1970 chevelle ss questions - Chevelle Tech
post #1 of 9 (permalink) Old Jan 12th, 11, 9:51 PM Thread Starter
dv
im new to chevelle tech so here it goes. i just purchased a 1970 chevelle ss. i got two build sheet and the pop with the car and im trying to figure out if engine, tranmission and rear end are orginal and i could use some help. the vin is13637k211857. the engine has a block repalce under warrenty in 1974 i was told. number on engine reads ce150203. does anyone think the dealer who replaced engine keep records this long so i could verify. The transmission tag has 484? (hard to read) on top. below reads 70 cf 28729. the build sheet on block no. 28 says cf. The rear end has ccw 06 8 b2. block 29 has cw on it and in the options block 107 g94 331 ratio axle. could anyone help? thanks alot!
dv is offline
post #2 of 9 (permalink) Old Jan 12th, 11, 10:14 PM
Mark
Re: 1970 chevelle ss questions
Check out the vin codes on this site - I think you can get to them from the home page, if not someone will surely answer for you.
On the engine - it's a ce, meaning as said warranty replacement. Therefore, it CANNOT be original, nor ever considered original. Doesn't matter if it was a warranty replacement or not - it's not the engine with the vin stamped on it that came from the factory.
And - Welcome!
Mark
1970 SS396
Lewis Racing Engines (Wolfplace) 489:
634 HP @ 6000rpm
627 Lb-ft @ 4,000rpm
ProSystems SV1
Gear Vendors Overdrive
Moser 12 Bolt
Alumitech Radiator
Pypes Exhaust
Dyno
'70 Chevelle
'70 Chevelle 2
Xtreme70SS396 is offline
post #3 of 9 (permalink) Old Jan 13th, 11, 2:15 PM
Joseph
Post a picture of the Build Sheet and POP.
Joseph
TC# 5427
ACES# 7460
1972 Chevelle SS 454 LS5 "W" Code Convertible
Sequoia Green White Top and Interior
http://i271.photobucket.com/albums/j...skqv2zuon.jpeg
1970 Chevelle SS 396 "L78" 4 Speed Coupe
Black with Black Bucket Interior
http://i271.photobucket.com/albums/j...JoesL78015.jpg
1970 Chevelle SS 454 LS6 Coupe
Forrest Green with Green Bucket Interior
http://i271.photobucket.com/albums/j...srmc0afs8.jpeg
1972convss454 is offline
post #4 of 9 (permalink) Old Jan 13th, 11, 5:31 PM Thread Starter
dv
Here is a copy of my build sheet and the POP.
Thanks alot.
DV
Name:	POP 1970 Chevelle SS.JPG
ID:	37734   Click image for larger version
Name:	1970 Chevelle Build Sheet.jpg
dv is offline
post #5 of 9 (permalink) Old Jan 13th, 11, 5:52 PM
The address on that protect-o-plate is 3.5 miles from me.
post #6 of 9 (permalink) Old Jan 13th, 11, 5:59 PM
I think that's the cleanest build sheet I've ever seen....................where was it found?
Dave Bradley
d1_bradley is offline
post #7 of 9 (permalink) Old Jan 13th, 11, 6:09 PM Thread Starter
dv
its a copy of one found behind glove box its in great shape and i have another that was found under back seat and its in good shape. thanks again to any one that can help
dv is offline
post #8 of 9 (permalink) Old Jan 13th, 11, 6:47 PM
CF is the correct code for your trans
CCW is the code for a 3.31 open rear and I don't see G80 posi option on the buildsheet.
I doubt a dealer would keep records that far back on replacing a motor,but you never know.Bottom line,trans and rear are original,motor has been replaced.
CE code is not a bad deal to have....
mr 4 speed is offline
post #9 of 9 (permalink) Old Jan 13th, 11, 11:21 PM
The dealer was most likely Van Chevrolet which has been gone for years. (that's where my 69 came from.) My friend was a service tech there for 19 years but that was before his time.
There is another Van Chevrolet again now in another part of town which is owned by the same owner of the old dealership.
