396/325hp - is a Holley 650 DP good enough - Chevelle Tech
post #1 of 14 (permalink) Old Mar 30th, 10, 11:10 AM Thread Starter
Hi all,
Can you guys give me your thoughts on a 650 double pumper on a stock 396/325 engine?
I'm wondering if i need more CFM....
Thank you,
Gary
68 ss396 (under restore)
67 Malibu (next in line)
68 Beaumont vert (ok maybe this one next)
65 Skylark GS
Yes i have the same sickness as other on here~!
gatkins2004 is offline
post #2 of 14 (permalink) Old Mar 30th, 10, 11:26 AM
Re: 396/325hp - is a Holley 650 DP good enough
650 would be more than enough for a stock 325 but I don't think a a DP is a very good choice for one. QuadraJet would be my first choice for a stock L-35 but if it has to be a Holley, I like a 60o or 670 vacuum secondary.
Jerry70 is offline
post #3 of 14 (permalink) Old Mar 30th, 10, 11:48 AM Thread Starter
Thanks Jerry, if i want to go more with numbers what is the correct carb for a stock 1968 ss396 chevelle?
Thank you,
Gary
65 Skylark GS
post #4 of 14 (permalink) Old Mar 30th, 10, 1:22 PM
Barry
vacuum secondaries for street use
barryt
Life is too short to wake up with regrets. So love the people who treat you right. Forget about the ones who don't.
T. C .member # 3966
A.C.E.S. member #08387
1968 Chevelle SS396
396 bb, 4 speed
A real 138 vin car
http://www.chevelles.com/showroom/sh...hp/photo/12002
http://www.chevelles.com/showroom/sh.../12972/cat/500
http://www.chevelles.com/showroom/sh.../12971/cat/505:
http://clubs.hemmings.com/columbiaclassicchevyclub
In just two days from now, tomorrow will be yesterday
barryt is offline
post #5 of 14 (permalink) Old Mar 30th, 10, 3:37 PM
"HOW BIG" of a carb is extremely dependent on "HOW HIGH" you plan to spin the engine.
If this is a putt-putt car, 650 cfm is more than enough. I wouldn't use a double pumper on a putt-putt, though.
My '69 325hp 396 used a 750 cfm Q-Jet. I suspect the '68 did, too.
Schurkey is offline
post #6 of 14 (permalink) Old Mar 30th, 10, 3:44 PM
jason
Thank you,
Gary
I have a rochester carb from a 68 396 325hp full size car. Would be willing to sell it. The date is a mid May if you are looking for a date. It will need to be rebuilt. Pm me if interested?
Jason
Jason 67 conv is offline
post #7 of 14 (permalink) Old Mar 30th, 10, 6:13 PM
Matt
I have an Edelbrock 1406 600 cfm elec. choke on my stock 396 325 and it runs awesome. Plenty of carb since it runs out of gusto at around 4400 rpm anyway because of the insanely small cam.
matt's66 is offline
post #8 of 14 (permalink) Old Mar 30th, 10, 7:12 PM
Louis
I would prefer 3310 750 cfm vacuum secondary Holley. 3310 780 vacuum secondary Holley will work, too. I believe the 750 will give you sharper throttle response. The only problem is the intake manifold. You need a square bore type manifold.
Louis
Original owner
http://www.youtube.com/watch?v=wCG7lnacgGg
https://www.youtube.com/watch?v=53OG2K2P9vQ
lg1969 is offline
post #9 of 14 (permalink) Old Mar 30th, 10, 7:58 PM
von
Lifetime Founding Member
Von
Jason
And I can rebuild it for very reasonable cost.
[img]
http://www.chevelles.com/showroom/da...m/DSCN1397.JPG
von is offline
post #10 of 14 (permalink) Old Mar 30th, 10, 8:32 PM
"Wild Bill"
Von just completed the Q-jet for my '69 SS396 w/L35.
Excellent work and highly recommended!!
Team Chevelle #613
ACES #3920
CAMI (Ireland) #14
CanAm Chevelles #136
Carolina Chevelles #185
Heart Of Dixie #231
Long Island Chevelles #113
BillsCamino is offline
post #11 of 14 (permalink) Old Mar 30th, 10, 9:25 PM
Hi all,
Thank you,
Gary
I use a 650 Holley DP and it's run great.
'66 SS owner since 1973(396/325, pg, a/c, ps, pb,3.31 12-bolt posi, am/fm delco w/rear speaker & fader, knee knocker, wood wheel, hazard warning, aztec bronze/black bucket int.w/reclining pass seat)
'65 vette coupe/L79/4speed
'61 Apache" Step side pickup. 6 cylinder, 4 speed, 390 posi (all original except repaint and new wood bed)
jb66ss396 is offline
post #12 of 14 (permalink) Old Apr 1st, 10, 6:28 PM
Rich
This is a good subject since I am on the downslope of putting back together my 67 SS. I have a 66 396 going back in with forged 10:1 pistons and rods, full roller top end with the comp cams mother thumper cam and bowtie alum intake. I have a 800 cfm quadrajet and am at 5,280 above sea level. Is that going to be too much carb? Here in colorado we need lots of air. Perhaps a jet recommendation for the carb would be a good idea at this point. Any ideas?
'66 Impala SS, Needs Restored. '67 Chevelle SS "In Process", '96 Impala SS Blown, Nitrous. Yea, its fast.
NastySS is offline
post #13 of 14 (permalink) Old Apr 1st, 10, 7:29 PM
von
Von
The beauty of the Q jet design is that it's never too much carb if set up right. A jet size couldn't be recommended without knowing the main bleed (upper and lower) sizes. Metering rod sizes enter into this too. GM varied air bleed and jet/rod combos according to desired level of emissions tune, specific engine, etc. I.E. the stock primary jet size for a '66 396 was 71. The size for a '70 396 was 78 and it was a leaner setup for emissions reasons, due to main air bleeds being much larger.
[img]
von is offline
post #14 of 14 (permalink) Old Apr 1st, 10, 8:28 PM
Rocky Hill
Why don't you do the math and see what size carb you need.
http://www.holleycarbs.com.au/chooseCarb.htm
A 396 hi performance engine, spinning it up to 6000rpm calls for a 584 cfm.
So I would say a 650 will do you fine. I have 650 DP on mine, and it works just peachy.
Copied from their site about sizing.
Carburetors with mechanical secondaries must be chosen very carefully, as a carburetor that is too big will result in "bog" or "sag". On the other hand, a carburetor that is too small will give better acceleration times, but power may fall off at higher RPM. In this case, a bigger carburetor is not necessarily better. To calculate the best size carburetor for a mechanical secondary carburetor, follow these guidelines.
The first thing you need to know is the lowest RPM at which you use full-throttle. In a manual, you should drive around to look at your personal driving, and watch your tach. In an automatic, use the convertor stall speed (about 1350 RPM for a typical Chevy converter). Typically, a heavier vehicle with a higher gear ratio (lower numerical ratio) will have a lower RPM rate here. A normal value for a 300 - 400 CID engine is a 650 or 700 CFM carburetor. A lighter car might have a 700 or 750 CFM carbie. To find the exact value, click on the link below and print out the page that opens, or hold a ruler against your screen to connect your minimum full-throttle RPM with your engine size, and extend the line to the carbie size.
Rocky
A Man And His Chevelle!
It's A Beautiful Thing.
TC Member #1530
Mid America Chevelle Club
Queen City Chevelle Club
Heartland Chevelle Club
My Showroom
rocks66ss is offline
