also thought there was a lot of play but the new one had slop also. It looks like you should add a couple of bearing but that is the way it is. There are 19 bearings.
During the assembly, I remember something touching the edge of the bearing to hold the bearing in place. I am suffering from KRAFT so it is not clear what I did when I put it together a couple of years ago
If you can't find one let me know.
Brob is offline
post #14 of 46 (permalink) Old Apr 15th, 05, 7:29 AM
OK guys, Brob is right on the money with the upper bearing PN# 5679205, cost was $9.58 back in 1999. However at that time I was told the lower bearing was discontinued from GM, if that is still the case here is where I got mine from, there is no PN# on their invoice.
Gary's Classic Chevy Parts
1209 Castle Street
Dallas, Tx.
214-948-1831 or 214-698-8321
Fax 214-948-9408
The bearing was a bit pricy but I could not find one, $21.49 including shipping.
Sorry for not posting sooner but I was busy getting the 66 ready for a Car Show tomorrow and went to a Car Club meeting last night.
Jesse
Street's Classic Chevy Parts
Jesse Robertson
T/C Gold 243
post #15 of 46 (permalink) Old Apr 15th, 05, 11:47 AM
Rich
When you say there is lots of slop in the column are you basing that assessment AFTER you've removed the steering wheel? The canceling cam has a cone shaped nose to it that is pressed into the switch/bearing combo by the spring which is behind the wheel and on top of the cancelling cam. Once the wheel nut is tightened down it's unlikely the bearing will be found to be loose if all the ball bearings are still in the race. Reassemble things once greased before you decide the bearing is loose. Without the cancel cam and spring in place none of it will fit together tightly.
Rich-L79 is offline
This Thread is more than 4398 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
67 steering column lower bearing 4oze Brakes, Suspension & Steering 1 Aug 11th, 04 10:38 PM
steering column bearing? 1966_L78 Brakes, Suspension & Steering 4 Mar 17th, 04 11:23 AM
1968 Steering Column Survey JIML82 Restoration Corner 3 Sep 23rd, 03 11:25 PM
66 4spd lower steering column bearing ETD66SS 2001 2 Jul 16th, 01 4:40 AM
Steering Column Bearing 67BigBlock 1999 -- 2 Feb 5th, 00 8:27 PM
