Headlight upgrade moves? - Chevelle Tech
post #1 of 11 (permalink) Old Apr 26th, 12, 9:51 PM Thread Starter
George
Guys, planning on more night driving in the 66.. The headlights work correctly but still are weak... What ideas have you guys used to get brighter/ safer lights???
geo's 66 is offline
post #2 of 11 (permalink) Old Apr 26th, 12, 9:58 PM
bln
Re: Headlight upgrade moves?
george here is some good info http://www.madelectrical.com/electri...adlights.shtml
bln is offline
post #3 of 11 (permalink) Old Apr 26th, 12, 10:02 PM
Kevin
Originally Posted by bln View Post
1972 El Camino Custom
1996 Impala SS
2005 SSR 6-speed
1999 Silverado
SSR71 is offline
post #4 of 11 (permalink) Old Apr 27th, 12, 5:36 AM
joe
Send a message via Yahoo to magicrat56
did the upgrade last year using Marks kit,excellent results and Mark is one hell of a nice guy to deal with.
magicrat56 is offline
post #5 of 11 (permalink) Old Apr 27th, 12, 11:40 AM
Weldon
I do instrument wiring by trade so I built my own relay system, which is really not that much of an accomplishment. I was amazed at how much brighter the headlights were, especially on high beam. The relays unloaded the instrument wiring system dramatically.
Weldon
64 El Camino
67 Mercury Cougar
66 Chrysler 300
2004 Dodge Dakota
2008 Chrysler Sebring Vert
2011 Harley Davidson TriGlide
Team Chevelle #5157
wihaltom is offline
post #6 of 11 (permalink) Old Apr 27th, 12, 12:30 PM
Adding relays and plain ol' ordinary halogen sealed-beams beats hell out of installing some Chinese-junk "HID" system that is neither DOT-legal nor particularly effective except to blind oncoming traffic.
Schurkey is offline
post #7 of 11 (permalink) Old Apr 27th, 12, 12:49 PM
Derrick
swap in a modern CS style altnernator and run a big wire directly from the back of the alternator to the battery... this should get you up to almost 14 volts at the lights if the rest of your wiring is in good shape.
-Hank Hill
novaderrik is offline
post #8 of 11 (permalink) Old Apr 27th, 12, 1:00 PM
Matt
Also, some electrical contact cleaner on the terminals never hurts. Even with bulbs installed the contacts can still corrode and dim the lights.
'71 4-Door
My former Daily Driver, a rolling project to be a driver again
You just can't beat points and a carb
MM54 is offline
post #9 of 11 (permalink) Old Apr 27th, 12, 1:26 PM
I did the relay conversion on my 70 driver. ( P.S. NO Chevelle owner is dumber than me ) Dash lights are much brighter, Using Halogen headlight bulbs....
No night driving issues whatsoever! Just added the relays NOTHING ELSE, Using the Org. 70- 63 Amp. Alt.
Mounted the two relays behind the washer bottle on my 70 ( makes them hard to see). Best and very cheeeeeep upgrade for a Chevelle.
I am a guy that wants everything to look STOCK.
P.S. I hid the giant hot wire from the batt. to relays, Inside the core support with the Org. wiring. I also slid the hot wire inside a long piece of vacuum hose to protect it. Reason: A large hot wire that shorts out from the Batt. Would require at least TWO firetrucks to put the fire out.
Did this four years ago. I drive the Wagon a lot at night.
Robinls5 is offline
post #10 of 11 (permalink) Old Apr 27th, 12, 1:32 PM
While I don't use the CS-style alternator, I do wire the relay to the alternator output terminal via ~5 inches of fusible link (16 gauge) and the remaining wire 12 gauge until it splices into the (verified good) OEM headlight harness.
As long as the wire from alternator to relay to headlights has no corroded sections, it will provide alternator voltage or very close to alternator voltage to the headlights; whatever the alternator is regulated at is what the headlights should receive. This is typically 14+ volts.
Schurkey is offline
post #11 of 11 (permalink) Old Apr 28th, 12, 12:43 PM
http://prepostmodern.com/hd/
Coppertop is offline
This Thread is more than 1825 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
