70 chevelle ss - Chevelle Tech
post #1 of 20 (permalink) Old Nov 5th, 13, 5:16 PM Thread Starter
jeff
70 chevelle ss
hi I just recently inherited a 70 chevelle ss from my brother who just passed away at the age of 44 suddenly anyway trying to find out some info on the car tach not working pin 9 of cluster has brown wire but for some reason I traced it to the fuse box and goes to a fuse connection it also has power on it when key is on also possibly didn't come with the tach package
? don't know if the tach and other gauges for 70 have the green lettering like the speedo does any help would be nice oh and anyone know where the build sheet might be so I can look for it thanks jeff
jeff singer is offline
post #2 of 20 (permalink) Old Nov 5th, 13, 10:52 PM
Re: 70 chevelle ss
I can't help with the wiring, but I've seen build sheets glued to the inside of either door panel as well as in the springs under the front seat. My '70 Atlanta built Chevelle had one sheet on the door panel and a second under the right front corner (bench seat). I've also heard someone say they found one under the package tray, but've never seen that first hand.
2BlueLS6's is offline
post #3 of 20 (permalink) Old Nov 5th, 13, 11:01 PM Thread Starter
jeff
Re: 70 chevelle ss
This is a kan Car
post #4 of 20 (permalink) Old Nov 6th, 13, 12:35 AM
Ray
Re: 70 chevelle ss
A brown wire should goes through the firewall just above the gas pedal to the post on the coil. All the gauge lettering should have a green tint to them for 70.
70 SS Chevelle Van Nuys Cal Built
http://s777.photobucket.com/albums/y...70%20chevelle/
Chevelle and El Camino Club of Oregon
http://www.chevelles-oregon.com/home/
shadowgray396 is offline
post #5 of 20 (permalink) Old Nov 6th, 13, 6:07 PM Thread Starter
jeff
Re: 70 chevelle ss
possibly didn't come with gauges seems from what I read that its an ss car has the boxed in control arms on rear and ss emblems and door panels have ss all the cluster wires colors match the ss but no tach wire so I guess im back to square 1 because the fuse box didn't have a terminal in the 3rd top hole which should be the tach wire from what ive found on the net the only wires that are missing out of cluster connector are the amp guage wires black with white and the black one but like I said the brown one goes to the fuse box on the back to a fuse lug
post #6 of 20 (permalink) Old Nov 6th, 13, 7:58 PM
Ron
Re: 70 chevelle ss
Wow, I hope you can get it but I cant understand your question. ..............Put a few of these in.........
Sorry.
70 Chevelle SS396 (496) Straub roller, M21
69 Malibu convertible
TC #54 Gold
69 - Top down
69 Top up
new wheels
70 side
On Gearz
ToocoolZ28 is offline
post #7 of 20 (permalink) Old Nov 6th, 13, 8:45 PM
Phil
Re: 70 chevelle ss
Can you post a pic of the gauges?
What engine do you have?
Where in Ohio? I'm 30 miles west of Cleveland.
71 Chevelle SS
zz502 (Straub Cam, RPM Airgap, ProSystems Carb, MSD, etc.)
Rossler TH400
Built 12 bolt 4:11
Pics
Video
Slick71ss is offline
post #8 of 20 (permalink) Old Nov 7th, 13, 12:06 AM
Frank Riley
Re: 70 chevelle ss
Try the Electrical & Wiring Fourm... Ton's of Tach info there....
70-454 LS5
Mid America Chevelle Club #293
Greater Kansas City
70-SS454 is offline
post #9 of 20 (permalink) Old Nov 7th, 13, 1:50 PM
Re: 70 chevelle ss
It sounds to me that you have an idiot light harness and possibly an idiot light cluster. Full gauges were an option.
RealRed70 is online now
post #10 of 20 (permalink) Old Nov 9th, 13, 3:53 PM Thread Starter
jeff
Re: 70 chevelle ss
Ya I've come to that conclusion so I've done some rewiring with an old harness took the pins out and made some wiring up and got the tach working then I ordered the correct tach from ground up that has the green lettering got it Friday put it in and it doesn't work start up the car and I goes to 7000 rpm and sits there so I took it back out and they are closed now so im gonna have to send it back I even tried hook it up under the hood power ground coil and 7000 rpms funny the old one worked just wrong for the car sucking
post #11 of 20 (permalink) Old Nov 9th, 13, 4:35 PM
Re: 70 chevelle ss
post #12 of 20 (permalink) Old Nov 9th, 13, 4:42 PM
Re: 70 chevelle ss
I can not make heads or tails of this.
post #13 of 20 (permalink) Old Nov 9th, 13, 5:23 PM
Re: 70 chevelle ss
I think it means this:
Ya I've come to that conclusion so I've done some rewiring with an old harness. I took the pins out and made some wiring up and got the tach working then I ordered the correct tach from ground up that has the green lettering. I got it Friday put it in and it doesn't work. When I start up the car it goes to 7000 rpm and sits there so I took it back out. Ground up is closed now so I'm gonna have to send it back. I even tried hook it up under the hood power ground coil and it still shows 7000 rpms. It's funny the old one worked, just wrong for the car.
post #14 of 20 (permalink) Old Nov 11th, 13, 8:41 PM Thread Starter
jeff
Re: 70 chevelle ss
hey slick 71 I live in Elyria the chevelle has a 396 Muncie 4spd 411 gears tuxedo black with white strips and cowl hood with the top load fresh air that's kinda what was throwing me off a cowl hood and no gauges lol
post #15 of 20 (permalink) Old Nov 11th, 13, 8:55 PM
Re: 70 chevelle ss
Jeff, seriously dude, use some periods and commas so we can tell what you're trying to say without reading it 4 or 5 times.
